CES-139-01-G-S
CES-139-01-G-S
    SAMTEC(申泰)
    LOW PROFILE .025" SQUARE STRIPS
CES-139-01-G-S 数据手册
F-215 SLW–110–01–T–D CES–125–02–L–D SLW–120–01–G–S CES–115–01–T–S (2,54 mm) .100" SLW, CES SERIES LOW PROFILE SOCKET STRIPS SPECIFICATIONS For complete specifications see www.samtec.com?SLW or www.samtec.com?CES Insulator Material: Black G.F. Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ"(1,27 µm) Ni SLW Current Rating (SLW/TSW): 5.2 A per pin (1 pin powered per row) CES Current Rating (TSW/CES): 5.5 A per pin (1 pin powered per row) Voltage Rating: SLW: 406 VAC CES: 400 VAC Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Contact Resistance: 10 mΩ Insertion Depth: SLW: (2,16 mm) .085" to (2,92 mm) .115" CES: (2,62 mm) .103" to (4,06 mm) .160" Insertion Force: SLW: (Single contact only) (3,34 N) 12 oz avg. (0,64 mm) .025" SQ pin CES: (Single contact only) (2,22 N) 8 oz avg. (0,64 mm) .025" SQ pin Withdrawal Force: SLW: (Single contact only) (1,67 N) 6 oz avg. (0,64 mm) .025" SQ pin CES:(Single contact only) (1,11 N) 4 oz avg. (0,64 mm) .025" SQ pin RoHS Compliant: Yes Lead-Free Solderable: Wave only RECOGNITIONS NO. PINS PER ROW 1 SLW PLATING OPTION 01 ROW OPTION Mates with: TLW, TSW, MTLW, MTSW, HW, EW, ZW, HTSW, HMTSW, TSM –S = Single Row –F 01 thru 50 –D = Gold flash on contact, Matte Tin on tail = Double Row (2,54) .100 X No. of Positions 01 02 –L (2,54) .100 = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (2,54) .100 TYP 02 –G (2,54) (4,95) .100 .195 = 20µ" (0,51 µm) Gold on contact, Gold flash on balance 01 –T (4,57) .180 = Matte Tin (2,92) .115 (0,64) .025 (2,54) .100 1 CES (0,41) .016 NO. PINS PER ROW Mates with: TLW, TSW, MTLW, MTSW, HW, EW, ZW, DW, HTSW, PHT, HMTSW For complete scope of recognitions see www.samtec.com/quality LEAD STYLE – 01 01 thru 50 –L = (3,25 mm) .128 “A” Dim. = 10µ" (0,25 µm) Gold contact, Matte Tin on tail – 02 = (5,66 mm) –T .223 “A” Dim. (2,54) .100 X No. of Positions PLATING OPTION = Matte Tin ROW OPTION –S – RA = Single Row = Right Angle version –D Style – 02 only Single Row only = Double Row (3,05) .120 01 02 (3,05) .120 FILE NO: 090871_0_000 (CES ONLY) (2,54) .100 TYP ALSO AVAILABLE (0,71) .028 SQ 02 (MOQ Required) • Other platings Contact Samtec. (1,02) .040 A (2,54) (5,59) .100 .220 Chamfered (0,25) .010 Dual leaf folded contact 01 (5,08) .200 Note: Some lengths, styles and options are non-standard, non-returnable. (0,51) .020 (0,64) .025 RA OPTION (2,54) .100 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Closed bottom contact
CES-139-01-G-S 价格&库存
很抱歉,暂时无法提供与“CES-139-01-G-S”相匹配的价格&库存,您可以联系我们找货
