09 45 245 1102
09 45 245 1102
    HARTING(浩亭)
    HARTING - 09 45 245 1102 - Modular Connector, RJ45 Plug, 1 x 1 (Port), 8P4C, Cat5, IP65, IP67, Cable...
09 45 245 1102 数据手册
PushPull HARTING PushPull RJ45 HARTING PushPull Technology acc. to IEC 61 076-3-106 variant 4 RJ45-panel feed-throughs and accessories Advantages l l l Technical characteristics  mall, space-saving PushPull Interfaces S in IP 65 / IP 67 Locking PushPull Technology acc. to IEC 61 076-3-106 variant 4  asy handling of RJ45 patch cords in switch E ­cabinets or sets Mounting to casings Transmission rate cat. 5 versions 10/100/1000 Mbit/s Transmission rate cat. 6 versions 10/100 Mbit/s / 1/10 Gbit/s Shielding fully shielded, 360° shielding contact Mating cycles min. 750 Degree of protection IP 65 / IP 67 Temperature range -40 °C … +70 °C Housing material Plastic, black Zinc die-cast, shining Flammability acc. to UL 94 V0 Identification Part No. Panel feed-through set category of transmission Cat. 5 incl. housing bulkhead mounting EasyInstall with integrated seal, 2 x RJ45-jack board drillings for M3 09 45 245 1130 09 45 295 1130 (metal version) incl. housing bulkhead mounting Compact, ­flat seal, 2 x RJ45-jack board drillings for M2.5 09 45 245 1102 Panel feed-through set category of transmission Cat. 6 incl. housing bulkhead mounting EasyInstall with integrated seal, 2 x RJ45-jack board drillings for M3 09 45 245 1590 incl. housing bulkhead mounting Compact, ­with integrated seal, 2 x RJ45-jack 09 45 245 1560 02 06 Panel cut outs see page 02.04 Drawing UL approval (E102079) Dimensions in mm
09 45 245 1102 价格&库存
很抱歉,暂时无法提供与“09 45 245 1102”相匹配的价格&库存,您可以联系我们找货
  • 10+125.0448810+16.19769
