09 12 021 3001
09 12 021 3001
    HARTING(浩亭)
    HARTING - 09 12 021 3001 - Heavy Duty Connector, Less Contacts, Han Q High Density, Insert, 21 Conta...
09 12 021 3001 数据手册
Han® Q High Density Size 3 A ~50 V / ‒120 V 6.5  A Number of contacts 21 Part number Identification Male insert (M) Female insert (F) Drawing Dimensions in mm Crimp terminal Order crimp contacts separately M 09 12 021 3001 09 12 021 3101 F Identification Part number Drawing Dimensions in mm Insertion / removel tool for D-Sub crimp contacts 09 99 000 0368 Han® Data Sheet 0730 Han® Q High Density Features Technical characteristics Inserts • Heavy duty connector for D-Sub signal contacts Number of contacts Electrical data acc. to EN 61 984 Rated current Rated voltage AC Rated voltage DC Rated impulse voltage Pollution degree • Suitable for all Han® 3 A hoods/housing types: Standard (metal, plastic), EMC, INOX, M and HPR • High contact density at small foot print • Easy handling of signal connectors in industrial environment Insulation resistance Material Limiting temperatures Mechanical working life - mating cycles • One preleading contact 21 6.5 A ~50 V / ‒120 V 0.8 kV 3 6.5 A ~50 V ‒120 V 0.8 kV 3 ≥ 1010 Ω polycarbonate -40 °C ... 125 °C according to performance level of used contacts   Contacts Current Carrying Capacity The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly, without exceeding the allowed maximum temperature. Measuring and testing techniques according to DIN EN 60 512-5 Operating current (A)   Material Surface - selectively gold plated Crimp termination - mm² - AWG ① wire gauge: 0.14 mm² ② wire gauge: 0.25 mm² ③ wire gauge: 0.5 mm² stamped contacts stamped contacts turned contacts according to performance level 0.09 mm² ... 0.56 mm² 28 ... 20   Hoods/Housings Detailed information and further hoods/housings types see catalog "Industrial Connectors Han®", chapter 31 Plastic hoods/housings Material Flammability acc. to UL 94 Degree of protection acc. to DIN EN 60 529 for coupled connector Metal hoods/housings Material Degree of protection acc. to DIN EN 60 529 for coupled connector Ambient temperature (°C) copper alloy polycarbonate V0 IP 67 zinc die-cast IP 44 IP 67 is achieved with seal screw 09 20 000 9918 ® Han Q High Density Contacts Contacts Identification Wire gauge Part number (mm²) Male contact Female contact Drawing Dimensions in mm Individual contacts, turned Performance level 1 0.09-0.25 0.13-0.33 0.25-0.52 09 67 000 7576 09 67 000 5576 09 67 000 8576 09 67 000 7476 09 67 000 5476 09 67 000 8476 0.09-0.25 0.25-0.56 09 67 000 7176 09 67 000 8176 09 67 000 7276 09 67 000 8276 Wire gauge 0.09-0.25 mm² 0.13-0.33 mm² 0.25-0.52 mm² AWG 28-24 AWG 26-22 AWG 24-20 Ø* Stripping length 1.7 1.7 1.7 4 mm 4 mm 4 mm Ø* Stripping length 1.02 1.52 2.5 mm + 0.5 2.5 mm + 0.5 Ø* Stripping length 1.02 1.52 2.5 mm + 0.5 2.5 mm + 0.5 Ø* Stripping length 1.02 1.52 2.5 mm + 0.5 2.5 mm + 0.5 Individual contacts, stamped Performance level 1 Wire gauge 0.09-0.25 mm² 0.25-0.56 mm² AWG 28-24 AWG 24-20 500 pieces/reel Performance level 1 Unrolling left 0.09-0.25 0.25-0.56 09 67 000 7166 09 67 000 8166 09 67 000 7266 09 67 000 8266 Wire gauge 0.09-0.25 mm² 0.25-0.56 mm² AWG 28-24 AWG 24-20 10,000 pieces/reel Performance level 1 Unrolling left 0.09-0.25 0.25-0.56 09 67 000 7156 09 67 000 8156 09 67 000 7256 09 67 000 8256 Wire gauge 0.09-0.25 mm² 0.25-0.56 mm² AWG 28-24 AWG 24-20 HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Phone: +49 5772 47-97100 | Fax: +49 5772 47-495 Internet: www.HARTING.com | E-Mail: electric@HARTING.com *) Ø = max. isolation diameter 2012-11-12
09 12 021 3001 价格&库存
很抱歉,暂时无法提供与“09 12 021 3001”相匹配的价格&库存,您可以联系我们找货
  • 1+153.900621+19.97349
  • 10+130.7888410+16.97401
  • 30+121.0294230+15.70741
  • 50+116.7445850+15.15132
  • 100+111.17383100+14.42834
  • 250+104.21965250+13.52581
  • 500+99.25055500+12.88091
库存:30
09120213001
  • 1+76.13557
  • 3+72.32410
  • 5+70.87658
库存:2
09120213001
    库存:100
