RM15WTPZ-12P(76)
RM15WTPZ-12P(76)
    HRS(广濑)
    HIROSE(HRS) - RM15WTPZ-12P(76) - Circular Connector, RM-W Series, Cable Mount Plug, 12 Contacts, Sol...
RM15WTPZ-12P(76) 数据手册
-Original Multi-purpose High-pin-count Miniature Waterproof Connectors RM-W Series Assembly type (straight plug/RM15W) Ø23 Ø21.5 57 (Low-height plug) Cable Ø21.5 Overview RM-W series connectors originally developed by Hirose offer miniature waterproof connectors to satisfy the requirements of high-capability in a small package. The locking structure adopts a thread coupling style, showing superior waterproof reliability. Cable Fig.1 Assembly type (right-angled plug/RM15W) 41 Cable Features Plugs : Available in 3 types - straight plug, straight lowheight plug, and right-angled plug. Receptacles : Fixing methods : Available in 2 types-Jam nut type and screw tightening type with square flange. The Jam nut types offer a front or back mount application. Available numbers of contacts : 2, 4, 8, 10, 12, 15, 20, 40 contacts in 2 contact plating types: gold or silver. Ø23 Flexible cable arrangements Cable ° In RM-W series, you can select an optimal product for your application through different kinds of both plugs and receptacles. 360 1. Rich variation 40 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 48 Fig.2 2. Waterproof structure When fully mated, the connectors meet the waterproof requirements of IP68. 3. Flexible cable arrangements The assembly type right-angled plugs permit exiting of the cable over a 360-degree range in any direction. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.7⑤ 1 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Product Specifications (RM15WT size products) Voltage rating 600V AC, 840V DC (2 pos.) 500V AC, 700V DC (4, 8 pos.) 350V AC, 490V DC (10 pos.) 350V AC, 490V DC (12 pos.) Current rating 10A (2, 4 pos.) 5A (8, 10, 12 pos.) Operating temperature (Note 1) -25ç to +85ç Storage temperature range (Note 2) -10ç to +60ç Rating Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Characteristic Specification 1. Contact resistance 2mø max. (2, 4 pos.) 4mø max. (8, 10, 12 pos.) 2. Insulation resistance 1,000Mø min Conditions 1A DC 3. Withstanding voltage No flashover or insulation breakdown. 500V DC 1,800V AC/1 minute (2 pos.) 1,500V AC/1 minute (4, 8 pos.) 1,000V AC/1 minute (10, 12 pos.) Frequency : 10 to 55 to 10Hz, single amplitude of 0.75mm, 10 cycles in 3 axis. 4. Vibration No electrical discontinuity for 10µs max. 5. Shock No electrical discontinuity for 10µs max. Acceleration of 490m/s2, 11ms duration, sine half-wave, 3 cycles in each of the 6 axis. 6. Durability (insertion/withdrawal) 4mø max. (2, 4 pos.) 8mø max. (8, 10, 12 pos.) 2,000 cycles 7. Temperature cycle Insulation resistance : 100Mø min. Temperature : -55ç ➝ Room temperature ➝ +85ç ➝ Room temperature Time : 30 ➝ 10 to 15 ➝ 30 ➝ 10 to 15 (Minutes) 5 cycles 8. Humidity Insulation resistance : 100Mø min. (Dry) 96 hours at temperature of 40ç and humidity of 90% to 95%. 9. Water protection When mated with corresponding connector. No water penetration when submerged for 48 hours at the depth of 1.8 meter. Note 1 : Includes temperature rise caused by the current flow. Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating temperature range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Materials / Finish Item Material Finish Remarks Body Zinc alloy, brass Chrome plated or nickel plated ------------------- Insulator Diallyl phthalate resin, or PPS ------------------- UL94V-0 (Color : Black) Contacts Brass, phosphor bronze, or copper alloy Silver plated or gold plated ------------------- Packing SIR (black or red), or NBR (gray) ------------------- ------------------- Note : Do not mix different contact plating. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. RM 15 W T P** - 2 P (**) 1 2 3 4 5 6 7 1 Series name : RM-W 5 Number of Contacts 2 Shell size 6 Contact type P : Male contact S : Female contact 3 Lock type T : Screw Lock 4 Connector type P : Plug LP : Plug(right angle) R : Receptacle 2 1 7 Other specifications A two-digit number is added to indicate other specifications. RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Wrench opening dimension of 18mm Plugs - Straight Long Back Shell M20∞0.75 M19∞1 13 Ø21.5 2 Ø15.2 RM15WTPZA-10S(71) 45.3 (Representative example) Part No. HRS No. RM15WTPZA-2P(7*) 109-1734-5 7* 2 RM15WTPZA-4P(7*) 109-1735-8 7* 4 RM15WTPZA-8P(7*) Part No. HRS No. 43g RM15WTPZA-2S(7*) 109-1729-5 7* 2 44g RM15WTPZA-4S(8*) 109-1730-4 8* 4 43g RM15WTPZA-8S(7*) No. of contacts Weight 109-1736-0 7* 8 RM15WTPZA-10P(7*) 109-1737-3 7* 10 RM15WTPZA-12P(7*) 109-1738-6 7* 12 44g No. of contacts Weight 109-1731-7 7* 8 RM15WTPZA-10S(7*) 109-1732-0 7* 10 RM15WTPZA-12S(7*) 109-1733-2 7* 12 45g Applicable Strain Reliefs External cable clamp + internal, self-tightening JR16WCC-10(72) M20∞0.75 Ø23 Wrench opening dimension of 21mm A Drive screw(2) 17.5 (Representative example) Part No. HRS No. A JR16WCC-4(72) 114-2052-6 72 4 JR16WCC-6(72) 114-2053-9 72 6 JR16WCC-8(72) 114-2054-1 72 8 Weight 17.5g Part No. HRS No. A JR16WCC-10(72) 114-2055-4 72 10 JR16WCC-11(72) 114-2154-6 72 11 JR16WCC-12(72) 114-2056-7 72 12 Weight 17.5g Internal, self tightening JR16WCCA-10(72) M20∞0.75 Ø23 Wrench opening dimension of 21mm A Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] (76)(81) : Silver plated contacts (77)(82) : Gold plated contacts 8 (Representative example) Part No. HRS No. A JR16WCCA-4(72) 114-2076-4 72 4 JR16WCCA-6(72) 114-2077-7 72 6 JR16WCCA-8(72) 114-2078-0 72 8 Weight 16g Part No. HRS No. A JR16WCCA-10(72) 114-2079-2 72 10 JR16WCCA-11(72) 114-2155-9 72 11 JR16WCCA-12(72) 114-2080-1 72 12 Weight 16g Note 1 : Cable jacket diameter : Use A ± 0.2mm Note 2 : When using the self-tightening strain relief verify the cable pull force requirements. 3 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Wrench opening dimension of 18mm Plugs - Straight Short Back Shell M16∞0.75 M19∞1 13 Ø21.5 2 Ø15.2 RM15WTPZ-10S(71) 36.3 (Representative example) Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] (76)(81) : Silver plated contacts (77)(82) : Gold plated contacts Part No. HRS No. RM15WTPZ-2P(7*) 109-1616-9 7* 2 RM15WTPZ-4P(7*) 109-1617-1 7* 4 RM15WTPZ-8P(7*) Part No. HRS No. 32g RM15WTPZ-2S(7*) 109-1611-5 7* 2 33g RM15WTPZ-4S(8*) 109-1612-8 8* 4 32g RM15WTPZ-8S(7*) No. of contacts Weight 109-1618-4 7* 8 RM15WTPZ-10P(7*) 109-1619-7 7* 10 RM15WTPZ-12P(7*) 109-1620-6 7* 12 33g No. of contacts Weight 109-1613-0 7* 8 RM15WTPZ-10S(7*) 109-1614-3 7* 10 RM15WTPZ-12S(7*) 109-1615-6 7* 12 34g Applicable Strain Reliefs External cable clamp + internal, self-tightening  JR13WCC-10(72) Wrench opening dimension of 17mm A Ø20 M16∞0.75 17 Drive screw(2) (Representative example) Part No. HRS No. A JR13WCC-4(72) 114-2045-0 72 4 JR13WCC-5(72) 114-2046-3 72 5 JR13WCC-6(72) 114-2047-6 72 6 Weight 17g Part No. HRS No. A JR13WCC-7(72) 114-2048-9 72 7 JR13WCC-8(72) 114-2049-1 72 8 JR13WCC-9(72) 114-2050-0 72 9 JR13WCC-10(72) 114-2051-3 72 10 Weight 17g Internal, self tightening JR13WCCA-10(72) M16∞0.75 A Ø20 Wrench opening dimension of 17mm 7.5 (Representative example) Part No. HRS No. A JR13WCCA-4(72) 114-2069-9 72 4 JR13WCCA-5(72) 114-2070-8 72 5 JR13WCCA-6(72) 114-2071-0 72 6 Weight 12g Part No. A JR13WCCA-7(72) 114-2072-3 72 7 JR13WCCA-8(72) 114-2073-6 72 8 JR13WCCA-9(72) 114-2074-9 72 9 JR13WCCA-10(72) 114-2075-1 72 10 Note 1 : Cable jacket diameter : Use A ± 0.2mm Note 2 : When using the self-tightening strain relief verify the cable pull force requirements. 4 HRS No. Weight 12g RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Plugs - Right Angle Wrench opening dimension of 21.8mm RM15WTLP-10S(31) M16∞0.75 Ø23 Ø15.2 19.15 Set screw(2) Hexagonal hole opposite side 1.27mm (1.27HEX) M19∞1 39.5 (Representative example) Part No. RM15WTLP-4P(33) RM15WTLP-4S(34) RM15WTLP-8P(33) RM15WTLP-8S(34) HRS No. No. of contacts 109-1886-3 33 4 109-1888-9 34 109-1887-6 33 8 109-1889-1 34 Weight 60.6g 61.6g 61.5g 63.2g Part No. RM15WTLP-10P(33) RM15WTLP-10S(33) RM15WTLP-12P(33) RM15WTLP-12S(33) HRS No. No. of contacts 109-0020-0 33 10 109-0999-4 33 109-0997-9 33 12 109-1911-9 33 Weight 62.1g 63.1g 62.3g 64.3g Note 1 : Packing material : NBR, body plating : nickel Note 2 : HRS recommended tool : 1.27mm Hex Wrench Note 3 : Recommended set screw tightening torque : 0.2 to 0.3N•m. Applicable Strain Reliefs External cable clamp + internal, self-tightening  M16∞0.75 Ø20 Wrench opening dimension of 17mm JR13WCC-10(72) A Drive screw(2) 17 (Representative example) Part No. JR13WCC-4(72) JR13WCC-5(72) JR13WCC-6(72) HRS No. 114-2045-0 72 114-2046-3 72 114-2047-6 72 A 4 5 6 Weight 17g Part No. JR13WCC-7(72) JR13WCC-8(72) JR13WCC-9(72) JR13WCC-10(72) HRS No. 114-2048-9 72 114-2049-1 72 114-2050-0 72 114-2051-3 72 A 7 8 9 10 Weight A 7 8 9 10 Weight 17g Internal, self tightening JR13WCCA-10(72) M16∞0.75 Ø20 Wrench opening dimension of 17mm A Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] (33) : Silver plated contacts (34) : Gold plated contacts 7.5 (Representative example) Part No. JR13WCCA-4(72) JR13WCCA-5(72) JR13WCCA-6(72) HRS No. 114-2069-9 72 114-2070-8 72 114-2071-0 72 A 4 5 6 Weight 12g Part No. JR13WCCA-7(72) JR13WCCA-8(72) JR13WCCA-9(72) JR13WCCA-10(72) Note 1 : Cable jacket diameter : Use A ± 0.2mm Note 2 : When using the self-tightening strain relief verify the cable pull force requirements. HRS No. 114-2072-3 72 114-2073-6 72 114-2074-9 72 114-2075-1 72 12g 5 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacles Front panel mount RM15WTRZ-10S(71) A 6 9 Wrench opening dimension of 18mm 1 1 2 Ø22 2 2 M19∞1 (Representative example) Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] (76)(81) : Silver plated contacts (77)(82) : Gold plated contacts Part No. HRS No. No. of contacts RM15WTRZ-2P(7*) 109-1631-2 7* 2 RM15WTRZ-4P(7*) 109-1633-8 7* 4 RM15WTRZ-8P(7*) 109-1634-0 7* 8 RM15WTRZ-10P(7*) 109-1635-3 7* 10 RM15WTRZ-12P(7*) 109-1636-6 7* 12 A 21 20.65 Weight Part No. HRS No. No. of contacts 13g RM15WTRZ-2S(7*) 109-1637-9 7* 2 14g RM15WTRZ-4S(8*) 109-1639-4 8* 4 13g RM15WTRZ-8S(7*) 109-1640-3 7* 8 RM15WTRZ-10S(7*) 109-1641-6 7* 10 RM15WTRZ-12S(7*) 109-1642-9 7* 12 14g A Weight 21.75 15g 21.6 Note : Recommended nut tightening torque : 3N•m Rear panel mount RM15WTRZA-10S(71) A 2 Ø27 24(HEX) 13 6.5 M19∞1 M21∞1 (Representative example) [Specification number] (76)(81) : Silver plated contacts (77)(82) : Gold plated contacts Part No. HRS No. No. of contacts RM15WTRZA-2P(7*) 109-1651-0 7* 2 RM15WTRZA-4P(7*) 109-1653-5 7* 4 RM15WTRZA-8P(7*) 109-1654-8 7* 8 RM15WTRZA-10P(7*) 109-1655-0 7* 10 RM15WTRZA-12P(7*) 109-1656-3 7* 12 Note : Recommended nut tightening torque : 3N•m 6 A 21 20.65 Weight Part No. HRS No. No. of contacts 22g RM15WTRZA-2S(7*) 109-1657-6 7* 2 23g RM15WTRZA-4S(8*) 109-1659-1 8* 4 22g RM15WTRZA-8S(7*) 23g 109-1660-0 7* 8 RM15WTRZA-10S(7*) 109-1661-3 7* 10 RM15WTRZA-12S(7*) 109-1662-6 7* 12 A Weight 21.75 24g 21.6 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacles (Square flange) Waterproof (When mated with corresponding plug) 9 2 A 6 3 Ø3 .6 2 .9 Ø1 4- 1 1 Ø19 2 28 20.6 28 20.6 3 RM15WTRZB-10S(71) M19∞1 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) [Specification number] (76)(81) : Silver plated contacts (77)(82) : Gold plated contacts Part No. HRS No. No. of contacts RM15WTRZB-2P(7*) 109-1671-7 7* 2 RM15WTRZB-4P(7*) 109-1673-2 7* 4 RM15WTRZB-8P(7*) 109-1674-5 7* 8 RM15WTRZB-10P(7*) 109-1675-8 7* 10 RM15WTRZB-12P(7*) 109-1676-0 7* 12 A Weight Part No. HRS No. No. of contacts 19g RM15WTRZB-2S(7*) 109-1677-3 7* 2 20g RM15WTRZB-4S(8*) 109-1679-9 8* 4 19g RM15WTRZB-8S(7*) 109-1680-8 7* 8 RM15WTRZB-10S(7*) 109-1681-0 7* 10 RM15WTRZB-12S(7*) 109-1682-3 7* 12 21 20.65 20g A Weight 21.75 21g 21.6 Note 1 : Screw size : M3 Note 2 : Recommended nut tightening torque : 0.3 to 0.35N•m 7 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Plug -- Disassembly / Assembly Clamp Gasket Tightening collar Insulator body (P) 3 min Contacts Screw Washer Cable jacket Conductors Wires A Cable B Coupling Back shell Strain relief clamp Cable Back shell Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Tightening ring Part No. Table 1 No. of contacts RM15WTPZA-** 2,4,8,10,12 RM15WTPZ-** 2,4,8,10,12 RM15WTLP-** 10,12 A B 21mm 3mm 12mm 25mm Set screw(2) Disassembly 1Fix the plug in the assembly fixture (RM15TP-T01 (HRS No.150-0098-0)), then remove the insulator body (P) and the back shell. 1. Right-angle plugs have set screws in the tightening ring at 2 locations. Loosen the set screws before removing the back shell. 2 Remove the 2 screws of the strain relief clamp, and then remove the clamp from the tightening collar. Wiring 1 Assure that the cable outer diameter will fit the strain relief clamp, and is prepared as recommended in Table 1. It is recommended that the exposed conductors be pre-soldered, to assure easier insertion in the soldering cup. 2. 2 Pass the parts over the cable in the order of: tightening collar, washer, bushing, back shell, and coupling. Refer to the drawings (above) for assembly orientation of all components. 3Solder the wires to the contacts of the insulator body (P). Use of heat-shrink tubing or another insulating media between the soldered contacts is suggested. Connector Assembly Straight Plugs 1 Place the completely wired insulator body (P) in the assembly fixture secured in a vise. Insert in the coupling, then back shell. The back shell should be tightened to a torque of 3N•m. Right-angle Plugs 1 Place the completely wired insulator body (P) in an assembly fixture secured by a vise. Insert in the coupling, then back shell (with tightening ring). When attaching the back shell, orient the cable in the desired direction and fasten the tightening ring to the insulator body (P) with a torque of 3N•m. After this, tighten and fix the 2 sets crews with a torque of 0.2 to 0.25N•m. 3. Additional assembly recommendations : In applications where continuous extremely high vibrations may be encountered it is recommended that a thread locking compound be applied to male threads prior to assembly (Loctite 263 manufactured by Henkel Japan K.K. or equivalent) 2Assemble in the following order : gasket then washer, then the tightening-collar. During assembly, make sure to keep the tip of the cable sheath at least 3mm from the gasket, as shown in the figure (above). 3To prevent loosening of the male threads, apply Loctite 263 (Henkel Japan K.K. or equivalent) to the male threads of the back shell. Then tighten the tightening-collar to a torque of 3N•m with the clamp and the cable so that the cable cannot rotate. (Screw-tightening torque : 0.65 to 0.70N•m) 4. Points to be checked 1This connector has a waterproof feature. Please verify that the assembled connector is waterproof by conducting the test described below. 2Because the force required to secure the strain relief clamp differs with the cable structure, please check the connector assembly before use to make sure there is no rotation. (Test verification of waterproof capability) Apply air pressure of 17.6kPa for 30 seconds from the mating end of the plug connector. No air should leak from inside the connector. Precautions 5. The waterproof capability may be impaired if the cable sheath or gasket is damaged or contaminated when performing the assembly. Please handle carefully. 8 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacle - recommended panel cut-outs Rear mounting, front nut Square flange, screw mounting 20.6±0.05 +0.1 0 Ø24 +0.1 0 Ø7.6 +0.1 0 Ø19.65 +0.05 0 Ø21 20.6±0.05 .1 +0 0 Ø17 4-M3∞0.5 Ø19.2 +0.1 0 Front mounting, rear nut 1.4±0.05 Panel thickness : 0.5 to 2mm Panel thickness : 0.5 to 2.5mm Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For RM15WTRZ receptacles For RM15WTRZA receptacles Panel thickness : 2.5 to 4mm For RM15WTRZB receptacles Note 1 : When attaching the receptacle to the panel, be certain to check that the gasket is in place in the groove. Do not pinch the gasket. Note 2 : The view of the above diagrams is from the receptacle mating side. Note 3 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Contact Arrangement and Specifications Shell size : 15 Contact arrangement No. of contacts 2 4 Withstanding voltage 1,800V AC / 1 minute Current rating 8 1,500V AC / 1 minute 10A 10 12 1,000V AC / 1 minute 5A 1,000Mø min. Insulation resistance Contact resistance 2mø max. 4mø max. Solder pot inner diameter 1.7mm 1.1mm Note 1 : The contact configuration as viewed from the wiring side. Note 2 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Note 3 : Withstanding voltages indicate test voltage values. Precautions 1. Switch off the power of the circuit before disconnecting or plugging- in the connectors. 2. Use a connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely cocked position. 4. Use correct plug / receptacle to assure water protection. 9 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Product Specifications (RM21WT to RM31WT size products) Rating Voltage rating 600V AC, 840V DC (40 pos.) 500V AC, 700V DC (15, 55 pos.) 350V AC, 490V DC (20 pos.) Current rating 5A Operating temperature range (Note 1) -25ç to +85ç Storage temperature range (Note 2) -10ç to +60ç Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Characteristic Specification Conditions 1. Contact resistance 4mø max. 1A DC 2. Insulation resistance 1,000Mø min 500V DC 3. Withstanding voltage No flashover or insulation breakdown. 1,800V AC/1 minute (40 pos.) 1,500V AC/1 minute (15, 55 pos.) 1,000V AC/1 minute (20 pos.) 4. Vibration No electrical discontinuity for 10μs max. Frequency : 10 to 55 to 10Hz, single amplitude of 0.75mm, 10 cycles in 3 axis. 5. Shock No electrical discontinuity for 10μs max. Acceleration of 490m/s2, 11ms duration, sine half-wave, 3 cycles in each of the 6 axis. 6. Durability (insertion/withdrawal) 8mø max. 2,000 cycles 7. Temperature cycle Insulation resistance : 100Mø min. Temperature : -55ç ➝ Room temperature ➝ +85ç ➝ Room temperature Time : 30 ➝ 10 to 15 ➝ 30 ➝ 10 to 15 (Minutes) 5 cycles 8. Humidity Insulation resistance : 100Mø min. (Dry) 96 hours at temperature of 40ç and humidity of 90% to 95%. 9. Water protection When mated with corresponding connector. No water penetration when submerged for 48 hours at the depth of 1.8 meter. Note 1 : Includes temperature rise caused by the current flow. Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating temperature range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Materials / Finish Item Material Finish Remarks Body Brass Chrome plated or nickel plated ------------------- Insulator Diallyl phthalate resin ------------------- UL94V-0 (Color : Black) Contacts Brass, copper alloy Silver plated ------------------- Packing Chloroprene rubber or SIR ------------------- (Color : Black) Note : Do not mix different contact plating. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. RM 31 W T P* - 40 S (** ) 1 2 1 3 4 5 6 7 1 Series name : RM-W 5 Number of contacts 2 Shell size 6 Contact type P : Male contact S : Female contact 3 Lock type T : Screw Lock 4 Connector type P : Plug R : Receptacle 7 Other specifications A two-digit number is added to indicate other specifications. RM 21 W T P - CP (10) (** ) 8 8 CP: Strain relief 10 9 7 : External cable clamp 9 () with () without : Internal cable clamp Numbers : Cable size RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors D Plugs - Straight Short Back Shell Set screw E 8 RM21WTP-15P(31) 9 7 15 11 1 13 10 14 ØB ØA Y 6 12 5 2 3 Z 4 C (Representative example) Part No. RM21WTP-15S(31) RM21WTP-15P(33) RM21WTP-20S(31) RM21WTP-20P(33) RM31WTP-40P(33) HRS No. 109-1401-2 31 109-1403-8 33 109-1402-5 31 109-1404-0 33 109-1573-8 33 No. of contacts ØA ØB C E F 21 32 37.5 TM25∞2 M20∞0.75 30.8 42 52 TM35∞2 M28∞0.75 15 20 40 Weight 86g 85g 88g 85g 149g Remarks Silver plated only Applicable Strain Reliefs External cable clamp + internal, self-tightening JR16WCC-10(72) ØA ØB E Wrench opening dimension D C (Representative example) Part No. JR16WCC-4(72) JR16WCC-6(72) JR16WCC-8(72) JR16WCC-10(72) JR16WCC-11(72) JR16WCC-12(72) HRS No. 114-2052-6 72 114-2053-9 72 114-2054-1 72 114-2055-4 72 114-2154-6 72 114-2056-7 72 ØA 4 6 8 10 11 12 ØB C D E Weight Remarks 23 17.5 21 M20∞0.75 17.5g For RM21WT (No locking screw attached) Note 1 : Cable jacket diameter:Use A ± 0.2mm. Note 2 : HRS recommended tool : 1.27mm Hex Wrench Note 3 : Recommended set screw tightening torque : 0.3 to 0.4N•m. Internal, self tightening E RM21WTP-CP(8)(71) Set screw ØB ØA Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note : Recommended set screw tightening torque : 0.2 to 0.3 N•m. D C (Representative example) Part No. RM21WTP-CP(8)(71) RM21WTP-CP(10)(71) RM21WTP-CP(12)(71) RM31WTP-CP(10)(71) RM31WTP-CP(12)(71) RM31WTP-CP(14)(71) RM31WTP-CP(16)(71) RM31WTP-CP(18)(71) HRS No. 109-1405-3 71 109-1406-6 71 109-1407-9 71 109-1575-3 71 109-1576-6 71 109-1579-4 71 109-1577-9 71 109-1578-1 71 ØA 8 10 12 10 12 14 16 18 ØB C D E 23 38 7.5 M20∞0.75 Weight 22.5g 22g 21.5g Remarks For RM21WT 46g 31 42 12 M28∞0.75 45g 43.5g 42g For RM31WT Note 1 : Cable jacket diameter : Use A ± 0.2mm. Note 2 : Code cramp No. should be the same as connector shell No. Note 3 : When using the self-tightening strain relief verify the cable pull force requirements. Note 4 : Recommended set screw tightening torque : 0.2 to 0.3N•m. 11 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacles Front panel mount 2 Z 14 15 7 9 Y Y 7 9 6 14 10 13 5 10 12 1 15 1 11 13 ØA 5 12 11 4 2 4 6 Z 3 3 RM21WTR-15P(31) 8 8 C F D B E (Representative example) Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. ØA No. of contacts RM21WTR-15P(33) 109-1445-8 33 15 RM21WTR-20P(33) 109-1446-0 33 20 RM31WTR-40S(33) 109-1527-0 33 40 31 B C D 21 6.5 2.5 41 E F 23.5 TM25∞2 34 TM35∞2 Weight Remarks 28g Silver 31.5g plated only 52g Receptacle - recommended panel cut-out Front mounting, rear nut Part No. R C ØA B ØA B RC For RM21WTR 22.1 12.75 0.8 For RM31WTR 32.1 17.75 0.85 Note : Tolelance is +0.1/0. Panel thickness : 0.5 to 2mm For RM**WTR receptacles Note 1 : When attaching the receptacle to the panel, be certain to check that the gasket is in place in the groove. Do not pinch the gasket. Note 2 : The view of the above diagrams is from the receptacle mating side. Note 3 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Contact Arrangement and Specifications Shell size : 21 Contact arrangement 9 10 1 15 11 2 3 13 6 9 17 8 16 12 14 Number of contacts Withstanding voltage Current rating Insulation resistance Contact resistance Solder pot inner diameter 10 8 7 Shell size : 31 4 5 15 1,500V AC / 1 minute 7 15 6 18 19 1 11 2 12 3 20 14 18 13 4 5 20 1,000V AC / 1 minute 5A 1,000Mø min. 4mø max. 1.1mm 17 16 15 14 31 30 29 13 19 32 39 1 20 33 2 21 34 40 38 35 37 28 12 27 26 11 10 36 25 9 3 4 22 5 23 24 6 7 8 40 1,800V AC / 1 minute Note 1 : The contact configuration as viewed from the wiring side. Note 2 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Note 3 : Withstanding voltages indicate test voltage values.   Precautions 1. Switch off the power of the circuit before disconnecting or plugging- in the connectors. 2. Use a connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely locked position. 4. Use correct plug / receptacle to assure dust and water protection. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2021. Contents are subject to change without notice for the purpose of improvements.
RM15WTPZ-12P(76) 价格&库存
很抱歉,暂时无法提供与“RM15WTPZ-12P(76)”相匹配的价格&库存,您可以联系我们找货
