IPL1-105-02-F-SH-K-TR 数据手册
REVISION G
IPL1-1XX-XX-XXX-SH-K-XX
FIG 1
(IPL1-110-02-XXX-SH-K SHOWN)
DO NOT
SCALE FROM
THIS PRINT
C
LEAD STYLE
-02: SINGLE HORIZONTAL .062 BOARD
(USE T-1S64-09-XXX)
-03: SINGLE HORIZONTAL .093 BOARD
(USE T-1S64-09-XXX)
(No. OF POS. X .100[2.54]) + .075[1.91]
2 MAX SWAY
(TYP)
C
(No. OF POS. -1) X .100[2.54]
.130 3.30
PLATING SPECIFICATION
-F: FLASH SELECTIVE (USE T-1S64-09-F)
-L: LIGHT SELECTIVE (USE T-1S64-09-L)
-S: SELECTIVE (USE T-1S64-09-S)
-STL: SELECTIVE TIN/LEAD(USE T-1S64-09-STL)
.025 0.64 SQ REF
01
02
.220 5.59 REF
.200 5.08 REF
.040 1.02
REF
OPTION
-TR: TAPE & REEL
(SEE NOTE 9)
No OF POSITIONS
-02 THRU -25
POLARIZATION
-K: KEYED POLARIZATION
ROW SPECIFICATION
-SH: SINGLE HORIZONTAL
C
.100 2.54 REF
.100 2.54 (TYP)
(No. OF POS. X .100[2.54]) +.160[4.06] REF
"A"
2 MAX TOE
(TYP)
SEE NOTE 7
IPL1-XX-SH
.110 2.79 REF
.215 5.46
.300 7.62
WT-28-03-T
SEE NOTE 8
T-1S64-09-XXX
SEE NOTE 10
C
.214±.008 5.44±0.203
.067 1.71
C
45°
"A"
.100 2.54
(TYP)
C
.025 0.64 SQ
REF (TYP)
C
.006[0.15]
2 MAX SWAY (TYP)
SECTION "A"-"A"
SCALE 2.5 : 1
C
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM TERMINAL / WELD TAB RETENTION: 1.0LB. [4.4N]
3. PARTS TO BE MOLDED TO POSITION.
4. POST MUST BE WITHIN .005[0.13] OF EACH OTHER.
5. ALL PIN TO PIN DIMENSIONS TO BE MEASURED FROM TIP TO TIP.
6. DIMENSION TO BE MEASURED AT BEND.
7. TIP TO BE FLUSH TO .010[0.254] BELOW TOP OF SHROUD.
8. THIS NUMBER REPRESENTS THE NUMBER OF POSITIONS PER ROW ONLY AND IS NOT
INTENDED TO BE USED IN POSITION NUMBERING.
9. PARTS TO BE PACKAGED IN TUBES IF TAPE & REEL IS NOT SPECIFIED.
10. INDENTION FROM WELD TAB CARRIER IS ALLOWABLE.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP UL94-V0, COLOR: BLACK
TERMINAL: PHOS BRONZE
F:\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-SH-K-XX-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.100[2.54] SINGLE ROW TERMINAL ASSEMBLY
DWG. NO.
BY: D. SCHMELZ
10/31/2008 SHEET 1 OF 2
REVISION G
PACKAGING VIEW
(PARTS TO HAVE POSITION #1 LOADED
IN SAME DIRECTION AS ARROW ON TUBE)
IN-PROCESS 2
FILL T-1S64-09-XXX
IN-PROCESS 1
FILL WELD TAB
"A"
T-1S64-09-XXX
C
PT-1-24-01-106
.108 2.73
.215 5.46
REF
.025 0.64 REF
WT-28-XX-X
C
.530 13.46
REF
.240±.005 6.10±0.127
C
FIG. 2
(IPL1-125-02-XXX-SH-K SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG. 1)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: D. SCHMELZ
10/31/2008 SHEET 2 OF 2
IPL1-105-02-F-SH-K-TR 价格&库存
很抱歉,暂时无法提供与“IPL1-105-02-F-SH-K-TR”相匹配的价格&库存,您可以联系我们找货
