07MQ-ST
07MQ-ST
    JST
    插件,P=2mm
    板对板连接器 直插 针脚数:7Pin 间距:2mm 排数:1
07MQ-ST 数据手册
MQ CONNECTOR 2.0mm pitch/Board-to-board connectors Specifications ––––––––––––––––––– • Current rating: 1.0A AC, DC • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10m Ω max. After environmental testing/ 20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable PC board thickness: 1.2 to 1.6mm Measuring 2.0mm in pitch, 9.2mm in mounting height and 5.5mm in thickness, this board-to-board connector makes highdensity mounting of components in electronic products possible. It is ideal for small electronic products, such as portable VCRs and video cameras, which require high-density mounting and high reliability. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– • Back-up support spring construction • Easy insertion • Board retention feature 0 1 Certified LR20812 Top entry type Low insertion force type Top entry type 9.2 9.2 3min 0.95 1.2∼1.6 0.95 1.2∼1.6 2.4min; (Low insertion force type) 2 min; (Standard type) 2 ±0.05 Recognized E60389 1.2∼1.6 1.2∼1.6 φ0.75 ±0.05 5.5 Side entry type 5.5 2 min Low insertion force type 6 Side entry type 3.5 9.2 9.2 4 ±0.05 3max 2 ±0.05 1.2∼1.6 6 1.2∼1.6 φ0.75 ±0.05 3.5 Note: 1. The above figure is the figure viewed from soldering side. 2. The PC board layout of the header is identical to that of the top entry receptacle. 3. Tolerances are non-cumulative: ±0.05mm for all centers. 4. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 MQ CONNECTOR Receptacle Top entry type 6.2 Circuits 5 6 4.15 7 2 8 2.55 2 9 5.5 A B 10 12 3.2 Q'ty / box Top entry Side entry type type 8.0 12.0 500 500 10.0 14.0 500 500 12.0 16.0 500 500 14.0 18.0 500 250 16.0 20.0 500 250 18.0 22.0 250 250 22.0 26.0 250 250 Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural RoHS compliance 4 1.7 6.2 2 A B Dimensions (mm) A B Material and Finish 5.5 Side entry type Model No. Top entry type Side entry type 05MQ-BT 05MQ-ST 06MQ-BT 06MQ-ST 07MQ-BT 07MQ-ST 08MQ-BT 08MQ-ST 09MQ-BT 09MQ-ST 10MQ-BT 10MQ-ST 12MQ-BT 12MQ-ST 2 Shrouded header B5P-MQ B6P-MQ B7P-MQ B8P-MQ B9P-MQ B10P-MQ B12P-MQ 4.5 5 6 3 Model No. 8 3.2 Circuits 10 7 9 12 φ0.6 2 Dimensions (mm) A B Q'ty / box 8.0 12.0 500 10.0 14.0 500 12.0 16.0 500 14.0 18.0 500 16.0 20.0 500 18.0 22.0 250 22.0 26.0 200 3.5 2 A Material and Finish 5.5 Pin: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural B RoHS compliance This product displays (LF)(SN) on a label. Low insertion force type Receptacle Top entry type 6.2 Circuits 4 4.15 5 2 9 5.5 A B 7 8 2.55 2 6 10 12 3.2 5.5 Side entry type Model No. Top entry type Side entry type 04MQ-BT-L 04MQ-ST-L 05MQ-BT-L 05MQ-ST-L 06MQ-BT-L 06MQ-ST-L 07MQ-BT-L 07MQ-ST-L 08MQ-BT-L 08MQ-ST-L 09MQ-BT-L 09MQ-ST-L 10MQ-BT-L 10MQ-ST-L 12MQ-BT-L 12MQ-ST-L Q'ty / box Top entry Side entry type type 6.0 10.0 500 500 8.0 12.0 500 500 10.0 14.0 500 500 12.0 16.0 500 500 14.0 18.0 500 250 16.0 20.0 500 250 18.0 22.0 250 250 22.0 26.0 250 250 Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0 RoHS compliance 4 1.7 6.2 2 2 Dimensions (mm) A B A B Low insertion force type Shrouded header Circuits 6 4 9.2 5 6 7 3.2 8 9 10 φ0.6 2 2.4 3.4 12 Model No.       B4P-MQ-C       B5P-MQ-C       B6P-MQ-C       B7P-MQ-C       B8P-MQ-C       B9P-MQ-C B10P-MQ-C B12P-MQ-C Dimensions (mm) A B 10.8 500 8.0 12.8 500 10.0 14.8 500 12.0 16.8 250 14.0 18.8 250 16.0 20.8 250 18.0 22.8 250 22.0 26.8 200 A B Material and Finish Pin: Brass, copper-undercoated, tin-plated (reflow trreatment) Wafer: PA 66, UL94V-0 2 Q'ty / box 6.0 RoHS compliance This product displays (LF)(SN) on a label.
07MQ-ST 价格&库存
很抱歉,暂时无法提供与“07MQ-ST”相匹配的价格&库存,您可以联系我们找货
07MQ-ST
    • 1+3.112431+0.40454
    • 10+2.5647210+0.33335
    • 50+2.0256950+0.26329
    • 100+1.66055100+0.21583
    • 500+1.59099500+0.20679
    • 1000+1.538831000+0.20001
    • 2000+1.512752000+0.19662
    库存:408
    07MQ-ST
      • 500+1.05920
      库存:8500
