09340032601
09340032601
    HARTING(浩亭)
    INSERT MALE 3+2POS+1GND SCREW
09340032601 数据手册
Han® 3 Hv E/ES Size 10 B 830 V 16 A Number of contacts 3 + + 2 additional contacts for safe high voltage connections Han Hv E Identification Series Cage clamp terminal Han® Hv ES 1-3 Part number Male insert (M) Female insert (F) 09 34 003 2616 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 003 2716 Cage clamp terminal Screw terminal Crimp terminal 1) Han Hv E® 1-3 Dimensions in mm " not plug compatible to screw/crimp terminal Screw terminal Drawing a 18,4 b 33,4 c 18,4 d 35,6 18,5 33,5 18 34,5 Distance for contact max. 21 mm Contact arrangement (view from termination side) Han® 3 Hv ES 09 34 003 2601 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 003 2701 " Han® 3 Hv E Crimp terminal Han Hv E® 1-3 09 34 003 2602 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 003 2702 " ● Working contact ◐ Relay contact ○ Without contact Panel cut out for inserts for use without hoods/ housings Order crimp contacts separately (see page 04.16) 04 . 04 Crimp terminal and cage clamp terminal could also be used with 10 B standard hood/housing Stock items in bold type
09340032601 价格&库存
很抱歉,暂时无法提供与“09340032601”相匹配的价格&库存,您可以联系我们找货
  • 1+256.264081+32.13601
  • 10+217.8212910+27.31521
  • 25+204.1819225+25.60481
  • 50+194.4413850+24.38333
  • 100+185.16669100+23.22026
  • 250+173.58682250+21.76812
  • 500+166.24419500+20.84734
库存:22
09340032601
    • 1+130.78738
    • 100+124.24749
    • 500+119.28009
    库存:6
    09340032601
    • 1+183.315381+22.98810
    • 4+180.836954+22.67730
    • 15+178.5355515+22.38870
    • 30+177.2963330+22.23330
    • 75+174.5523575+21.88920
