Product data sheet
09 67 050 4754
DSUB SV FE TSDP STR 50P AU3
Part number
09 67 050 4754
Specification
HARTING eCatalogue
https://b2b.harting.com/09670504754
Image is for illustration purposes only. Please refer to product description.
Identification
Category
Connectors
Series
D-Sub
Identification
Standard
Element
Connector
Description of the contact
Turned
Straight
Version
Termination method
Wave soldering termination
Gender
Female
Size
D-Sub 5
Connection type
Motherboard to daughtercard
Mezzanine
Number of contacts
50
Termination length
5.8 mm
PCB fixing
Without board locks
Locking type
Fixing flange with feed through hole Ø 3.1 mm
Technical characteristics
Distance between rows
2.84 mm
Contact spacing (termination side)
2.76 mm
Flange height
6.5 mm
Rated current
7.5 A
Clearance distance
≥1 mm
Page 1 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality,
conformity with applicable laws and directives, as well as for the electrical safety in the particular application.
HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany
Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
Product data sheet
09 67 050 4754
Creepage distance
≥1 mm
Insulation resistance
>1010 Ω
Contact resistance
≤10 mΩ
Limiting temperature
-55 ... +125 °C
Insertion force
≤167 N
Withdrawal force
≥14.5 N
≤111 N
Performance level
3
Mating cycles
≥50
Test voltage Ur.m.s.
1 kV
Isolation group
IIIa (175 ≤ CTI < 400)
PCB thickness
≥1.6 mm
Installation height
5.4 mm
Hot plugging
No
Material properties
Material (insert)
Thermoplastic resin, glass-fibre filled (PBTP)
Shell: steel, tin plated
Colour (insert)
White
Material (contacts)
Copper alloy
Surface (contacts)
Noble metal over Ni
Material flammability class acc. to UL 94
V-0
RoHS
compliant with exemption
RoHS exemptions
6(c): Copper alloy containing up to 4 % lead by weight
ELV status
China RoHS
50
REACH Annex XVII substances
Not contained
REACH ANNEX XIV substances
Not contained
REACH SVHC substances
Yes
Lead
ECHA SCIP number
ecef7555-f643-4ceb-a337-fc54762297f1
California Proposition 65 substances
Yes
Antimony trioxide
Lead
Nickel
Page 2 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
09 67 050 4754
Material properties
Fire protection on railway vehicles
EN 45545-2 (2020-08)
Requirement set with Hazard Levels
R26
Specifications and approvals
Specifications
DIN 41652
UL / CSA
UL 1977 ECBT2.E102079
Commercial data
Packaging size
25
Net weight
21 g
Country of origin
Germany
European customs tariff number
85366990
GTIN
5713140093676
ETIM
EC001136
eCl@ss
27440214 D-Sub coupler
Page 3 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the
很抱歉,暂时无法提供与“09670504754”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+151.23599
- 100+148.21077
- 500+145.24700
- 国内价格
- 1+147.36621
- 13+140.00363
- 25+137.20231
- 国内价格 香港价格
- 1+174.334341+22.55480
- 25+141.7558325+18.33990
- 50+136.8646950+17.70710
- 国内价格
- 1+161.89465
- 25+131.67415
- 50+127.11054
