09 06 000 8482
09 06 000 8482
    HARTING(浩亭)
    GDS A-F/FC FEMALE CRIMP C
09 06 000 8482 数据手册
DIN 41 612 · Type D Number of contacts max. 32 Female connectors Number Identification of contacts Part No. Drawing Dimensions in mm Female connector for crimp contacts DIN Power up to 6 A Order contacts separately 32 09 04 032 3213f) 32 09 04 532 3213c)f) Shell housing 09 03 096 0501 see chapter 20 Part No. Performance levels according to IEC 60603-2. Explanation chapter 00 Identification 1 Identification Wire gauge 2 Female crimp FC contacts Bandoliered contacts (approx. 2,500 pieces) 1 2 3 09 06 000 6484 09 06 000 6481 09 06 000 6482 09 06 000 6474 09 06 000 6471 09 06 000 6472 Bandoliered contacts (approx. 250 pieces) 1 2 3 09 06 000 7484 09 06 000 7481 09 06 000 7482 09 06 000 7474 09 06 000 7471 09 06 000 7472 Individual contacts1) 1 2 3 09 06 000 8484 09 06 000 8481 09 06 000 8482 09 06 000 8474 09 06 000 8471 09 06 000 8472 Female contacts with solder lugs2) (lockable) FC 1 FC 2 FC 3 09 06 000 6420 Wire gauge Insulation ø mm² AWG mm 0.09 - 0.25 0.14 - 0.56 0.5 - 1.5 1 2 3 28 - 24 26 - 20 20 - 16 0.7 - 1.5 0.8 - 2.0 1.6 - 2.8 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped For the fabrication in line with the specification please use exclusively crimp tools approved by HARTING (see DIN EN 60 352-2) Insertion, removal and crimping tools see chapter 30 03 . 14 Identification Bandoliered contacts Individual contacts Packaging unit 1,000 pieces Solder contacts must not be used together with shell housing A. Special contact surface: 2 µm gold. c) Connectors with coding see chapter 00 f) Railway classification NFF 16-101, Smoke index: F1, Flammability class: I2 1) 2)
09 06 000 8482 价格&库存
很抱歉,暂时无法提供与“09 06 000 8482”相匹配的价格&库存,您可以联系我们找货
  • 1+5.57815
  • 10+4.75646
  • 25+4.42587
  • 50+4.17433
  • 100+3.95274
  • 250+3.73115
  • 500+3.57424
  • 1000+3.42691
  • 3000+3.21370
  • 5000+3.12147
库存:5055
09060008482
    • 1+2.46240
    • 10+2.40840
    • 30+2.36520
    库存:36
    09060008482
      • 1+7.322511+0.94852
