Ha-VIS eCon 3000 Full Gigabit Ethernet Basic
2 to 7 Ethernet ports RJ45 and FOC
English
Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0°C ... +55°C / Industrial
temp.: -40°C ... +70°C
Energy
Efficient
Ethernet
■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3
■ Support of jumbo frames (10 kB)
■ Variants with industrial temperature range of -40°C ... +70°C
■ Wide range power supply 24/48 VDC
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
■ Optimised DIN rail bracket
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General description
The Ha-VIS eCon 3000 Full Gigabit family of unmanaged Ethernet switches
is equipped with up to 7 gigabit Ethernet ports and allows for cost-efficient
and quick expansion and/or reconstruction of network infrastructures
with high bandwidth requirements. In this, all switches support extra-long
Ethernet frames (jumbo frames). The slender design of the switches
enables an extremely high packing density on the DIN rail. The selection
includes various combinations of variants with RJ45 and fibre optic cables.
Automatic detection of the transmission rate (auto-negotiation) and of the
wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for
simple plug and play. All variants are available with the temperature ranges
"Industrial" and "Commercial".
Technical characteristics
Switch Features
Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE
Enclosure width
25 mm
Type of connection
RJ45
Number of ports
2, 5, 6, 7
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Frame Size
Auto-MDI(X)
10 kBytes
MAC table size
Transfer conditions
8k entries
Transfer speed
10 / 100 / 1000 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Packet buffer size
1 Mbit
Non-blocking
Yes
Quality of Service
Yes
Energy Efficient Ethernet
Yes
PROFINET compatible
Yes
EthernetIP compatible
Yes
Yes
Twisted pair
Ethernet ports 1000BASE-SX / 1000BASE-LX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
Wavelength
Power supply
FOC
850 nm
Transfer speed
Nominal voltage
24 VDC
Permissible voltage range
48 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Starting current
1.60 A
Overcurrent protection at input
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
Input sensitivity
3.20 A
Yes (12 A)
2.21 W ... 4.73 W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screwed contact
Supply circuit (according to 60950)
Transfer length
Output power
9 VDC ... 60 VDC
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
Single-mode (SM)
SC Duplex
1310 nm
1000 Mbit/s
0.55 km
10 km
-9.5 dBm ... -4 dBm
-9.5 dBm ... -3 dBm
≤ -17 dBm
≤ -21 dBm
SFP ports
Transfer standard
Depending on used SFP
Type of connection
Depending on used SFP, RJ45 or LC
Transfer conditions
Depending on used SFP, TP or FOC
Transfer
speed
Transfer length
Depending on used SFP, 100 or 1000 Mbit/s
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
Enclosures
Ambient conditions
Enclosure width
25 mm
Dimensions H x W x D (without pluggable screw type terminal block and
holding bracket)
Commercial temperature range
142 mm x 25 mm x 107.5 mm
Weight
428 g ... 490 g
Type of installation
35 mm DIN acc. to EN 60 715
Material enclosures
Anodised aluminium / powder-coated
steel sheet
Protection class (with pluggable
screw type terminal block)
III
Status and diagnostic displays
Power ("Pwr")
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
-40 °C ... +70 °C
Storage temperature range
-40 °C ... +85 °C
Relative humidity (operation)
0 % ... 95 % (non-condensing)
Relative humidity (storage and
transport)
Air pressure
2000 m (795 hPa)
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
IP30
Protection class
0 °C ... +55 °C
Industrial temperature range
Link is active
Link is active and data is transferred
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
Link speed ("Spd") off
10 Mbit/s
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
Link speed ("Spd") illuminated yellow
100 Mbit/s
Link speed ("Spd") illuminated green
1000 Mbit/s
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
Drawings
Technical characteristics / order information
Ports / order information
Commercial temp.: 0 °C ... +55 °C
Industrial temp.: -40 °C ... +70 °C
RJ45
SFP
SC
Enclosure
width
Power consumption @ 24 VDC
MTBF
in million h
Switch
Part no.
Switch
Part no.
1
1x MM (0.55 km)
25 mm
92 mA
2.13
Ha-VIS eCon 3011GB-AD
24 03 401 1110
Ha-VIS eCon 3011GBT-AD
24 03 401 1100
1
1x SM (10 km)
25 mm
92 mA
2.13
Ha-VIS eCon 3011GB-AF
24 03 401 1210
Ha-VIS eCon 3011GBT-AF
24 03 401 1200
1
1
25 mm
90 mA
0.95
Ha-VIS eCon 3011GB-AC
24 03 401 1310
Ha-VIS eCon 3011GBT-AC
24 03 401 1300
4
1x MM (0.55 km)
25 mm
155 mA
2.15
Ha-VIS eCon 3041GB-AD
24 03 404 1110
Ha-VIS eCon 3041GBT-AD
24 03 404 1100
4
1x SM (10 km)
25 mm
155 mA
2.15
Ha-VIS eCon 3041GB-AF
24 03 404 1210
Ha-VIS eCon 3041GBT-AF
24 03 404 1200
4
2x MM (0.55 km)
25 mm
182 mA
2.08
Ha-VIS eCon 3042GB-AD
24 03 404 2110
Ha-VIS eCon 3042GBT-AD
24 03 404 2100
4
2x SM (10 km)
25 mm
182 mA
2.08
Ha-VIS eCon 3042GB-AF
24 03 404 2210
Ha-VIS eCon 3042GBT-AF
24 03 404 2200
4
3
25 mm
172 mA
0.99
Ha-VIS eCon 3043GB-AC
24 03 404 3310
Ha-VIS eCon 3043GBT-AC
24 03 404 3300
5
25 mm
149 mA
1.97
Ha-VIS eCon 3050GB-A
24 03 405 0010
Ha-VIS eCon 3050GBT-A
24 03 405 0000
5
1x MM (0.55 km)
25 mm
177 mA
1.91
Ha-VIS eCon 3051GB-AD
24 03 405 1110
Ha-VIS eCon 3051GBT-AD
24 03 405 1100
5
1x SM (10 km)
25 mm
177 mA
1.91
Ha-VIS eCon 3051GB-AF
24 03 405 1210
Ha-VIS eCon 3051GBT-AF
24 03 405 1200
5
2
25 mm
175 mA
0.94
Ha-VIS eCon 3052GB-AC
24 03 405 2310
Ha-VIS eCon 3052GBT-AC
24 03 405 2300
6
25 mm
172 mA
1.76
Ha-VIS eCon 3060GB-A
24 03 006 0010
Ha-VIS eCon 3060GBT-A
24 03 006 0000
6
1
25 mm
178 mA
0.89
Ha-VIS eCon 3061GB-AC
24 03 406 1310
Ha-VIS eCon 3061GBT-AC
24 03 406 1300
7
25 mm
182 mA
0.85
Ha-VIS eCon 3070GB-A
24 03 407 0010
Ha-VIS eCon 3070GBT-A
24 03 407 0000
Copyright© 2014
Date of issue 02.2015
All rights reserved
ICPN Datasheet 0848/01
很抱歉,暂时无法提供与“24034070000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5626.394671+705.56070
- 5+5287.940525+663.11790
- 国内价格 香港价格
- 1+7792.405661+977.18264
- 5+6906.933315+866.14271
- 10+6591.8413610+826.62957
