F-219 SUPPLEMENT
IPR1–06–D
T1M74-L–01–F
MRTD–06–24–L–03.3
(2.54 mm) .100"
IPR1, T1M74-L, T1M74-R, MRTD, MRTDT SERIES
DISCRETE WIRE COMPONENTS & TOOLING
SPECIFICATIONS
PINS
PER ROW
D
–02, –03, –04,
–05, –06, –08,
–10, –12, –15
= Double
Row
TYPE
For complete specifications
see www.samtec.com?IPR1,
www.samtec.com?T1M74-L
or www.samtec.com?T1M74-R
RECOGNITIONS
IPR1
For complete scope
of recognitions see
www.samtec.com/quality
= Body,
Loose
TOOLING
• Mini Applicator (20-24 AWG):
CAT-MC-174-2024-XX-01
• Mini Applicator (26-30 AWG):
CAT-MC-174-2630-XX-01
Insulator Material:
Nylon 66
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-40 °C to +105 °C (PVC) ®
-55 °C to +125 °C (*Teflon )
Wire:
20 to 30 AWG
RoHS Compliant:
Yes
*DuPont™ Teflon ® is a
registered trademark of the
E.I. du Pont de Nemours
and Company or its affiliates.
= Contact,
Full Reel
(15,300 Parts
per Reel)
(5.08)
.200
(19.33)
.761
(1.57)
.062
DIA
(3.81)
.150
(3.17)
.125
Insulator Material:
Nylon
MRTD
= Double Row
PVC Cable
MRTDT
= Double Row
*Teflon® Cable
(20, 24, 28 &
30 AWG only)
PINS PER
ROW
WIRE
GAUGE
–02,
–03, –04,
–05, –06,
–08, –10,
–12, –15
–20
–20C♦
–22
–24
–24C♦
–26
–28
–28C♦
–30
(Standard sizes)
01
(5.08)
.200
(7.62)
.300
No. of positions
x (2.54) .100
+ (3.81) .150
RECOGNITIONS
(2.54)
.100
For complete scope
of recognitions see
= 10 µ" (0.25 µm)
Gold on contact
T1M74-R
(9.65)
.380
SPECIFICATIONS
–L
= 20 to 24 AWG
(1.91)
.075
TYPE
= Gold flash
on contact
–02
= Contact,
Loose
(17.53)
.690
• Extraction Tool:
CAT-EX-74-01
see www.samtec.com?MRTD
or www.samtec.com?MRTDT
(7.62)
.300
–F
= 26 to 30 AWG
T1M74-L
(8.38)
.330
• Hand Tool:
CAT-HT-174-2030-13
Mates with:
MMSD(T)
–01
–D
(Standard sizes)
No. of positions
x (2.54) .100
+ (3.81) .150
FILE NO. E111594
PLATING
OPTION
WIRE
GAUGE
TYPE
PLATING
OPTION
–L
= 10 µ"
(0.25 µm)
Gold on
contact
Contact Material:
Phosphor Bronze
ASSEMBLY
LENGTH
PINOUT
–“XX.X”
Leave blank for single
ended cable assembly.
= Assembly Length
in Inches
Single ended =
(76.2 mm) 03.0" min.
Double ended =
(84.0 mm) 03.3" min.
Note:
♦ C specifies
color coded cable.
See website for color coding.
END 1
–L1
= Plastic Transfer
Latch up, straight
APPLICATION
MRTD
(2.54)
.100
(2.54)
.100
(17.53)
.690
(9.14)
.360
MMSD
FILE NO. E111594
Note:
Teflon ® cable is
intended for crimp only.
Contact Samtec for
solderable cable applications.
MRTD/MRTDT
–L4
= Plastic Transfer
Latch down, straight
END 2
Note: Acceptable panel thickness of
(0.84 mm) .0329" to (2.28 mm) .0897"
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“IPR1-03-D”相匹配的价格&库存,您可以联系我们找货
