09661636813
09661636813
    HARTING(浩亭)
    弯插
09661636813 数据手册
Product data sheet 09 66 163 6813 DSUB SV MA SSDP ANG73-284 09P AU2 DSUB SV MA SSDP ANG73-284 09P AU2 Part number 09 66 163 6813 Specification DSUB SV MA SSDP ANG73-284 09P AU2 HARTING eCatalogue https://b2b.harting.com/09661636813 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series D-Sub Identification Standard Element Connector Description of the contact Turned Angled Version Termination method Wave soldering termination Gender Male Size D-Sub 1 Connection type Motherboard to daughtercard Number of contacts 9 further contacts With grounding pin Termination length 3 mm PCB fixing With board locks Locking type Fixing flange with fitted screw lock 4-40 UNC Technical characteristics Distance between rows 2.84 mm Contact spacing (termination side) 2.74 mm Rated current 7.5 A Clearance distance ≥1 mm Page 1 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 09 66 163 6813 DSUB SV MA SSDP ANG73-284 09P AU2 Technical characteristics Creepage distance ≥1 mm Insulation resistance >1010 Ω Contact resistance ≤10 mΩ Tightening torque ≤0.4 Nm Locking screw Limiting temperature -55 ... +125 °C Insertion force ≤30 N Withdrawal force ≥3.3 N ≤20 N Performance level 2 acc. to CECC 75301-802 Mating cycles ≥250 Test voltage Ur.m.s. 1 kV Isolation group IIIa (175 ≤ CTI < 400) PCB thickness ≥1.6 mm Installation height 7.3 mm Hot plugging No Material properties Material (insert) Thermoplastic resin, glass-fibre filled (PBTP) Shell: Plated steel Colour (insert) Black Material (contacts) Copper alloy Surface (contacts) Noble metal over Ni Material flammability class acc. to UL 94 V-0 RoHS compliant with exemption RoHS exemptions 6(c): Copper alloy containing up to 4 % lead by weight ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances Not contained REACH ANNEX XIV substances Not contained REACH SVHC substances Yes REACH SVHC substances Lead ECHA SCIP number ecef7555-f643-4ceb-a337-fc54762297f1 California Proposition 65 substances Yes Page 2 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 09 66 163 6813 DSUB SV MA SSDP ANG73-284 09P AU2 Material properties California Proposition 65 substances Antimony trioxide Lead Nickel Fire protection on railway vehicles EN 45545-2 (2020-08) Requirement set with Hazard Levels R26 Specifications and approvals Specifications DIN 41652 UL / CSA UL 1977 ECBT2.E102079 Commercial data Packaging size 100 Net weight 9.8 g Country of origin China European customs tariff number 85366990 GTIN 5713140081512 ETIM EC001136 eCl@ss 27440214 D-Sub coupler Page 3 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
09661636813 价格&库存
很抱歉,暂时无法提供与“09661636813”相匹配的价格&库存,您可以联系我们找货
  • 1+71.339391+9.22966
  • 10+60.6042810+7.84078
  • 25+56.8034325+7.34904
  • 50+54.0898850+6.99797
  • 100+51.50866100+6.66402
  • 300+47.66755300+6.16707
  • 500+45.98141500+5.94893
  • 1000+43.789191000+5.66530
库存:81
