MICRO EDGE CARD SYSTEMS
0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm PITCH
FEATURES & BENEFITS
• Up to 56 Gbps PAM4
• PCI Express® 4.0 (MEC5 Series)
• Solutions for (1.60 mm) .062" and (2.36 mm) .093" thick cards
• Choice of pitch: 0.50 mm, 0.635 mm, 0.80 mm,
Staggered press-fit tails
(MEC8-VP)
• Vertical, right-angle and edge mount orientations
• Available in surface mount and through-hole
Justification beam ensures
card and body are flush
(MEC5)
KEY SPECIFICATIONS
SERIES
PITCH
TOTAL
POSITIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
MEC5
0.50 mm
60-200
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
1.5 A (2 pins)
125 VAC
Yes
MEC6
0.635 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.4 A (2 pins)
185 VAC
Yes
MEC8
0.80 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.3 A (2 pins)
180 VAC
Yes
F-224
MEC1
1.00 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.2 A (2 pins)
250 VAC
Yes
MECF
1.27 mm
10-100
Black/Natural LCP
BeCu
-55 ℃ to +125 ℃
3.5 A (2 pins)
280 VAC
Yes
MEC2
2.00 mm
10-100
Black/Natural LCP
BeCu
-55 ℃ to +125 ℃
3.5 A (2 pins)
235 VAC
Yes
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
25
G b p s
(1.27 mm) .050" PITCH • MINI EDGE CARD SOCKET
MECF
POSITIONS
PER ROW
–05, –08,
–20, –30,
–40, –50
CARD
THICKNESS
–01
PLATING
OPTION
DV
–L
= (1.60 mm) .062"
thick card
Leave blank for
Tube Packaging
= Weld Tabs
(Standard on –02
card thickness, optional
on –01 card thickness)
= (2.36 mm) .093"
thick card
–TR
= Tape & Reel
–FR
–K
= Full Reel Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
Polyimide film
pick & place pad
(–“X”R only)
MECF
POSITIONS
PER ROW
Card Mates:
(1.60 mm) .062"
thick card
(2.36 mm) .093"
thick card
–05, –08,
–20, –30,
–40, –50
CARD
THICKNESS
–01
= (1.60 mm) .062"
thick card
–02
PLATING
OPTION
–L
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= (2.36 mm) .093"
thick card
(-DV option only)
Card Mates:
(1.60 mm) .062"
thick card
(2.36 mm) .093"
thick card
MEC2-TH
Card Mates:
(1.60 mm) .062"
thick card
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
TAIL
OPTION
–DV
3, 4
–20
15, 16
–40
31, 32
41, 42
–50
OPTION
“X”R
Leave blank for
Tube Packaging
–TR
= Tape & Reel
(05 thru 30
positions only)
(Not available
with -TH1)
–K
= Polyimide film
pick & place pad
(–”X”R & –DV only)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(05 thru 30
positions only)
(Not available
with -TH1)
–TH1
–DV
POSITIONS
PER ROW
21, 22
–30
5, 6
= Weld Tabs
(standard on –02 card,
optional on –01 card)
–TH1
–05
–WT
Vertical
Surface Mount
(67.61) 2.662 (65.79) 2.590
–08
G b p s
Through-hole
MEC2-DV
(54.91) 2.162 (53.09) 2.090
–40
–50
14
(2.00 mm) .0787" PITCH • MINI EDGE CARD SOCKET
POSITIONS
PER ROW
(42.21) 1.662 (40.39) 1.590
–30
POSITIONS POLARIZED POSITIONS
PER ROW
(No Contact)
View complete specifications at: samtec.com?MECF-DV
(8.64) .340
(12.45) .490
(29.51) 1.162 (27.69) 1.090
–20
B
(14.27) .562
–08
A
(10.46) .412
–05
MEC2
“X”R
–WT
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–02
OPTION
A
B
POSITIONS
PER ROW
POLARIZED
POSITIONS
(No Contact)
3, 4
–05
(13.40) .528
(11.50) .453
–05
–08
(19.40) .764
(17.50) .689
–08
5, 6
–20
(43.40) 1.709 (41.50) 1.634
–20
15, 16
–30
(63.40) 2.496 (61.50) 2.421
–30
21, 22
–40
(83.40) 3.283 (81.50) 3.209
–40
31, 32
–50
(103.40) 4.071 (101.50) 3.996
–50
41, 42
View complete specifications at: samtec.com?MEC2-DV & samtec.com?MEC2-TH
samtec.com/EdgeCard
F-224
MEC2-08-01-L-TH1-WT 价格&库存
很抱歉,暂时无法提供与“MEC2-08-01-L-TH1-WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 24+46.8418024+6.08452
