CC03L-2830-01-G
CC03L-2830-01-G
    SAMTEC(申泰)
CC03L-2830-01-G 数据手册
F-215 ISDF–07–D–M ™ SYSTEM ISDF–10–D–S (1,27 mm) .050" CC03R–2830–01–G ISDF, CC03R, CC03M, TFM SERIES DISCRETE WIRE COMPONENTS & TOOLING SPECIFICATIONS For complete specifications see www.samtec.com?ISDF, www.samtec.com?CC03R or www.samtec.com?CC03M RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TOOLING • Hand tool: CAT-HT-203-2830-12 • Clamp for mounting hand tool to work table: CAT-HT-MNT-01 TYPE ISDF = Housing Insulator Material: Black LCP (1,27) .050 POSITIONS PER ROW –03, –04, –05, –07, –10, –15, –20, –25, –40, –50 OPTION = Double Row –S (5,08) .200 = Screw Down (–D only) –S (2,03) .080 –D –M NO. PINS PER ROW PLATING = Gold flash on contact –G = 10µ" (0,25 µm) Gold on contact ™ (0,38) .015 (1,27) .050 DIA (15,37) .605 (1,78) .070 Note: Some lengths, styles and options are non-standard, non-returnable. 1 = 28 to 30 AWG = Contact, Mini Reel (5,000 Parts per Reel) (3,68) .145 (6,32) .249 TFM –2830 = Contact, Full Reel (35,000 Parts per Reel) (2,00) .079 DIA (1,27) .050 (2,03) .080 (1,27) .050 CC03R CC03M (11,18) .440 (6,35) .250 01 –GF = Metal Retention Latch –D No. of Positions x (1,27) .050 + (0,38) .015 WIRE GAUGE TYPE –M –S = Single Row (Standard sizes) • Mini Applicator: CAT-MA-203-2830-XX-01 Mates with: SFSD(T), SFSS(T) ROW OPTION (3,81) .150 (1,91) .075 –S LEAD STYLE (3,81) .150 PLATING OPTION Contact Material: BeCu ROW OPTION OPTION SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?TFM 03, 04, 05, 07, 10, 15, 20, 25, 40, 50 Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: OTHER Au or Sn over 50µ" (1,27 µm) Ni SOLUTIONS Voltage Rating: 250 VAC mated with SFM • Many other options Operating Temp Range: available. See TFM, -55°C to +125°C TFML, TFC Series RoHS Compliant: Yes Processing: RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FILE NO: 090871_0_000 –L –S = 15µ" (0,38 µm) Gold on post, Matte Tin on tail = Single Row –02 (1,27) .050 x No. of Positions + (3,18) .125 (4,45) .175 = Double Row (2,79) .110 01 02 (See website for –DS & –WT OAL) –REX = (1,27) .050 x No. of Positions + (6,68) .263 (1,27) .050 (5,72) .225 (0,46) .018 DIA –DS –D = Surface Mount or contact Samtec. Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (05-25) (0,15 mm) .006" max (30-50) –01 = Through-hole –WT –WT 01 (1,27) .050 (5,59) .220 (1,97) .078 (2,35) .093 (0,64) .025 (5,72) .225 (0,36) .014 SURFACE MOUNT (3,81) .150 –DS THROUGH-HOLE WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. = Dual Screw Down for (1,60 mm) .062" PCB (05, 07, 10, 15, 20, 25, 40 positions only) (Requires –D row option) (Mates with SFSD/SFSDT –SS and –DS option only) (1,99) .079 = Weld Tab (Mates to SFSS/SFSD –SR and –DR option only) (05, 07, 10, 15, 20, 25, 40, 50 positions only)
CC03L-2830-01-G 价格&库存
很抱歉,暂时无法提供与“CC03L-2830-01-G”相匹配的价格&库存,您可以联系我们找货
