Data sheet | Item number: 2857-570/024-001
3-Phase Power Measurement Module; 3x400/690 V/1 A; Modbus RTU;
Digital output; Configuration via software; Supply voltage: 24 VDC
www.wago.com/2857-570/024-001
i
Picture differs from the item.
Item description
Short description:
WAGO's 3-Phase Power Measurement Module in a DIN-rail-mount enclosure measures electrical data in three-phase supply networks – remotely
from the control level.
Measured variables such as active/apparent/reactive power, energy consumption, power factor, phase angle and frequency can be accessed via
Modbus® interface. In addition, the measured variables can be stored on a microSD card.
Features:
Current measurement via 1A current transformer
Mobile measurement and storage of measured values on microSD card
Configuration and display of measured values during operation via configuration interface
Compact device in DIN-rail-mount enclosure saves space used for building technology
Communication of measured values via Modbus® interface
Configurable digital signal output as pulse output
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
04.08.2021 Page 1/11
Note:
Additional setting options via the WAGO Interface Configuration Software
Data
Technical data
Configuration
Configuration options
Input
Input signal type
Voltage
Current
Network configuration
3-phase power measurement with N-conductor (4-conductor)
3-phase power measurement without N-conductor (3-conductor)
Input signal (voltage)
AC 400 V (ULN); AC 690 V (ULL)
Input signal (current)
AC 1 A (Current transformer)
Frequency range
45 … 65 Hz (Harmonics analysis: 0 … 3.3 kHz)
Input resistance (current input)
22 mΩ
Input resistance (voltage input)
1.5 MΩ
Input current (max.)
1 AAC
Input voltage (max.)
400 VAC (ULN); 690 VAC (ULL)
Response threshold
10 mA
Resolution (current)
10 mA
Output – digital
Switching voltage (DO) (max.)
Supply voltage (applied)
Continuous current (DO) (max.)
100 mA (no internal restriction)
Configurable functions (DO)
Threshold value switch
Pulse output (S0 interface)
Communication
Communication
Modbus® RTU
Interface
RS-485 (2-wire) via RJ-45
Number of devices (max.)
32
Addressing
Via Interface configuration software
Hansastr. 27
32423 Minden
04.08.2021 Page 2/11
Signal processing
Measurement method
True RMS measurement (measured value acquisition with 8 kHz)
Measured variables (calculated)
Line-to-line voltage
Outputs
Energy sources
Power factors
Mains frequency
Harmonics analysis (up to 41st harmonic)
Total harmonic distortion (THD)
Signal form
Any periodic signals (considering the threshold frequencies)
Limit frequency
15.9 kHz
Memory card type
WAGO 758-879/000-3102 (microSD; 2 GB)
Measurement error
Transmission error (max.)
≤ 0.5 % for current and voltage (of the full scale value)
Supply
Power supply type
24 VDC
Nominal supply voltage US
DC 24 V (SELV)
Supply voltage range
±30 %
Power consumption at nominal supply voltage
≤ 50 mA (+ IDO)
Safety and protection
Line-to-neutral conductor voltage
AC / DC 600 V
Overvoltage category
III
Pollution degree
2
Safe isolation
Input/supply and communication per EN 61010-1
Requirement (N input)
Shall not be dangerously active
Requirement (ILx input)
Coils/converters with basic insulation
Protection type
IP20
Test voltage
Test voltage (input/output/supply)
AC 3.51 kV; 50 Hz; 1 min
Hansastr. 27
32423 Minden
04.08.2021 Page 3/11
Connection data
Connection type (1)
Voltage
Connection technology
Push-in CAGE CLAMP®
WAGO Connector
WAGO 804 Series
Solid conductor
0.25 … 2.5 mm² / 20 … 12 AWG
Fine-stranded conductor
0.25 … 2.5 mm² / 22 … 12 AWG
Strip length
10 … 11 mm / 0.39 … 0.43 inch
Connection type 2
Current/Power supply/DO
Connection technology 2
Push-in CAGE CLAMP®
WAGO Connector 2
WAGO 741 Series
Solid conductor 2
0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor 2
Strip length 2
9 … 10 mm / 0.35 … 0.39 inch
Connection type (3)
Modbus® communication
Pluggable connectors
2 x RJ-45 (daisy chain configuration)
Physical data
Width
72 mm / 2.835 inch
Height from upper-edge of DIN-rail
55 mm / 2.165 inch
Depth
90 mm / 3.54 inch
Mechanical data
Mounting type
DIN-35 rail
Material data
Fire load
0.047 MJ
Weight
115.6 g
Environmental requirements
Surrounding air temperature (operation)
-40 … 70 °C
Surrounding air temperature (storage)
-40 … 85 °C
Relative humidity
5 … 95 % (non-condensing)
Hansastr. 27
32423 Minden
04.08.2021 Page 4/11
Standards and specifications
Conformity marking
CE
EMC immunity to interference
EN 61000-6-2
EMC emission of interference
EN 61000-6-3
Standards/Specifications
EN 61010-1
Commercial data
PU (SPU)
1 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143827539
Customs tariff number
85437090300
Approvals / Certificates
Ship Approvals
Logo
Approval
Additional Approval Text
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAA00001ZY
Optional accessories
Interface module
Item no.: 289-175/790-108
Interface module; RJ-45; PCB terminal blocks, double-row; Cat. 5; in mounting carrier; with shield
connection; with shield clamping saddle
www.wago.com/289-175
/790-108
Item no.: 289-176
Interface module; RJ-45; with power jumper contacts; RJ-45; Cat. 5; in mounting carrier
www.wago.com/289-176
General accessories
Item no.: 2007-8874
Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured
www.wago.com/2007-8874
Item no.: 2007-8877
Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured
www.wago.com/2007-8877
Item no.: 855-8001
Power tap; with fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); Phase
www.wago.com/855-8001
Hansastr. 27
32423 Minden
04.08.2021 Page 5/11
Item no.: 855-8002
Power tap; without fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); N-conductor
www.wago.com/855-8002
Item no.: 855-8003
Power tap; with fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); Phase
www.wago.com/855-8003
Item no.: 855-8004
Power tap; without fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); N-conductor
www.wago.com/855-8004
Item no.: 855-8006
Power tap; for busbar; with fuse; Mounting screw M6
www.wago.com/855-8006
Item no.: 855-8008
Power tap; for busbar; with fuse; Mounting screw M8
www.wago.com/855-8008
Item no.: 855-8015
Power tap; for busbar; with fuse; Clamping connection
www.wago.com/855-8015
Item no.: 758-879/000-3102
Memory Card SD Micro; 2 GByte
www.wago.com/758-879
/000-3102
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Memory card
Tool
Cables and pluggable connectors
Item no.: 750-923
Configuration cable; USB connector; Length: 2.5 m
www.wago.com/750-923
Item no.: 750-923/000-001
Configuration cable; USB connector; Length: 5 m
/000-001
Item no.: 750-978/000-011
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief
www.wago.com/750-978
/000-011
Current transformers
Item no.: 855-1001/2500-1001
www.wago.com/855-1001
Plug-in current transformer; Primary rated current: 2500 A; Secondary rated current: 1 A; Rated power:
/2500-1001
10 VA; Accuracy class: 1
Item no.: 855-2701/035-001
Plug-in current transformer; Primary rated current: 35 A; Secondary rated current: 1 A; Rated power:
0.2 VA; Accuracy class: 1
www.wago.com/855-2701
/035-001
Item no.: 855-2701/064-001
Plug-in current transformer; Primary rated current: 64 A; Secondary rated current: 1 A; Rated power:
/064-001
Item no.: 855-3001/060-003
Split-core current transformer; Primary rated current: 60 A; Secondary rated current: 1 A; Rated power: www.wago.com/855-3001
Hansastr. 27
32423 Minden
04.08.2021 Page 6/11
0.2 VA; Accuracy class: 3; Cable length: 3 m
/060-003
Item no.: 855-3001/100-003
Split-core current transformer; Primary rated current: 100 A; Secondary rated current: 1 A; Rated
power: 0.2 VA; Accuracy class: 3; Cable length: 3 m
/100-003
Item no.: 855-3001/200-001
Split-core current transformer; Primary rated current: 200 A; Secondary rated current: 1 A; Rated
power: 0.2 VA; Accuracy class: 1; Cable length: 3 m
/200-001
Item no.: 855-3001/250-001
Split-core current transformer; Primary rated current: 250 A; Secondary rated current: 1 A; Rated
/250-001
Item no.: 855-301/050-103
Plug-in current transformer; Primary rated current: 50 A; Secondary rated current: 1 A; Rated power:
1.25 VA; Accuracy class: 3
www.wago.com/855-301
/050-103
Item no.: 855-301/060-101
Plug-in current transformer; Primary rated current: 60 A; Secondary rated current: 1 A; Rated power:
1.25 VA; Accuracy class: 1
/060-101
Item no.: 855-301/075-201
Plug-in current transformer; Primary rated current: 75 A; Secondary rated current: 1 A; Rated power:
2.5 VA; Accuracy class: 1
/075-201
Item no.: 855-301/100-201
Plug-in current transformer; Primary rated current: 100 A; Secondary rated current: 1 A; Rated power:
/100-201
Item no.: 855-301/150-501
Plug-in current transformer; Primary rated current: 150 A; Secondary rated current: 1 A; Rated power: 5
/150-501
Item no.: 855-301/200-501
Plug-in current transformer; Primary rated current: 200 A; Secondary rated current: 1 A; Rated power: 5
/200-501
Item no.: 855-301/250-501
Plug-in current transformer; Primary rated current: 250 A; Secondary rated current: 1 A; Rated power: 5
/250-501
Item no.: 855-301/400-1001
Plug-in current transformer; Primary rated current: 400 A; Secondary rated current: 1 A; Rated power:
/400-1001
Item no.: 855-301/600-1001
Plug-in current transformer; Primary rated current: 600 A; Secondary rated current: 1 A; Rated power:
/600-1001
Item no.: 855-4001/100-001
Hansastr. 27
32423 Minden
04.08.2021 Page 7/11
www.wago.com/855-4001
/100-001
Item no.: 855-4001/150-001
Split-core current transformer; Primary rated current: 150 A; Secondary rated current: 1 A; Rated
/150-001
Item no.: 855-4001/200-001
power: 0.2 VA; Accuracy class: 0.5; Cable length: 3 m
/200-001
Item no.: 855-401/250-501
www.wago.com/855-401
/250-501
Item no.: 855-401/400-501
Plug-in current transformer; Primary rated current: 400 A; Secondary rated current: 1 A; Rated power: 5
/400-501
Item no.: 855-401/600-501
/600-501
Item no.: 855-4101/200-001
www.wago.com/855-4101
/200-001
Item no.: 855-4101/250-001
/250-001
Item no.: 855-4101/400-001
Split-core current transformer; Primary rated current: 400 A; Secondary rated current: 1 A; Rated
/400-001
Item no.: 855-5001/1000-000
Split-core current transformer; Primary rated current: 1000 A; Secondary rated current: 1 A; Rated
power: 0.5 VA; Accuracy class: 0.5; Cable length: 5 m
www.wago.com/855-5001
/1000-000
Item no.: 855-5001/250-001
power: 0.5 VA; Accuracy class: 1; Cable length: 5 m
/250-001
Item no.: 855-5001/400-000
/400-000
Item no.: 855-5001/600-000
Split-core current transformer; Primary rated current: 600 A; Secondary rated current: 1 A; Rated
/600-000
Item no.: 855-501/1000-1001
Plug-in current transformer; Primary rated current: 1000 A; Secondary rated current: 1 A; Rated power: www.wago.com/855-501
Hansastr. 27
32423 Minden
04.08.2021 Page 8/11
/1000-1001
Item no.: 855-501/400-1001
/400-1001
Item no.: 855-501/600-1001
/600-1001
Item no.: 855-501/800-1001
Plug-in current transformer; Primary rated current: 800 A; Secondary rated current: 1 A; Rated power:
/800-1001
Item no.: 855-5101/1000-000
www.wago.com/855-5101
/1000-000
Item no.: 855-601/1500-501
www.wago.com/855-601
Plug-in current transformer; Primary rated current: 1500 A; Secondary rated current: 1 A; Rated power:
/1500-501
Item no.: 855-801/1000-1001
/1000-1001
Item no.: 855-801/2000-1001
Plug-in current transformer; Primary rated current: 2000 A; Secondary rated current: 1 A; Rated power:
/2000-1001
Potential distribution
Item no.: 855-1851/350-000
Current and voltage tap up to 185 mm²; Primary rated current: 350 A; Secondary rated current: 1 A;
Rated power: 0.2 VA; Accuracy class: 0.5; fused
www.wago.com/855-1851
/350-000
Item no.: 855-501/150-000
Current and voltage tap up to 50 mm²; Primary rated current: 150 A; Secondary rated current: 1 A;
/150-000
Item no.: 855-951/250-000
Current and voltage tap up to 95 mm²; Primary rated current: 250 A; Secondary rated current: 1 A;
www.wago.com/855-951
/250-000
Power supplies
Item no.: 787-2850
Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 1.25 A output current
www.wago.com/787-2850
Hansastr. 27
32423 Minden
04.08.2021 Page 9/11
Downloads
Documentation
Manual
V 1.0.0
pdf
16.4 MB
Download
15 Jul 2019
xml
8.8 kB
Download
15 Jul 2019
docx
20.1 kB
Download
V 1.1.0
pdf
1.2 MB
Download
V 1.0.0
pdf
265.8 kB
Download
1.0.0
28 Feb 2019
zip
2.2 MB
Download
1.0.6.18
8 Apr 2021
exe
30.0 MB
Download
1.0.6.18
8 Apr 2021
exe
113.9 MB
Download
Bid Text
2857-570/024-001
X81 - Datei
2857-570/024-001
docx - Datei
Instruction Leaflet
3-Phasen-Leistungsmessmodul
Additional Information
Disposal; Electrical and electronic equipment, Packaging
Libraries
Library
Library for the Wago 3-Phase Powertransducer module 2857-570
WAGO-I/O-PRO Library for
2857-0570/0024-000x
3-Phase Powertransducer modules
Engineering-Software
Software for Interface-Products
WAGO Interface Configuration Software G2 SMALL
The full setup only includes the WAGO Interface Configuration Software G2.
WAGO Interface Configuration Software G2 FULL
The full setup, in addition to the WAGO Interface Configuration Software G2, includes
Hansastr. 27
32423 Minden
04.08.2021 Page 10/11
8 Apr 2021
113.9 MB
the installation for the Microsoft .NET Framework.
CAD/CAE-Data
CAE data
EPLAN Data Portal 2857-570/024-001
URL
Download
ZUKEN Portal 2857-570/024-001
URL
Download
URL
Download
URL
Download
CAD data
2D/3D Models 2857-570/024-001
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2857-570/024-001
3-Phase Power Measurement Module; 3x400/690 V/1 A; Modbus RTU; Digital output;
Installation Notes
Configuration
Configuration via WAGO Interface
Hansastr. 27
32423 Minden
04.08.2021 Page 11/11
很抱歉,暂时无法提供与“2857-570/024-001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9458.596781+1227.55322
