09 45 851 0000
09 45 851 0000
    HARTING(浩亭)
    HARTING - 09 45 851 0000 - Connector Accessory, RJ Industrial DIN Rail Outlet, RJ45 Keystone Jack Co...
09 45 851 0000 数据手册
HARTING Ethernet cabling – Ha-VIS preLink® HARTING Cabinet Outlet RJ45, 8-poles RJ45 distribution module for IP20 environments (top-hat rail mounting) Advantages Technical characteristics •  Simple mountng Number of ports, Copper / Termination 1 / RJ45 (Twisted Pair) Transmission performance Category 6A / Class EA up to 250 MHz acc. to ISO/IEC 11 801:2002, EN 50 173-1 •  Dust protection caps •  Port identification Transmission rate 10/100 Mbit/s and 1/10 Gbit/s Mounting To 35 mm top-hat mounting rail acc. to DIN EN 60 715, alignable •  Angled output Dimensions (H x W x D) 71 x 18 x 68 mm Degree of protection IP20 Operating temperature range –20 °C … +70 °C Housing material Polyamide, UL94 V-0 Colour Grey Part No. HARTING RJ Industrial ® Cabinet Outlet RJ45 09 45 851 0000 Protection cover set for 09 45 851 0000 09 45 851 0001 Usable RJ45 cable jacks • Ha-VIS preLink ® keystone set AWG 22/23 (with Ha-VIS preLink ® terminal block) • Ha-VIS preLink ® keystone set (without Ha-VIS preLink ® terminal block) 20 82 501 0001 Usable with Ha-VIS preLink ® terminal blocks • Ha-VIS preLink ® terminal block AWG 22/23 (24) • Ha-VIS preLink ® terminal block AWG 26/27 20 82 000 0001 Usable RJ45 cable jacks • RJ45 keystone module IDC AWG 24 – AWG 22 • RJ45 keystone module IDC AWG 27 – AWG 26 09 45 545 1564 Drawing Dimensions in mm Ha-VIS preLink® Identification 20 82 500 0001 20 82 500 0003 09 45 545 1563 02 67
09 45 851 0000 价格&库存
很抱歉,暂时无法提供与“09 45 851 0000”相匹配的价格&库存,您可以联系我们找货
  • 1+65.96125
  • 15+62.67048
库存:24
09458510000
  • 1+118.674531+15.42731
