24 02 405 0010
24 02 405 0010
    HARTING(浩亭)
    HARTING - 24 02 405 0010 - Switch, 5 Ports, Industrial, Unmanaged Fast Ethernet, DIN Rail, RJ45 x 5,...
24 02 405 0010 数据手册
Ha-VIS eCon 2000 Full Gigabit Ethernet Basic 5 to 7 Ethernet ports RJ45 and FOC English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial ­­ temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3 ■ Support of jumbo frames (10 kB) ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General Description The Ha-VIS eCon 2000 Full Gigabit family of unmanaged Ethernet switches is equipped with up to 7 gigabit Ethernet ports and allow for cost-efficient and quick expansion and/or reconstruction of network infrastructures with high bandwidth requirements. In this, all switches support extra-long Ethernet frames (jumbo frames). Due to the extremely flat design, these switches can be accommodated in installations where space is restricted towards the cable connection at the front. The selection includes various combinations of variants with RJ45 and fibre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch features Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE Enclosure width 60 mm 120 mm Number of ports 5 7 Type of connection RJ45 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame size Auto-MDI(X) 10 kBytes MAC table size Transfer conditions 8k entries Transfer speed 10 / 100 / 1000 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Paket buffer size 1 Mbit Non-blocking Yes Quality of service Yes Energy-efficient Ethernet Yes PROFINET-compatible Yes EthernetIP-compatible Yes Yes Twisted pair Ethernet ports 1000BASE-SX / 1000BASE-LX Type of fibre Multi-mode (MM) Type of connection Transfer conditions Wavelength Power supply FOC 850 nm Transfer speed Nominal voltage 24 VDC Permissible voltage range 48 VDC 9 VDC ... 60 VDC Surge protection Yes Reverse polarity proof Yes Starting current 1.60 A Overcurrent protection at input Input sensitivity 3.20 A Yes (2/4 A) Max. power consumption @ 24 VDC 3.22 W ... 4.78 W Conductor cross-section 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) Type of connection Pinout 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) Transfer length Output power SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches Single-mode (SM) SC Duplex 1310 nm 1000 Mbit/s 0.55 km 10 km -9.5 dBm ... -4 dBm -9.5 dBm ... -3 dBm ≤ -17 dBm ≤ -21 dBm Environmental conditions Commercial temperature range Industrial temperature range Storage temperature range 0 °C ... +55 °C -40 °C ... +70 °C -40 °C ... +85 °C Relative humidity (operation) 0% ... 95 % (not-condensing) Relative humidity (storage and transport) 0% ... 95 % (not-condensing) Air pressure (operation) 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. Enclosures Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) 60 mm 120 mm 113.5 mm x 60 mm x 27.3 mm 113.5 mm x 120 mm x 27.3 mm 205 g 378 g ... 393 g Weight Type of installation 35 mm DIN rail acc. to EN 60 715 Enclosures material Anodised aluminium Protection class (with plugged screwed contact) IP30 Protection class illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green Link is active Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s Link speed ("Spd") illuminated green 1000 Mbit/s EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) III Status and diagnostic displays Power ("Pwr") Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Vibrationresonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Drawings Technical characteristics / order information Ports / order information Commercial Temp.: 0 °C ... +55 °C RJ45 SFP SC Enclosure width Power consumption @ 24 VDC MTBF in million h Switch 4 - 3x MM (0.55 km) 120 mm 185 mA 1.69 4 - 3x SM (10 km) 120 mm 199 mA 1.69 5 - - 60 mm 134 mA 5 - 2x MM (0.55 km) 120 mm 5 - 2x SM (10 km) 6 - 6 7 Industrial Temp.: -40 °C ... +70 °C Part no. Switch Part no. Ha-VIS eCon 2043GB-AD 24 02 404 3110 Ha-VIS eCon 2043GBT-AD 24 02 404 3100 Ha-VIS eCon 2043GB-AF 24 02 404 3210 Ha-VIS eCon 2043GBT-AF 24 02 404 3200 3.06 Ha-VIS eCon 2050GB-A 24 02 405 0010 Ha-VIS eCon 2050GBT-A 24 02 405 0000 184 mA 1.69 Ha-VIS eCon 2052GB-AD 24 02 405 2110 Ha-VIS eCon 2052GBT-AD 24 02 405 2100 120 mm 194 mA 1.69 Ha-VIS eCon 2052GB-AF 24 02 405 2210 Ha-VIS eCon 2052GBT-AF 24 02 405 2200 1x MM (0.55 km) 120 mm 183 mA 1.69 Ha-VIS eCon 2061GB-AD 24 02 406 1110 Ha-VIS eCon 2061GBT-AD 24 02 406 1100 - 1x SM (10 km) 120 mm 190 mA 1.69 Ha-VIS eCon 2061GB-AF 24 02 406 1210 Ha-VIS eCon 2161GBT-AF 24 02 406 1200 - - 120 mm 182 mA 1.70 Ha-VIS eCon 2070GB-A 24 02 407 0010 Ha-VIS eCon 2070GBT-A 24 02 407 0000 Copyright© 2014 HARTING Technology Group All rights reserved Date of issue 05.2015 ICPN Datasheet 0838/02
24 02 405 0010 价格&库存
很抱歉,暂时无法提供与“24 02 405 0010”相匹配的价格&库存,您可以联系我们找货
