F-215 (Rev 13JUL15)
QTE–014–01–F–D–DP–A
QTE–040–01–L–D–A
QTE–060–01–L–D–A
(0.80 mm) .0315"
QTE SERIES
HIGH SPEED GROUND PLANE HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QTE
Insulator Material:
Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating: Au or Sn over
50µ" (1.27 µm) Ni
Current Rating:
Contact:
2 A per pin
(1 pin powered per row)
Ground Plane:
23 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
225 VAC mated with QSE
& 5 mm Stack Height
Max Cycles: 100
RoHS Compliant: Yes
Processing:
Lead–Free Solderable: Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (020-060)
Board Stacking:
For applications requiring
more than two connectors per
board contact ipg@samtec.com
Integral metal plane
for power or ground
Board Mates:
QSE
Standard stack heights
from 5 mm to 25 mm
100 GbE
XAUI ®
PCI Express
SATA
t I/O)
MGT (Rocke ™
d
an
iB
fin
In
notes at
Download app ppnote
om/a
c.c
te
m
sa
w.
ww
@ samtec.com
Contact SIG
on protocols
ns
for questio
Rated @ 3dB Insertion Loss
with PCB effects* w/o PCB effects**
Single-Ended Signaling
–D
9 GHz / 18 Gbps
9 GHz / 18 Gbps
Differential Pair Signaling
–D
8 GHz / 16 Gbps
14 GHz / 28 Gbps
–DP 8.5 GHz / 17 Gbps 13.5 GHz / 27 Gbps
*Performance data includes effects of a non-optimized PCB.
**Test board losses de-embedded from performance data.
Performance data for other stack heights and complete test data
available at www.samtec.com?QTE or contact sig@samtec.com
QTE/QSE
5 mm Stack Height
Type
PINS PER ROW
NO. OF PAIRS
QTE
RECOGNITIONS
–020, –040, –060
For complete scope
of recognitions see
www.samtec.com/quality
(40 total pins per bank = –D)
–014, –028, –042
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
–F
–D
= Gold Flash
on Signal Pins and
Ground Plane,
Matte Tin on tails
= Single-Ended
(14 pairs per bank = –D–DP)
–L
ALSO AVAILABLE
= 10µ" (0.25 µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–D–DP = (No. of Positions per Row/14)
x (20.00) .7875
(MOQ Required)
01
–D = (No. of Positions per Row/20)
x (20.00) .7875
(20.00) .7875
(5.97)
.235
02
(0.80)
.0315
(0.20)
.008
A
–C*
= Electro-Polished
Selective
(7.11)
50µ" (1.27 µm) min
.280
Au over 150µ"
(3.81 µm) Ni on Signal
Pins in contact area,
10µ" (0.25 µm) min Au
over 50µ" (1.27 µm) Ni
on Ground Plane
in contact area,
Matte Tin over 50µ"
(1.27 µm) min Ni on
all solder tails
(0.76)
.030
(0.89)
.035 DIA
–D–DP
= Differential Pair
(–01 only)
QTE
LEAD
STYLE
–01
–02
–03
–04
–05
–07
–L
OTHER
OPTION
–09
= (7.00 mm)
.275" DIA
Polyimide
Film Pick &
Place Pad
–TR
= Tape & Reel
Packaging
HEIGHT
WITH (N/A –05 & –07
lead style)
QSE*
A
(4.27)
.168
(7.26)
.286
(10.27)
.404
(15.25)
.600
(18.26)
.718
(24.24)
.954
(13.26)
.522
(5.00)
.197
(8.00)
.315
(11.00)
.433
(16.00)
.630
(19.00)
.748
(25.00)
.984
(14.00)
.551
–L
= Latching
Option
(N/A on –042 &
–060 positions)
*Processing conditions
will affect mated height.
*Note: –C Plating passes
10 year MFG testing
(0.64)
.025
A
TYPE
–K
FILE NO: 090871_0_000
• 15 mm, 22 mm and 30
mm stack height
(Caution: Some automatic
placement/inspection
machines may have
component height
restrictions. Please consult
machinery specifications.)
• 30µ" (0.76 µm) Gold
(Specify -H plating for
Data Rate cable mating
applications.)
• Edge Mount
• 56 (-DP), 80, 100
positions per row
• Guide Posts, Screw Down
& Friction Lock
• Retention Option
Contact Samtec.
s
ocol
Prot orted
Supp
Cable Mates:
EQCD, EQDP, EQRF
(See Also Available note)
Note: Some lengths, styles
and options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
OTHER
SOLUTIONS
• Board Spacing Standoffs.
See SO Series
QTE-060-03-L-D-A-TR 价格&库存
很抱歉,暂时无法提供与“QTE-060-03-L-D-A-TR”相匹配的价格&库存,您可以联系我们找货
