SDL-136-G-39
SDL-136-G-39
    SAMTEC(申泰)
SDL-136-G-39 数据手册
F-224 WEB SL–120–G–10 SDL–125–TT–12 SDL–115–G–19 (2.54 mm) .100" SL, SDL SERIES SL–110–TT–11 LOW PROFILE MACHINED SOCKET STRIPS FEATURES • Achieve low profile without sacrificing insertion depth! • Choice of four precision screw machined lead styles. • Exceptionally low profile, down to (2.11 mm) .083" off of board. • Mates with BBL or BDL for board stacking spaces down to (3.89 mm) .153" SPECIFICATIONS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS 1 PLATING OPTION NO. PINS PER ROW LEAD STYLE SL = Single Row Low Profile Socket Strip SDL = Double Row Low Profile Socket Strip thru (2.54) .100 (2.54) .100 TYP (1.27) .050 (2.54) .100 X No. of Positions + (0.23) .009 (5.08) .200 –G = 30 µ" (0.76 µm) Gold contact, 10 µ" (0.25 µm) Gold shell 01 (2.54) .100 X No. of Positions + (0.23) .009 For complete specifications see www.samtec.com?SL or www.samtec.com?SDL Insulator Material: Black Glass Filled Polyester (SDL) Black Liquid Crystal Polymer (SL) Contact/Shell Materials: BeCu/Brass Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin RoHS Compliant: Yes Lead-Free Solderable: SL: Yes SDL: No, Lead Wave only TYPE STRIP 32 –T = 30 µ" (0.76 µm) Gold contact, Tin shell 01 thru (2.54) .100 (1.27) .050 (2.54) .100 TYP –TT 36 = Tin contact and shell (LIF not available) Low Insertion Force (LIF) Available –10 = Low Profile (Hollow Leg) –11 –19 –12 = Low Profile (Standard Mount) For LIF specify –31 = Micro-Socket (Hollow Leg) For LIF specify –39 = Micro-Socket (Hollow Leg) RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality (1.83) .072 DIA (1.83) .072 DIA FILE NO. E111594 (5.84) .230 (3.10) .122 (0.76) .030 (1.32) .052 DIA (0.76) .030 DIA Note: Some lengths, styles and options are non-standard, non-returnable. Contact Length = (2.11 mm) .083" Lead DIA Accepted = (0.38 mm) .015" to (0.51 mm) .020" Insertion Depth = (2.67 mm) .105" to (4.32 mm) .170" Style 10 Component Part No. = SC-3P1 (6.10) .240 (1.83) .072 DIA (0.51) .020 (3.35) .132 (1.32) .052 DIA (4.83) .190 (2.41) .095 (0.51) .020 (1.32) .052 DIA (4.19) .165 (4.45) .175 (1.32) .052 DIA (0.74) .029 DIA Micro Socket Contact Length = (1.58 mm) .062" Lead DIA Accepted = (0.41 mm) .016" to (0.51 mm) .020" Insertion Depth = (1.65 mm) .065" to (3.81 mm) .150" Style 12 Component Part No. = SC-5P1 (0.25) .010 (2.11) .083 (0.76) .030 DIA (0.51) .020 DIA Contact Length = (1.58 mm) .062" Lead DIA Accepted = (0.41 mm) .016" to (0.53­mm) .021" Insertion Depth = (2.03 mm) .080" to (2.67 mm) .105" Style 11 Component Part No. = SC-4P1 Style 31 Component Part No. = EZ-4P1 (1.83) .072 DIA Standard Socket (Reference only. Not available with SL & SDL) Contact Length = (1.58 mm) .062" Lead DIA Accepted = (0.41 mm) .016" to (0.51 mm) .020" Insertion Depth = (1.65 mm) .065" to (3.56 mm) .140" Style 19 Component Part No. = SC-8P1 Style 39 Component Part No. = EZ-8P1 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SDL-136-G-39 价格&库存
很抱歉,暂时无法提供与“SDL-136-G-39”相匹配的价格&库存,您可以联系我们找货
