Data sheet | Item number: 2716-104
PCB terminal block; lever; 16 mm²; Pin spacing 10 mm; 4-pole; CAGE
CLAMP®; 16,00 mm²; gray
www.wago.com/2716-104
Color:
L = pole no. x pin spacing
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
21.06.2021 Page 1/8
Item description
High-current PCB terminal strips with lever-actuated CAGE CLAMP® connection
Tool-free termination – fingers open/close levers
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Four solder pins per contact point provide high mechanical stability
600 V UL for 15 mm pin spacing
Pin and dimensions compatible to high-current, screw-type terminal blocks
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
76 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
55 A
Rated voltage UL (Use Group C)
150 V
Rated current UL (Use Group C)
55 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Lever
Solid conductor
1.5 … 16 mm² / 16 … 6 AWG
Hansastr. 27
32423 Minden
21.06.2021 Page 2/8
Solid conductor
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
1.5 … 10 mm²
Fine-stranded conductor; with uninsulated ferrule
1.5 … 10 mm²
Strip length
12 … 13 mm / 0.47 … 0.51 inch
Conductor connection direction to PCB
30 °
Pole No.
4
Total number of connection points
4
Total number of potentials
4
Number of connection types
1
Number of levels
1
Physical data
Pin spacing
10 mm / 0.394 inch
Width
41.5 mm / 1.634 inch
Height
33.3 mm / 1.311 inch
Height from the surface
28.8 mm / 1.134 inch
Depth
30 mm / 1.181 inch
Solder pin length
4.5 mm
Solder pin dimensions
0.95 x 1.2 mm
Drilled hole diameter with tolerance
1.6 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
4
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.603 MJ
Weight
35.7 g
Hansastr. 27
32423 Minden
21.06.2021 Page 3/8
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
Packaging type
BOX
Country of origin
PL
GTIN
4045454739287
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7131
CSA
C22.2 No. 158
1132097
ENEC
EN 60947
2160584.29
Approval
cURus
Underwriters Laboratories Inc.
UL 1059
UL-Approvals
Logo
Certificate
name
20180629E45172
Optional accessories
Testing and measuring
Item no.: 210-136
www.wago.com/210-136
Test plug; 2 mm Ø; with 500 mm cable; red
Hansastr. 27
32423 Minden
21.06.2021 Page 4/8
Ferrule
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-107
Ferrule; Sleeve for 4 mm² / AWG 12; uninsulated; electro-tin plated
www.wago.com/216-107
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-108
Item no.: 216-109
Ferrule; Sleeve for 10 mm² / AWG 8; uninsulated; electro-tin plated
www.wago.com/216-109
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-207
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; gray
www.wago.com/216-207
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-209
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; red
www.wago.com/216-209
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-244
Hansastr. 27
32423 Minden
21.06.2021 Page 5/8
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
acc. to DIN 46228, Part 4/09.90; gray
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-286
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289
acc. to DIN 46228, Part 4/09.90; red
Downloads
Documentation
Additional Information
Technical explanations
2019 Apr 3
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2716-104
PCB Design
Symbol to
and
Footprint
2716-104
Subject
changes.
Please
Hansastr. 27
32423 Minden
21.06.2021 Page 6/8
Symbol and Footprint 2716-104
URL
Download
URL
Download
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 2716-104
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2716-104
PCB terminal block; lever; 16 mm²; Pin spacing 10 mm; 4-pole; CAGE CLAMP®; 16,00
mm²; gray
Hansastr. 27
32423 Minden
21.06.2021 Page 7/8
Installation Notes
Conductor termination
To open the clamping unit, pull the operating
lever all the way back — 2706 and 2716
Series.
Inserting/removing a conductor – 2706 and
2716 Series.
Testing
Testing with test plug – 2706 and 2716
Series.
Hansastr. 27
32423 Minden
21.06.2021 Page 8/8
很抱歉,暂时无法提供与“2716-104”相匹配的价格&库存,您可以联系我们找货
