DSUBMINIATURE CONNECTOR J SERIES
Solder pot plug and socket
01
SOLDER POT PLUG AND SOCKET
Solder pot socket
Solder pot plug
Features –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
• The socket contacts are formed by high-speed stamping presses
to obtain the advantages of cold working. They are therefore
highly elastic, which in turn ensures reliable connection even after
many mating cycles.
• The dimples in the plug shell ensure continuity between it and the
socket shell, thus providing complete shielding.
Standards ––––––––––––––––––––––
Recognized E60389
1Certified LR20812
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
1
• Costs are kept low by selective gold plating the contacts.
• The solder cup portions of the contacts are tin-plated for easy
soldering.
• Insulator housings are made of a heat-resistant glass-filled PBT
resin.
D SUBMINIATURE CONNECTOR J SERIES
Specifications–––––––––––––––––––––––––––––––––––––––––––––––––––––
Materials
Model number identification
Connector Part name
Material and Finish
Brass, gold-plated product:
Nickel-undercoated,
Mating part; gold-plated
Solder tail; tin-plated (reflow treatment)
tin-plated product: Copper-undercoated,
Glass-filled PBT, UL94V-0, black
Steel, copper-undercoated, nickel-plated
Phosphor bronze,
Nickel-undercoated,
Contact
Plug
Insulator
Shell
Contact
Socket
Insulator
Shell
J
E
Z - 9
P - 12 - 3
• Series name
• Shell size: E, A, B ,C
• Wire connection style: Z ... Solder pot type
• Number of circuits: 9, 15, 25, 37
• Connector type: P ... Plug, S ... Socket
Characteristics
• Finish
Blank ... Gold-plated (flash)
13 ... 0.4 micron gold-plated
90 ... Tin-plated (reflow treatment)
12 ... 0.2 micron gold-plated
14 ... 0.76 micron gold-plated
Current rating
3 A AC, DC (2 A for 37 circuits)
Voltage rating
250 V AC, DC
Temperature range
-40˚C to +85˚C
(including temperature rise in applying electrical current)
• Plating specification of shell: 3 … Copper-undercoated, nickel-plated
Contact resistance
Initial value/ 15 mΩ max.
After environmental tests/ 30 mΩ max.
Insulation resistance
5,000 MΩ min.
Withstanding voltage
1,000 VAC/minute
Note: 1. The relationship between number of circuits and shell size is
shown below.
9: E, 15: A, 25: B, 37: C
2. Contact JST for special plating requirements.
Note: Contact JST for details.
Socket
Plug
φ3.05
A
φ3.05
A
10°
B
(5.95)
B
Dimensions (mm)
Model No.
Gold-plated
Tin-plated
A
B
C
Q´ty/
box
JEZ-9P-3
Circuits
(6.18)
(10.9)
C
(10.72)
C
12.55
7.9
12.55
8.35
2.84
2.84
10°
Model No.
Dimensions (mm)
Gold-plated
Tin-plated
A
B
C
Q´ty/
box
Circuits
JEZ-9P-90-3
16.92
24.99
30.80
100
9
JEZ-9S-3
JEZ-9S-90-3
16.34
24.99
30.80
100
15
JAZ-15P-3
25.25
33.32
39.14
100
15
JAZ-15S-3
JAZ-15S-90-3
24.67
33.33
39.14
100
25
JBZ-25P-3
JBZ-25P-90-3
38.97
47.04
53.04
50
25
JBZ-25S-3
JBZ-25S-90-3
38.38
47.04
53.04
50
37
JCZ-37S-3
JCZ-37S-90-3
54.84
63.50
69.32
50
9
37
JCZ-37P-3
JCZ-37P-90-3
55.43
63.50
69.32
RoHS compliance Gold-plated products display (LF)(SN) on a label.
50
2
Right angle through-hole plug and socket
01
RIGHT ANGLE THROUGH-HOLE PLUG AND SOCKET
(with hexagonal lock screw blocks)
Right angle through-hole socket
(with rectangular lock screw blocks)
(with bail lock)
• The socket contacts are made by high-speed stamping presses.
• To ensure complete shielding, a wide variety of grounding
This promotes the uniform elasticity of the twin-contact mating
adapters are available so that the sockets can be grounded to
sections and therefore ensures reliable contact even after
different kinds of supporting structures.
repeated mating cycles. The solder tails are U-shaped for extra
strength.
• Costs are minimized by selective gold plating, high speed
stamping presses, and completely automated assembly.
3
• Metric, inch or other lock screw blocks are available for fastening
mating plugs.
Specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––
Materials
Part name
Material and Finish
Brass, gold-plated product: Nickel-undercoated,
Plug
Contact
Phosphor bronze, gold-plated product: Nickel-undercoated,
Socket
Insulator
Shell
Heaxagonal lock screw block
Rectangular lock screw block
Zinc, copper-undercoated, nickel-plated
Grounding adapter having a 3.2 mm dia. hole
Grounding adapter having an M3 tapped hole
Grounding adapter having a spring lock lever
Bail lock
Spring lock
Accepts bail lock
Brass, nickel-undercoated, tin/copper alloy-plated
Stainless steel
Characteristics
Current rating
Voltage rating
3 A AC, DC (2 A AC, DC for 37 circuits)
250 V AC, DC
Temperature range
-40˚C to +85˚C
Contact resistance
5,000 MΩ min.
1,000 VAC/minute
Applicable
1.6 mm
PC board thickness
Recognized E60389
Certified LR20812
J
E
Y - 9
S - 1A
3
A
12
S1
• Series name
• Wire connection style: Y... Right angle through-hole style
S ... Socket
• Connector construction/Dimensions: Standard J series
• Types of grounding adapters: 0 ... Without grounding adapters
1 ... With grounding adapters having a 3.2 mm dia. hole
2 ... With grounding adapters having an M3 thread
3 ... With grounding adapters having a spring lock device (1)
4 ... With grounding adapters having a spring lock device (2)
• Types of lock screw blocks: A ... With hexagonal lock screw blocks having a No. 4-40UNC inch thread
B ... With hexagonal lock screw blocks having an M2.6 thread
C ... With rectangular lock screw blocks having an M2.6 thread
D ... Without lock screw blocks
E ... Without lock screw blocks, but with grounding adapters having a 3.05 mm dia. hole
F ... Without lock screw blocks, but with grounding adapters having a No. 4-40UNC inch thread
G ... Without lock screw blocks, but with grounding adapters having an M2.6 thread
H ... Without lock screw blocks, but with grounding adapters having an M3 thread
• Finish: Blank ... Gold-plated (flash)
• Bail locks: Blank...Without bail locks
S or S1...With bail locks
S2...With bail locks (with addition of spring characteristic)
Note: 1. The relationship between number of circuits and shell size is shown below.
3. Contact JST for the Socket with bail locks. (Not UL/CSA approved.)
4
Type A
Type B
With hexagonal
lock screw
blocks (H: 6.3 mm)
having a
No.4-40UNC
inch thread
With hexagonal
lock screw
blocks (H: 6.3 mm)
having an
M2.6 thread
A
10°
D
12.55
2.84
2.84
3.2
0.75
8.35
H
0.6
B
(5.95)
E
C
(18.6)
H: Height of the lock screw block (for Types A, B & C)
Dimensions (mm)
Model No.
Circuits
Gold-plated plug
Tin-plated plug
A
B
C
D
E
Q´ty/
box
JEY-9P-1A**
JEY-9P-1A**90
16.90
24.99
30.80
8.1
9.52
100
15
JAY-15P-1A**
JAY-15P-1A**90
25.25
33.33
39.14
8.1
9.52
100
25
JBY-25P-1A**
JBY-25P-1A**90
38.97
47.04
53.00
8.2
9.62
50
9
RoHS compliance This product displays (LF)(SN) on a label.
*1, 2, 3 ... RoHS compliance
*4, 5 ... RoHS compliance This product displays (LF) on a label.
Note: ** shows the location where a two-digit code (see the table below for codes) should be entered.
Note: For example, if a 9-circuit gold-plated (flash) plug with hexagonal lock screw blocks having
Note: a No.4-40UNC inch thread and without grounding adapters is required, specify the model number
Note: as JEY-9P-1A0A.
No.4-40UNC
M2.6
*1
0A
0B
1A
1B
2A
2B
3A
3B
*2
with a 3.2 mm dia. hole
*3
with an M3 thread
*4
with a spring lock device (1)
*5
with a spring lock device (2)
5
Type C
Type D
With rectangular
lock screw blocks
(H: 6.2 mm)
having an M2.6
thread
Without lock screw
blocks
Type E
Type G
Type H
E: Grounding adapter has no thread.
F, G, H: Grounding adapters have a thread (*1) for securing separately-purchased lock screw blocks (*2)
Use a lock screw block
of Model number
JFS-( )S-C1N.
M2.6
Type F
φ3.05
*1: No.4-40UNC inch
thread
*2: Model number
JFS-4S-( )1W(M)
No.4-40UNC
*1: M2.6 thread
*2: Model number
JFS-2.6S-( )1W(M)
M2.6
*1: M3 thread
*2: Model number
JFS-3S-( )1W(M)
M3
0C
0D
1C
1D
1F
1G
2C
2D
2E
2F
2G
3C
3D
3E
3F
3G
4H
6
10°
A
0.76
7.9
B
E
6.18
(18.8)
Dimensions (mm)
Model No.
Gold-plated socket
Tin-plated socket
A
B
C
D
E
Q´ty/
box
JEY-9S-1A**
JEY-9S-1A**90
16.34
24.99
30.81
8.1
9.52
100
15
JAY-15S-1A**
JAY-15S-1A**90
24.67
33.32
39.14
8.1
9.52
100
25
JBY-25S-1A**
JBY-25S-1A**90
38.38
47.04
53.04
8.2
9.62
50
37
JCY-37S-1A**
JCY-37S-1A**90
54.84
63.50
69.32
8.2
9.62
50
9
With hexagonal
lock screw
blocks (H: 6.3 mm)
having a
No.4-40UNC
inch thread
With hexagonal
lock screw
blocks (H: 6.3 mm)
having an
M2.6 thread
12.55
0.6
C
Circuits
Type B
2.84
D
3.2
2.84
H
Type A
Note:1. ** shows the location where a two-digit code (see the table below for codes) should be entered. For example,
Note : if a 9-circuit gold-plated (flash) socket with hexagonal lock screw blocks having a No.4-40UNC inch thread
and without grounding adapters is required, specify the model number as JEY-9S-1A0A.
2. lt may be out of production depending on a combination.
No.4-40UNC
M2.6
*1
0A
0B
1A
1B
2A
2B
3A
3B
*2
*3
with an M3 thread
*4
*5
7
Type C
Type D
With rectangular
lock screw blocks
(H: 6.2 mm)
having an M2.6
thread
Without lock screw
blocks
Type E
Type G
Type H
Used a lock screw
block
[model number
JFS-( )S-C1N]
φ3.05
M2.6
Type F
*1: No.4-40UNC inch
thread
*2: Model number
JFS-4S-( )1W(M)
No.4-40UNC
*1: M2.6 thread
*2: Model number
JFS-2.6S-( )1W(M)
M2.6
*1: M3 thread
*2: Model number
JFS-3S-( )1W(M)
M3
0C
0D
1C
1D
1E
1F
1G
2C
2D
2E
2F
3C
3D
3E
3F
3G
4H
8
2.74±0.05
2.84±0.05
+0.1
9-φ1 0
9.6±0.05
6.86±0.05
4.11±0.05
+0.1
15-φ1
2.84±0.05
5.49±0.05
9 max.
with bail locks: 7.5 max.
1.37±0.05
9 max.
PC board layout (viewed from component side)
2-φ3.2±0.1
2-φ3.2±0.1
2.74±0.05
1.37±0.05
5.49±0.05
4.11±0.05
8.23±0.05
PC board edge
24.99±0.15
PC board edge
33.32±0.15
24.84±0.05
22.1±0.05
5.54±0.05
2.77±0.05
2.84±0.05
+0.1
25-φ1 0
13.82±0.05
11.05±0.05
8.28±0.05
5.54±0.05
+0.1
37-φ1
2.84±0.05
11.05±0.05
8.28±0.05
9 max.
16.56±0.05
13.82±0.05
2.77±0.05
9 max.
19.33±0.05
16.56±0.05
2-φ3.2±0.1
2-φ3.2±0.1
1.4±0.05
1.4±0.05
4.14±0.05
4.14±0.05
6.91
9.68
±0.05
PC board edge
6.91±0.05
PC board edge
9.68±0.05
±0.05
12.42±0.05
12.42±0.05
15.19±0.05
17.96±0.05
15.19±0.05
20.7±0.05
47.04±0.15
23.47±0.05
63.5±0.15
Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers.
2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
Panel layout
Mounting on the rear side
Mounting on the front side
A
B
C
2-φ3.2±0.1
4-1.6R
10°
A±0.15
B±0.2
C±0.2
9
24.99
20.6
12.0
15
33.32
28.8
12.0
25
47.04
42.6
12.0
37
63.50
59.0
12.0
Circuits
The connector can be mounted either on the front side or on the rear side of
the panel as shown above.
Use M2.5 or M2.6 screws for installation.
9
Note: The dimensions above should serve as a guideline.
Straight through-hole plug and socket
01
STRAIGHT THROUGH-HOLE PLUG AND SOCKET
Straight through-hole socket (without lock screw blocks, but with
grounding adapters having a No.4-40UNC inch thread)
• Three standard types are available with different dimensions
between the flange and solder tail: 6 mm, 9 mm, and 12 mm.
Standard product
Bail locks with shell
• The roots of the contact leads are covered to prevent flux from
• A grounding adapter with a spring lock device allows the
6
rising into the connector during soldering.
connector to be temporarily secured onto the printed circuit board
so that the connector can be soldered easily.
1Certified LR20812
9
Recognized E60389
9
10
Materials
Part name
Material and Finish
Plug
Contact
Socket
Insulator
Shell
Grounding adapter
with spring lock device
Cutting product
Stamping product
Brass, tin-plated (reflow treatment)
Bail lock
Spring lock
Accepts bail lock
Stainless steel
Characteristics
Current rating
Voltage rating
3 A AC, DC
250 V AC, DC
Temperature range
-40˚C to +85˚C
Contact resistance
Applicable
PC board thickness
5,000 MΩ min.
1,000 VAC/minute
1.6 mm
Type A
10°
H
H
D 3.5 2.7
D 3.5
D 3.5
2.7
H
9
3.2
5.95
2.7
2.84
2.84
7.6
8.35
12.55
0.5
A
B
5.95
C
6
3.2
(15.04)
5.95
12
3.2
(21.04)
(18.04)
With hexagonal lock
screw blocks(H: 6.3 mm)
having a No.4-40UNC
inch thread
H: Height of the lock screw block (for Types A, B & J)
Circuits
9
25
Dimension
between flange
and solder tail
(mm)
Gold-plated (flash)
Plug
Gold-plated
0.76 micron
6
JES-9P-2A**
JES-9P-2A**14
9
JES-9P-3A**
JES-9P-3A**14
12
JES-9P-4A**
JES-9P-4A**14
6
JBS-25P-2A**
JBS-25P-2A**14
9
JBS-25P-3A**
JBS-25P-3A**14
12
JBS-25P-4A**
JBS-25P-4A**14
Model No.
Dimensions (mm)
A
B
C
D
Q´ty/
box
16.90
24.99
30.8
2.4
100
38.97
47.04
53.0
2.5
50
RoHS compliance This product displays (LF)(SN) A on a label.
Note: ** shows the location where a two-digit code (see the table below for codes) should be entered. For example, if a 9-circuit gold-plated
(flash) plug with hexagonal lock screw blocks having a No. 4-40UNC inch thread and with grounding adapters whose dimension
between flange and solder tail is 6 mm is required, specify the model number as JES-9P-3A3A.
6 mm type
11
9 mm type
No.4-40UNC
12 mm type
3A
J
B
S - 25
P - 2A
3
F
14
S1
• Series name
• Shell size: B, E
• Wire connection type: S ... Straight through-hole type
• Number of circuits: 9, 25
S ... Socket
• Connector construction/ dimensions:
2A ... 6 mm from flange to solder tail,
3A ... 9 mm from flange to solder tail,
4A ... 12 mm from flange to solder tail
• Types of grounding adapter:
3 ... Grounding adapter with a spring lock device (Cutting product), 7 ... Grounding adapter with a spring lock device (Stamping product)
• Types of lock screw block:
F ... Without lock screw blocks, but with grounding adapters having an No.4-40UNC inch thread
J ... With hexagonal lock screw blocks having an M3 thread
K ... Without lock screw blocks, spring lock (Bail lock) with shell
• Finish of mating part
• Bail locks
Blank...Without bail locks, S or S1...With bail locks (bent oval type), S2...With bail locks (with addition of spring characteristic, bent oval type),
S3...With bail locks (with addition of spring characteristic, straight rhombic type), S4...With bail locks (with addition of spring characteristic, rhombic type)
S5...With bail locks (with addition of spring characteristic, straight oval type), S6...With bail locks (with addition of spring characteristic, parallel oval type with shell)
Note: 1. In the J Series, the number of circuits is determined by the shell size: 9 circuits for E and 25 circuits for B.
3. Contact JST for the dimensions between the flange and solder tail other than those listed above.
4. Grounding adapters that can secure printed circuit boards are also available.
5. Contact JST for the Receptacle with spring lock devices. (Not UL/CSA approved.)
Type B
With hexagonal lock
screw blocks
(H: 6.3 mm)
M2.6
Type F
Type H
F, G, H: Grounding adapters have a thread (*1) for securing separatelypurchased lock screw blocks (*2)
*1: No.4-40UNC inch
thread
*2: Model number
SFS-4S-( )1W(M)
No.4-40UNC
3B
Type G
3F
*1: M2.6 thread
*2: Model number
SFS-2.6S-( )1W(M)
M2.6
*1: M3 thread
*2: Model number
SFS-3S-( )1W(M)
M3
3G
Type J
With hexagonal lock
screw blocks
(H: 6.3 mm)
having an M3 thread
M3
3H
3J
12
Straight through-hole socket / Standard product
10°
A
2.7
D
H
2.7
D
H
2.7
D
7.6
2.84
2.84
7.9
12.55
0.5
H
Type A
6
6
B
6.18
C
6
3.2
9
6.18
(15.38)
3.2
12
6.18
(18.38)
3.2
(21.38)
With hexagonal lock
screw blocks (H:6.3 mm)
having a No.4-40UNC
inch thread
Dimension
between flange
and solder tail Gold-plated (flash)
(mm)
socket
Circuits
Model No.
Dimensions (mm)
Gold-plated
0.76 micron
Tin-plated
6
JES-9S-2A**
JES-9S-2A**14
9
JES-9S-3A**
JES-9S-3A**14
12
JES-9S-4A**
JES-9S-4A**14
6
JBS-25S-2A**
JBS-25S-2A**14
JBS-25S-2A**90
9
JBS-25S-3A**
JBS-25S-3A**14
JBS-25S-3A**90
12
JBS-25S-4A**
JBS-25S-4A**14
9
25
A
B
C
D
Q´ty/
box
16.34
24.99
30.8
2.4
100
38.38
47.04
53.0
2.5
50
RoHS compliance This product displays (LF) A on a label.
(flash) socket with hexagonal lock screw blocks having a No. 4-40UNC inch thread and with grounding adapters whose dimension
between flange and solder tail is 6 mm is required, specify the model number as JES-9S-3A3A.
6 mm type
9 mm type
No.4-40UNC
12 mm type
3A
Type B
Type F
With hexagonal lock
screw blocks
(H: 6.3 mm)
M2.6
13
Type H
*1: No.4-40UNC inch
thread
*2: Model number
SFS-4S-( )1W(M)
No.4-40UNC
3B
Type G
3F
*1: M2.6 thread
*2: Model number
SFS-2.6S-( )1W(M)
M2.6
*1: M3 thread
*2: Model number
SFS-3S-( )1W(M)
M3
3G
Type J
With hexagonal lock
screw blocks
(H: 6.3 mm)
having an M3 thread
M3
3H
Note: JBS-25S-2A3H
is excluded.
3J
Straight through-hole socket / Bail locks with shell
10°
Type K
7.9
2.84
12.55
A
6.18
B
Circuits
Dimension
between flange
and solder tail
(mm)
9
9
25
9
9
3.2
(18.38)
C
Model No.
Dimensions (mm)
A
B
C
Q´ty/
box
JES-9S-3A7KS6
16.34
24.99
38
180
JBS-25S-3A7KS6
38.38
47.04
60
108
Gold-plated (flash)
Socket
9 mm type
16.56±0.05
13.82±0.05
11.05±0.05
8.28±0.05
25-φ1 +0.1
2.74±0.05
2.77±0.05
2.84±0.05
9-φ1 +0.1
5.54±0.05
2.84±0.05
5.49±0.05
2-φ3.05±0.05
1.4±0.05
2-φ3.05±0.05
4.14±0.05
1.37±0.05
6.91±0.05
4.11±0.05
9.68±0.05
24.99±0.05
12.42±0.05
15.19±0.05
47.04±0.05
Panel layout
A
B
C
2-φ3.2±0.1
A±0.15
B±0.2
C±0.2
9
24.99
20.6
12.0
25
47.04
42.6
12.0
Circuits
4-1.6R
10°
Note: The dimensions above should serve as a guideline. Contact JST for details.
14
Crimp style plug and socket
01
CRIMP STYLE PLUG AND SOCKET
Crimp style plug
Crimp style socket
Pin contact
Socket contact
• The contacts of this plug are formed by high-speed stamping
presses into continuous strips that can be automatically fed into
our compact crimping machines. Much less time is required to
assemble CRT and RS-232C round cables using this plug than
when soldering connections.
• The contacts in this connector are selectively gold-plated.
Moreover, JST's advanced technological knowledge and
experience are fully utilized to significantly reduce production
costs.
• The dimples in the connector shell provide the ground connection
and are important factors in preventing electromagnetic
interference. The contact has a lance that can be visually
checked during assembly. This assures accurate assembly and
reduces defects.
Materials
Connector Part name
Plug
Contact
Material and Finish
Nickel-undercoated,
Crimping part; tin-plated (reflow treatment)
tin-plated product: tin-plated (reflow treatment)
Insulator
Shell
Contact
Socket
Phosphor bronze,
Nickel-undercoated,
Insulator
Shell
Characteristics
Contact
P
2
1 40
• Series name
• Product shape: S ... Chain
• Type of contact: P ... Pin contact, S ... Socket contact
• Applicable wire: 1 ... AWG #24 to #20, 2 ... AWG #28 to #24
• Material: 1 ... Brass (Pin contact), 3 ... Phosphor bronze (Socket contact)
• Finish: 40 ... Gold-plated (flash), 42 ... 0.2 micron gold-plated,
43 ... 0.4 micron gold-plated , 44 ... 0.76 micron gold-plated,
Note: Contact JST for special plating requirements.
Housing
Current rating
3 A AC, DC (2 A for 37 circuits)(AWG #20)
Voltage rating
250 V AC, DC
• Series name
Temperature range
-40˚C to +85˚C
Contact resistance
5,000 MΩ min.
1,000 VAC/minute
J - S
J - E
C - 9
P - 3
• Wire connection style: C ... crimp style
• Plating specification of shell: 3 ... nickel-plated
Note: The relationship between number of circuits and shell size is shown below.
Standards ––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Recognized E60389
1Certified LR20812
15
Pin contact (for plug housing)
Socket contact (for socket housing)
15.3
1.9
1.9
16.3
3.6
4.25
3.6
1
1.4
5.8
Model No.
Applicable wire
Pin contact
Socket contact
AWG #
lnsulation O.D.
(mm)
J-SS1340
# 24∼# 20
1.1∼1.8
J-SS2340
# 28∼# 24
0.9∼1.3
Gold-plated
Tin-plated
Gold-plated
J-SP1140
J-SP1190
J-SP2140
J-SP2190
Plug housing
10°
(10.7)
B
7
7.9
B
6.18
C
(10.8)
Model No.
12.55
(10.7)
(5.95)
C
φ3.05
A
7
8.35
2.84
φ3.05
2.84
A
Circuits
10,000
Socket housing
12.55
10°
Q´ty/reel
Dimensions (mm)
A
B
C
Q´ty/
box
Circuits
(10.9)
Model No.
Dimensions (mm)
A
B
C
Q´ty/
box
JEC-9P-3
16.92
24.99
30.80
100
9
JEC-9S-3
16.34
24.99
30.80
100
15
JAC-15P-3
25.25
33.32
39.14
100
15
JAC-15S-3
24.67
33.33
39.14
100
25
JBC-25P-3
38.97
47.04
53.04
50
25
JBC-25S-3
38.38
47.04
53.04
50
37
JCC-37P-3
55.43
63.50
69.32
50
9
RoHS compliance
RoHS compliance
Crimping machine, Applicator
Contact
Crimping
machine Crimp applicator
J-SP1***
J-SS1***
AP-K2N
J-SP2***
J-SS2***
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/J-SP/SS1
*MKS-SC
SC/J-SP/SS1
APLSC J-SP/SS1
MKS-L
MK/J-SP/SS1
APLMK J-SP/SS1
APLMK J-SP/SS1
*MKS-SC
SC/J-SP/SS1
APLSC J-SP/SS1
MKS-L
MK/J-SP/SS2
APLMK J-SP/SS2
*MKS-SC
SC/J-SP/SS2
APLSC J-SP/SS2
MKS-L
MK/J-SP/SS2
APLMK J-SP/SS2
*MKS-SC
SC/J-SP/SS2
APLSC J-SP/SS2
Note: *Strip-crimp applicator
16
D
SUBMINIATURE
CONNECTOR
J&JK SERIES
Accessories/EMI prevention shielding cover ( J cover)
J COVER
J cover
• This shielding cover is made of steel, formed by our advanced stamping
technology, and nickel-plated.
Cover nut
Cover
• The box-shaped cover completely encloses such EMI radiating areas as the connections
between the connector and wires. The result is a superior shielding effect.
• To install the shielding cover, simply align and press the upper and lower cover
elements, then tighten the nuts. It then securely grips the round cables.
• This cover is so compact, light and sturdy, that it can be used to cover the
connectors of any input/output cable. Moreover, it is attractive in appearance.
Recognized E60389
Applicable cable dimensions
JK series
Cable outer diameter (mm)
15
25
8.0 ± 0.2
10.0 ± 0.2
7.0 ± 0.2
37
Shielding cover B
W
W
Shielding cover A
9
15
J series
Circuits
16.4
16.6
L
L
10
10
6
φ3
J series
JK series
Dimensions
(mm)
Q´ty/
box
Circuits
Model No.
W
L
J-SC9A
15
JK-SC15A
19.4
42.0
200
15
J-SC15A
27.6
46.9
150
25
J-SC25A
41.4
57.0
100
37
J-SC37A
57.8
70.6
125
Circuits
9
Model No.
Circuits
Model No.
J series
JK series
Dimensions (mm)
W
L
Q´ty/box
9
15
J-SC9B
30.0
(42.0)
200
15
J-SC15B
38.0
(46.9)
150
25
J-SC25B
52.0
(57.0)
150
37
J-SC37B
68.0
(70.6)
100
Material and Finish
Material and Finish
RoHS compliance
Note: The cover of the JK series 15-circuit connector is the same as that of the
J series 9-circuit connector, except for the number of circuits indicated.
1
RoHS compliance
J series 9-circuit connector.
D SUBMINIATURE CONNECTOR J&JK SERIES
E-ring
φ5
d
D
Cover nut
Thickness
0.4
L
16.4
Circuits
9
Model No.
D
d
L
Q'ty/box
Model No.
Q'ty/box
J-CN9・15
13.6
7.2
19.0
1,000
J-ER
5,000
J-CN25
J-CN37
16.4
8.4
25.0
1,000
18.8
10.4
28.0
1,500
15
25
37
Material
Stainless steel
RoHS compliance
Note: The cover nuts, lock screws and E-rings are used with both the J and JK
series connectors.
Material
Glass-filled, PBT, UL94V-0, black
RoHS compliance
Lock screw
No.4-40UNC (Inch thread)
M2.6 (Metric thread)
No.4-40UNC
M3 (Metric thread)
M3
4.5
4.5
4.5
M2.6
2.7
2.7
2.7
1.7
1.7
5.7
1.7
5.7
5.7
Type of screw
Model No.
Q'ty/box
J-SL-1C
5,000
J-SL-2C
5,000
M3
J-SL-3C
5,000
(Metric thread)
Material and Finish
RoHS compliance
Use the following Model Nos. when ordering J-covers as a set.
JK series
J series
Parts in one set
Circuits
Model No.
Circuits
Model No.
J-C9-( )C
15
JK-C15-( )C
15
J-C15-( )C
25
J-C25-( )C
37
J-C37-( )C
9
Shielding cover A
Shielding cover B
Cover nut
Lock screw
E-ring
Q'ty/box
1 pc.
1 pc.
1 pc.
2 pcs.
1 set
25
25
RoHS compliance
Note: In the above lock screw model numbers, the number in parentheses indicates the type of screw-1: Inch thread (No.4-40UNC), 2: Metric thread (M2.6),
3: Metric thread (M3).
2
J-cover assembly procedure
J series
JK series
Shielding cover B
Shielding cover B
Lock screw
5
Lock screw
E-ring
E-ring
7
4
6
Connector
Contact
Cover nut
Wire
1
2
Cover nut
Crimp style plug
Copper foil tape
Copper foil tape
Meshed wire
Meshed wire
Wire
Shielding cover A
Shielding cover A
3
C
Lance
Lance
C
B
B
14
A
14
A
Assembly procedure
Dimensions after assembly
1. Connect wires to the connector by soldering or crimping.
2. Fold back the braided shielding wire along the outside insulation
and wind the copper foil tape around the shielding wire.
3. Install the connector into shielding cover A.
4. Screw the lock screws onto shielding cover B.
5. Install the E-rings.
6. Align shielding cover B with shielding cover A and press shielding
cover B until it engages the lances of shielding cover A.
7. Tighten the cover nut until the predetermined position is
reached.
Note: For details of the J-cover assembly procedure, please refer to the
processing specifications separately available. The shielding effect of
the J-cover is critically dependent on proper assembly.
3
Circuits
Dimensions (mm)
J series
JK series
A
B
C
9
15
24.99
(49.0)
13.6
15
33.32
(53.0)
13.6
25
47.04
(64.5)
16.4
37
63.50
(78.5)
18.9
D
SUBMINIATURE
CONNECTOR
J&JK SERIES
Accessories/EMI prevention overmolding cover
MOLD COVER
• This cover completely encloses all wire connections to the
connector, and its braided wire crimp section ensures a reliable
ground connection. The result is excellent shielding.
• This cover is sturdy enough to withstand the high pressure
necessary during overmolding. It can thus be finish-molded directly.
Applicable cable diameter
Circuits
J series
JK series
Cable O.D. (mm)
9
15
8.6±0.2
15
7.6±0.2
25
8.6±0.2
Note: Contact JST for cables other than those listed above.
Ferrule
Circuits
J series
T
L
JK series
9・25
15
φD
15
JK-MC15B-3
J-MC15B
L
8.0
0.5
4.0
B
11.3
0.6
8.0
A
7.0
0.5
4.0
B
10.5
0.6
8.0
J-MC25B-4
39.2
17.4 (25.6)
38
16.2 (24.4)
T
A
Mold cover B
J-MC25A-4
18
18
18
37 (37.6)
*Dimensions in (
the J-MC15B.
39
2.7 7.4
2.7 7.4
2.7 7.8
2.7 7.8
) are those for
18
39
37 (37.6)
*Dimensions in (
the J-MC15A.
Dimensions (mm)
φD
RoHS compliance
Mold cover A
JK-MC15A-3
J-MC15A
Ferrule
) are those for
RoHS compliance
4
Mold cover assembly procedure
Ferrule B
Mold cover B
Contact
Crimp style plug
Ferrule A
Copper foil tape
Braided wire
Mold cover A
Mold
Thumb screw
Mold cover assembly
Note: Customers please prepare mold and thumb screws on your own.
Assembly procedure
1. Processing braided shielding wire
Pass the cable through ferrule B and remove the insulation at
the end of the cable. Install ferrule A and fold back the braided
shielding wire along the outside insulation. Then wind the
3. Assembling the mold covers
Align mold cover B with mold cover A and press mold cover B
until it engages the lances of mold cover A. Install ferrule B
over the cable holding section of the cover assembly and crimp
ferrule B. This completes the assembly.
2. Connecting the wires to the contacts
Connect the wires to the contacts by crimping and insert the
contacts into the housing.
Circuits
J series
JK series
15
9
15
Parts name
Mold cover A
JK-MC15A-3
Mold cover B
JK-MC15B-3
Ferrule A
JK-FL15A-8.0C
Ferrule B
JK-FL15B-11.3
Mold cover A
J-MC15A
Mold cover B
J-MC15B
Ferrule B
25
Model No.
J-FL15B-10.5
Mold cover A
J-MC25A-4
Mold cover B
J-MC25B-4
Ferrule A
JK-FL15A-8.0C
Ferrule B
JK-FL15B-11.3
RoHS compliance
Contact
JK-FL15B-11.3
J-FL15B-10.5
5
Crimping
AP-K2N
MKS-L-RG
Applicator
Dies
MK/JK-MC15
APLMK JK-MC15
MK/J-MC15
APLSC JK-MC15
Material and Finish
Copper, tin-plated
Q'ty/bag
500
1,000
500
200
Copper, tin-plated
500
250
1,000
Copper, tin-plated
500
D
SUBMINIATURE
CONNECTOR
Accessories/Covers
J SERIES
4
19
45
JIS STYLE PLASTIC COVER (for 25-circuit J series connectors)
M2.6× 0.45
40
55
Model No.
Parts in one set
Cover
material
Q´ty/
box
JCB-25M
Covers ........ 2 pcs.
Lock screw ........ 2 pcs.
Cable clamp ........ 2 pcs.
Cover screws and nuts ........ 2 pcs. for each
Clamp screws ........ 2 pcs.
ABS resin
10
• Molded plastic cover.
• This cover can be used together with the hexagonal and
rectangular metric lock screws specified in JIS-C-6361.
14
RoHS compliance
6
D J・JH・JK & KH SERIES
SUBMINIATURE
CONNECTOR
Accessories/Lock screw block
A varietly of accessories are available for the D subminiature connectors.
LOCK SCREW BLOCK
Hexagonal lock screw block
(inch thread: No.4-40UNC)
L
L
H
4.78
H
No.4-40UNC
No.4-40UNC
No.4-40UNC
Type B
Type A
Applicable
series
Dimension /
Model No.
Dimension L (mm)
Model No.
J series right
angle throughJK series right
hole type
hole type
straight throughhole type
13.1
15.0
JFS-4S-C1N
KFS-4S-C1N
JFS-4S-B1W
KFS-4S-B1W
JFS-4S-C1W
KFS-4S-C1W
JFS-4S-B1WM
JFS-4S-C1WM
J series
JH series right
angle throughhole type
KH series right
10.0
11.8
SFS-4S-B1W
HFS-4S-B1W
Dimension
H
(mm)
Type
Spring washer .. 1 pc.
Nut ............ 1 pc.
5.5
A
4.8
5.5
KFS-4S-B1WM
SFS-4S-B1WM
HFS-4S-B1WM
4.8
KFS-4S-C1WM
SFS-4S-C1WM
HFS-4S-C1WM
5.5
Q'ty/
box
2,000
Hexagonal lock screw &
spring washer are integrated
B
RoHS compliance
(metric thread: M3)
L
4.78
L
H
H
M3
M3
Type A
Applicable
series
Dimension /
Model No.
Dimension L (mm)
Model No.
RoHS compliance
7
J series right
hole type
hole type
13.1
JH series right
angle throughJ series
straight through- hole type
KH series right
hole type
Dimension
H
(mm)
15.0
10.0
11.8
JFS-3S-C1N
5.5
JFS-3S-B1W
4.8
KFS-3S-C1W
SFS-3S-B1W
SFS-3S-C1W
HFS-3S-C1W
5.5
SFS-3S-B1WM
HFS-3S-B1WM
4.8
JFS-3S-C1WM
KFS-3S-C1WM
SFS-3S-C1WM
HFS-3S-C1WM
5.5
Type
M3
Type B
Q'ty/
box
A
B
2,000
D SUBMINIATURE CONNECTOR J・JH・JK & KH SERIES
(metric thread: M2.6)
L
L
4.78
H
H
M2.6
M2.6
M2.6
Type B
Type A
Applicable
series
Dimension /
Model No.
Dimension L (mm)
Model No.
J series
JH series right
KH series right
15.0
10.0
11.8
JFS-2.6S-C1N
5.5
JFS-2.6S-B1W
KFS-2.6S-B1W
SFS-2.6S-B1W
HFS-2.6S-B1W
4.8
HFS-2.6S-C1W
5.5
J series right
hole type
hole type
13.1
KFS-2.6S-C1W
Dimension
H
(mm)
JFS-2.6S-B1WM KFS-2.6S-B1WM SFS-2.6S-B1WM HFS-2.6S-B1WM
4.8
JFS-2.6S-C1WM KFS-2.6S-C1WM SFS-2.6S-C1WM HFS-2.6S-C1WM
5.5
Type
Q´ty/
box
A
B
2,000
RoHS compliance
12.5
1.2
M2.6
1
6.2
Model No.
JFS-2.6R-N
Spring washer ............ 1 pc.
Set screw ............ 1 pc.
1
6.1
Q´ty/box
1,000
RoHS compliance
8
Application examples of hexagonal lock screw blocks
• The resulting total dimension from the connector flange to the
Total dimension
6.2
Connector flange
top of the hexagonal lock screw block must be 6.2 mm after
assembly.
Grounding adapter with threads
• The D subminiature connector can be installed on the Panel by
simply tightening the hexagonal lock screw block together with
grounding adapter, which has an identical thread to that of the
F, G, and H types.
Height
of lock
screw
block
4.8
PC board
Panel
thickness 0.8
Spring washer thickness 0.6
DUST COVER (for receptacles)
Type A
Type
Circuits
J series
JK series
9
15
A
9.6
18
6.6
Model No.
J-DCES
J-DCES-1
B
Q´ty/box
1,000
Material
J・DCES
JST
PA, UL94V-0, black
RoHS compliance
Type B
9.6
18
φ3
7.4
J・DCES-1
JST
25
33
EXTRACTION TOOL
With this tool, contacts (connected to wires by crimping) can be
easily removed if they are improperly inserted into plug and
receptacle housings.
Applicable Connector
JK series
9
Model No.
DEJ-0.3
J series
Plug
KEJ-0.7
Receptacle
KEJ-0.4
