Product Data Sheet
Type-2 – Charging Cable
Specification
Product Definition
Charging standard
Type-2
Standards / regulations
IEC 62196-2
Approval
VDE
Country approval
On request
Confection line end
On request
Dimensions Charging Connector
Width
70 mm
Height
110 mm
Depth
200 mm
Conductor length
On request
Ambient Conditions
Ambient temperature (operation)
-30°C … +50°C
Ambient temperature (storage/transport)
-40°C … +80°C
Max. altitude
5.000 m (above sea level)
Degree of protection (plugged)
IP44
Degree of protection (protective cap)
IP44
HARTING Automotive GmbH | Marienwerderstraße 2 | D-32339 Espelkamp
www.HARTING.com/AUTOMOTIVE | e-mobility@HARTING.com
Type-2 – Charging Connector +
Cable
Product Data Sheet
Electrical Properties
Number of phases
Rated voltage for power contacts
Rated current for power contacts
1
3
250 V AC
480 V AC
20 A
32 A
20 A
32 A
4,7 kW
7,4 kW
11 kW
22 kW
Maximum charging power
5 kW
8 kW
16,6 kW
26,6 kW
Resistor coding (between PE and PP)
680 Ω
220 Ω
680 Ω
220 Ω
Charging power
Number of power contacts
3 (L1, N, PE)
5 (L1, L2, L3, N, PE)
Rated voltage for signal contacts
30 V AC
Rated current for signal contacts
2A
Number of signal contacts
2 (CP, PP)
Note on the connection method
Crimp termination (cannot be disconnected)
Mechanical Properties
Mating cycles
> 10.000
Insertion force
< 100 N
Withdrawal
< 100 N
Design
Color housing / handle area
black
Color mating face
black
Color protective cap
black
Housing with customer logo
On request
Material
Material housing / handle area
Plastic
Material mating face
Plastic
Material protective cap
Soft plastic
Flammability rating
V0
Material contacts
Cu-Alloy
Material surface of contacts
Ag
Product Data Sheet
Cable
1 phase
Cable structure
Cable diameter
3 phases
20 A
32 A
20 A
32 A
3 x 2,5 mm² +
0,5 mm²
10,2
± 0,3 mm
3 x 6,0 mm²
+ 0,5 mm²
12,8
± 0,4 mm
5 x 2,5 mm²
+ 0,5 mm²
12,8
± 0,4 mm
5 x 6,0 mm²
+ 0,5 mm²
16,5
± 0,3 mm
Cable resistance at 20°C (2,5 mm²)
≤ 7,98 Ω/km
Cable resistance at 20°C (6,0 mm²)
≤ 3,3 Ω/km
Cable resistance at 20°C (0,5 mm²)
≤ 39,0 Ω/km
Wiring standard
IEC 62893
Type of conductor
Straight, more types on request
Outer sheath, material
TPE-U
Outer sheath, color
On request
Minimum bending radius
9 x cable diameter
Environmental Product Compliance
REACh SVHC
Lead | CAS 7439-92-1
China RoHS
Environmentally Friendly Use Period: 50 years
Product Data Sheet
Drawings
Dimensional drawing
Pin assignment of the vehicle connector
很抱歉,暂时无法提供与“8801504004440A1”相匹配的价格&库存,您可以联系我们找货
