09 45 145 1560
09 45 145 1560
    HARTING(浩亭)
    HARTING - 09 45 145 1560 - Modular Connector, RJ45 Plug, 1 x 1 (Port), 8P8C, Cat6, IP65, IP67, Cable...
09 45 145 1560 数据手册
PushPull HARTING PushPull RJ45 HARTING PushPull Technology acc. to IEC 61 076-3-106 variant 4 RJ45-connector Advantages Technical characteristics l Ethernet connector based on RJ45 Locking PushPull Technology acc. to IEC 61 076-3-106 variant 4 l Fully shielded, 360° shielding contact Mating face RJ45 acc. to IEC 60 603-7 l Field-assembly connector with IDC contacts Cable diameter 4.9 ... 8.6 mm  ategory of transmission: Cat. 6 / class EA suitable C for 1/10 Gbit Ethernet Termination cross section AWG 27/7 ... AWG 22/7 (stranded) AWG 24/1 ... AWG 22/1 (solid) l Conductor diameter max. 1.6 mm (incl. insulation) Mating cycles min. 750 Degree of protection IP65 / IP67 Temperature range -40 °C … +70 °C Housing material Plastic, black Zinc die-cast, shining Flammability acc. to UL 94 V0 Identification Connector, 8-poles Cat. 6 incl. housing with RJ45 connector, shielding and cable gland Part number 09 45 145 1560 09 45 145 1560 XL1) 09 45 195 1560 (metal version) Colour clips for colour coding the HARTING PushPull connectors White Yellow Red Blue Green 02 10 1) Packaging with 100 sets 09 45 840 0011 09 45 840 0013 09 45 840 0017 09 45 840 0018 09 45 840 0019 Drawing UL approval (E102079) Dimensions in mm
09 45 145 1560 价格&库存
很抱歉,暂时无法提供与“09 45 145 1560”相匹配的价格&库存,您可以联系我们找货
