F-214 (Rev 19NOV14)
SL–120–G–10
SDL–125–T–12
SDL–115–G–19
(2,54 mm) .100"
SL, SDL SERIES
SL–110–T–11
LOW PROFILE MACHINED SOCKET STRIPS
FEATURES
• Achieve low profile
without sacrificing
insertion depth!
• Choice of four precision
screw machined lead
styles.
• Exceptionally low profile,
down to (2,11 mm) .083"
off of board.
• Mates with BBL or BDL
for board stacking
spaces down to
(3,89 mm) .153"
SPECIFICATIONS
Mates with:
TS, TD, HTS, BBS, BBD,
BBL, BDL, BHS
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
Note: Some lengths,
styles and options are
non-standard, non-returnable.
1
NO. PINS
PER ROW
PLATING
OPTION
LEAD
STYLE
SL
= Single Row Low Profile Socket Strip
SDL
= Double Row Low Profile Socket Strip
–G
(2,54) .100 X No. of Positions +
(0,23) .009
= 30µ" (0,76 µm)
Gold contact,
10µ" (0,25µm)
Gold shell
01
(2,54)
.100
thru
(2,54)
.100
TYP
For complete specifications
see www.samtec.com?SL or
www.samtec.com?SDL
Insulator Material:
Black Glass Filled Polyester
Contact/Shell Materials:
BeCu/Brass
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
Contact Resistance:
10 mΩ
Insertion Force:
(Single contact only)
Standard =
9 oz (2,50 N) avg.,
16 oz (4,45 N) max
((0,43 mm) .017" DIA probe)
Low Insertion Force =
2.5 oz (0,70 N) avg.,
5.5 oz (1,53 N) max
Withdrawal Force:
Standard =
1.5 oz (0,42 N) min
Low Insertion Force
= 2.0 oz (0,56 N) avg.,
0.5 oz (0,14 N) min
RoHS Compliant: Yes
Lead-Free Solderable:
Wave only
TYPE
STRIP
32
(1,27)
.050
(0,23) .009
(5,08)
.200
01
(2,54)
.100
(2,54)
.100
TYP
–T
= 30µ"(0,76 µm)
Gold contact,
Tin shell
thru
–TT
36
(1,27)
.050
= Tin contact and shell
(LIF not available)
Low Insertion Force (LIF) Available
–12
–11
–10
Low Profile
(Hollow Leg)
–19
Micro-Socket
(Hollow Leg)
Low Profile
(Standard Mount)
Micro-Socket
(Hollow Leg)
For LIF specify –39
For LIF specify –31
(1,83)
.072 DIA
(1,83)
.072 DIA
(3,10)
.122
(0,76)
.030
(5,84)
.230
(1,32)
.052
DIA
(0,76)
.030
DIA
Contact Length =
(2,11 mm) .083"
Lead DIA Accepted =
(0,38 mm) .015" to (0,51 mm) .020"
Insertion Depth =
(2,67 mm) .105" to (4,32 mm) .170"
Style 10 Component Part No. =
SC-3P1
(6,10)
.240
(2,11 mm)
Only .0 8b3o”ard
above p.c.
(1,83)
.072 DIA
(0,51)
.020
(3,35)
.132
(4,83)
.190
(1,32)
.052
DIA
(2,41)
.095
(0,51)
.020
(1,32)
.052
DIA
(4,19)
.165
(4,45)
.175
(1,32)
.052
DIA
(0,74)
.029
DIA
Micro
Socket
Contact Length =
(1,58 mm) .062"
Lead DIA Accepted =
(0,41 mm) .016" to (0,51 mm) .020"
Insertion Depth =
(1,65 mm) .065" to (3,81 mm) .150"
Style 12 Component Part No. =
SC-5P1
(0,25)
.010
(2,11)
.083
(0,76)
.030
DIA
(0,51)
.020
DIA
Contact Length =
(1,58 mm) .062"
Lead DIA Accepted =
(0,41 mm) .016" to (0,53 mm) .021"
Insertion Depth =
(2,03 mm) .080" to (2,67 mm) .105"
Style 11 Component Part No. =
SC-4P1
Style 31 Component Part No. =
EZ-4P1
(1,83)
.072 DIA
Standard
Socket
(Reference only.
Not available
with SL & SDL)
Contact Length =
(1,58 mm) .062"
Lead DIA Accepted =
Insertion Depth =
(1,65 mm) .065" to (3,56 mm) .140"
Style 19 Component Part No. =
SC-8P1
Style 39 Component Part No. =
EZ-8P1
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
