QRM8–036–05.0–L–D–DP–A–K
F-214 (Rev 01OCT14)
QRM8–078–05.0–L–D–A
QRM8–026–02.0–L–D–A
(0,80 mm) .0315"
QRM8 SERIES
SLIM BODY GROUND PLANE HEADER
SPECIFICATIONS
Board Mates:
QRF8, EQRD
For complete specifications and
recommended PCB layouts see
www.samtec.com?QRM8
Insulator Material:
Black LCP
Terminal & Ground
Plane Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Current Rating:
Contact:
2.2 A per pin
(1 pin powered per row)
Ground:
8.5 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
215 VAC
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (018-026)
(0,15 mm) .006" max (036-078)
(1,20 mm)
.047"
NOMINAL
WIPE
Integral
ground/power
plane
Choice of
stack heights
s
ocol
Prot orted
Supp
100 GbE
Increased wipe for
rugged applications
notes at
Download app ppnote
om/a
www.samtec.c mtec.com
@ sa
Contact SIG
on protocols
for questions
Rated @ 3dB Insertion Loss
with PCB effects* w/o PCB effects**
Single-Ended Signaling
–D 9.5 GHz / 19 Gbps 11 GHz / 22 Gbps
Differential Pair Signaling –D 8.5 GHz / 17 Gbps 10.5 GHz / 21 Gbps
Differential Pair Signaling –DP 9 GHz / 18 Gbps 17.5 GHz / 35 Gbps
*Performance data includes effects of a non-optimized PCB.
**Test board losses de-embedded from performance data.
Performance data for other stack heights and complete test data
available at www.samtec.com?QRM8 or contact sig@samtec.com
QRM8/QRF8
7 mm Stack Height
QRM8
Type
PINS PER ROW
NO. OF PAIRS
LEAD
STYLE
PLATING
OPTION
A
TYPE
OTHER
OPTION
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–026, –052, –078
(52 total pins per bank = –D)
–018, –036, –054
(18 pairs per bank = –D–DP)
–02.0
–L
= 2 mm
Body Height
(Not available
with –054 &
–078 positions)
= 10µ"
(0,25 µm)
Gold on
contact,
Matte Tin
on tail
–D
= SingleEnded
–D–DP
= Differential
Pair
–05.0
= 5 mm
Body Height
ALSO AVAILABLE
(MOQ Required)
–07.0
• Other platings
Contact Samtec.
–02.0
–05.0
–07.0
–05.0
–07.0
(7,00)
.276
(10,00)
.394
(12,00)
.472
(9,00)
.354
(12,00)
.472
(14,00)
.551
*Processing conditions will
affect mated height.
B
(9,12)
–05.0 (7,81)
.307 .359
01
QRF8 LEAD STYLE
A
(6,12)
–02.0 (4,81)
.189 .241
No. of Banks x (24,80) .976 + (1,77) .070
MATED HEIGHT*
QRM8
LEAD
STYLE
LEAD
STYLE
= 7 mm
Body Height
–GP
= Guide Post
(Requires –GP on
mating connector)
–K
= (5,00 mm) .197" DIA
Polyimide Film
Pick & Place Pad
–TR
= Tape & Reel
(–018, –026,
–036, –052 only)
(11,12)
–07.0 (9,78)
.385 .438
(4,60)
.181
02
(0,80) .0315
(1,32)
.052
(1,00)
.039
DIA
(2,20)
.087
A
(3,67)
.145
• Edge Rate™
contacts
No. of Banks x (24,80) .976 - (1,10) .043
(1,89)
.074
(3,18)
.125
B
• Increased contact
wipe
• 10 year MFG
• Guide post option
Note: Patented
No. of Banks x (24,80) .976 + (3,55) .140
Note: Some lengths, styles
and options are non-standard,
non-returnable.
–GP OPTION
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
