Tools
Contents
Page
Tools for contacts Han D ® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.02
Tools for contacts Han E ® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.04
Tools for contacts Han ® C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.06
Tools for other contacts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.08
Tools for FOC contacts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.10
Tools for Han ® high current contacts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.12
Summary Han ® Crimping tools . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.14
Crimping machine TK . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.16
Crimping machine TC-C01 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
99.18
Tools
99
01
Tools for contacts Han D® (09 15 ...)
Identification
Part number
Drawing
Dimensions in mm
HARTING Service crimping tool
with locator
set for Han D®, Han E®
09 99 000 0021
Wire gauge Han D®
0.14 ... 1.5 mm²
09 99 000 0001
Wire gauge
0.14 ... 2.5 mm²
BUCHANAN crimping tool
Locator Han D®
09 99 000 0311
Wire gauge
Multiple crimping tool
depth adjustment gauge
09 99 000 0379
0.14
0.25
0.37
0.5 ... 1.0
1.5
2.5
mm²
mm²
mm²
mm²
mm²
mm²
Ø
Ø
Ø
Ø
Ø
Ø
1.001)
1.001)
1.30
1.55
1.80
1.55
HARTING crimping tool
with locator
for Han D®, Han E®, Han® C
HARTING Pneumatic crimping tool
CP 600
09 99 000 0110
Wire gauge Han D®
0.14 ... 1.5 mm²
09 99 000 0810
Crimp die Han D®, Han E®, Han® C
09 99 000 0813
Footswitch
09 99 000 0811
Table fixing
09 99 000 0812
Wire gauge Han D®
0.14 ... 1.5 mm²
Tools
99
02
1)For
wire gauge 0.14 and 0.25 mm² use only male contact 09 15 000 6107 or female contact 09 15 000 6207.
Stock items in bold type
Identification
Part number
Drawing
Dimensions in mm
Insertion tool for crimp contacts
09 99 000 0059
For crimp contacts with wires of less than 0.75 mm² it is recommended that an insertion tool is used. Contacts should be
inserted from the wiring side and pushed down until a positive
locking is achieved.
Removal tool for crimp contacts
Removal tool
09 99 000 0012
Replacement-tip for removal tool
09 99 000 0004
Removal tool
09 99 000 0052
A removal tool is necessary if contacts are to be replaced in the
insert. It is inserted from the mating face and pushed over the
contact until a stop is noticeable. Additional pressure unlocks the
contact and pushes it out of the wiring side. In case of the removal tool (. . 0052) the unlocking process is achieved by pressure
on the central rod.
Tools
99
03
Tools for contacts Han E® (09 33 ...)
Identification
Part number
Drawing
Dimensions in mm
with locator
09 99 000 0021
Wire gauge Han E®
0.5 ... 2.5 mm²
09 99 000 0001
Wire gauge
0.14 ... 4 mm²
Locator Han E®
09 99 000 0310
Wire gauge
09 99 000 0379
0.14 ... 0.37
0.5 ... 1.0
1.5 ... 2.5
3.0 ... 4.0
mm²
mm²
mm²
mm²
Ø
Ø
Ø
Ø
1.00
1.55
1.80
2.00
with locator
CP 600
09 99 000 0110
Wire gauge Han E®
0.5 ... 4 mm²
09 99 000 0810
09 99 000 0813
Footswitch
09 99 000 0811
Table fixing
09 99 000 0812
Wire gauge Han E®
0.5 ... 4 mm²
Tools
99
04
Identification
Part number
Drawing
Dimensions in mm
09 99 000 0059
Insertion tool for Han® ES inserts
09 99 000 0367
for Han® EE, Han® Q 5/0, Han® Q 8/0,
Han E® and Han A®
09 99 000 0319
insert. The tool is inserted from the wiring side until a stop is
noticeable. The wire with the crimp contact can then be pulled out
from the same side of the insert.
Tools
99
05
Tools for contacts Han® C (09 32 ...)
Identification
Part number
Drawing
Dimensions in mm
09 99 000 0001
Locator Han® C
Wire gauge
0.14 ... 4 mm²
09 99 000 0308
Wire gauge
09 99 000 0379
1.5
2.5
4
mm² Ø 1.80
mm² Ø 1.80
mm² Ø 2.00
with locator
09 99 000 0110
Wire gauge Han® C
1.5 ... 4 mm²
with locator
for Han® C
09 99 000 0303
Wire gauge
4 ... 6 mm²
Locator as spare part
09 99 000 0304
for Han® C
CP 600
Tools
99
06
09 99 000 0377
Wire gauge
6 ... 10 mm²
09 99 000 0810
Crimp die Han® C
09 99 000 0814
Footswitch
09 99 000 0811
Table fixing
09 99 000 0812
Wire gauge Han® C
6 ... 10 mm²
Identification
Part number
Drawing
Dimensions in mm
Removal tool
1.5 ... 6 mm²
09 99 000 0305
10 mm²
09 99 000 0381
A removal tool is necessary to remove the contacts. For each
„C“ contact cavity, the location of the internal locking levers are
marked on the wiring side with two black arcs. The sides of the
tool must be first properly aligned so that the edges of the tool
engage both levers simultaneously and then inserted until a stop
is noticeable ➀. Once it has been inserted, the tool must not be
turned. The wire together with the tool can then be pulled out
from the wiring side of the insert ➁.
a ... lever marking
Tools
99
07
Identification
Part number
Drawing
Dimensions in mm
for coaxial contacts
09 99 000 0194
Use the middle crimping position.
for wire end ferrules 10 mm²
09 99 000 0374
Removal tools
for contacts
in the multi-contact module
09 99 000 0328
Insertion / removal tool
for D-Sub crimp contacts
09 99 000 0368
Removal tools
for locking sleeves
in the HV module
09 99 000 0327
Removal tools
for Quintax contact
Tools
09 99 000 0323
Stripping tool
09 99 000 0159
99
08
For stranded fine wires and solid wires 0.08 up to 10 mm²
Identification
Part number
Drawing
Dimensions in mm
Hexagonal driver
for axial screw
with grip
Bit 1/4“
adapter 3/8“
40 A contacts (SW 2)
09 99 000 0313
100 A contacts (SW 4)
09 99 000 0363
200 + 350 A contacts (SW 5)
09 99 000 0364
650 A contacts (SW 8)
09 99 000 0365
09 99 000 0369
70 A contacts (SW 2.5)
09 99 000 0375
09 99 000 0370
09 99 000 0371
09 99 000 0372
Tools
99
09
Tools for F.O. contacts hinged frames
Identification
Part number
Drawing
Dimensions in mm
Polishing tool
DIN 41 626
20 99 000 1092
POF1) cable ∅ 2.2
20 99 000 1093
Fibre stripper
0.3 mm
20 99 000 1041
1 mm
20 99 000 1045
0.18 / 0.3 mm
20 99 000 1046
Crimping tool
for following 1 mm POF1) contacts
Han D®, Han E®
DIN 41 626
Ferrule
F-SMA, -ST
20 99 000 1035
for F.O. connector (glass fibre)
SW 4.3 mm
SW 3.8 mm
SW 4.95 mm
for crimping the strain relief to the connector
F.O. cable for glass fibre
20 99 000 1033
for F.O. connector (plastic fibre)
SW 6.95 mm
SW 4.95 mm
SW 3.0 mm
Tools
20 99 000 1031
Epoxy adhesive
glass fibre
99
10
1)POF
= Polymer optical fibre
20 80 001 9902
2 ml EPO-TEK 360 with hardener (10:1), 4 g foil pack
Identification
Part number
Polishing paper
Drawing
Dimensions in mm
Range of delivery
Each part number means 5 pieces.
for POF1) grain size 1000
20 80 001 9911
for GI 9 µ-grain size
20 80 001 9912
for GI 1 µ-grain size
20 80 001 9913
Tools
1)POF
99
11
Tools for Han® high current contacts
Identification
Part number
Drawing
Dimensions in mm
Hydraulic handtool; Pressing force: 130 kN
09 99 000 0385
• fast forward action
• storage box
• weight: 6.4 kg
• Length: 620 mm
Die holder
09 99 000 0389
Crimp dies
DIN 46 235 (supplied as apair) use in
combination with die holder
09 99 000 0398
09 99 000 0386
09 99 000 0387
09 99 000 0388
09 99 000 0391
09 99 000 0392
09 99 000 0393
09 99 000 0394
Part number
Wire gauge
acc. to
DIN 46 235
a
b
c
d
09 99 000 0398
09 99 000 0386
09 99 000 0387
09 99 000 0388
09 99 000 0391
09 99 000 0392
09 99 000 0393
09 99 000 0394
10 mm²
16 mm²
25 mm²
35 mm²
50 mm²
70 mm²
95 mm²
120 mm²
B6 DIN
B8 DIN
B10 DIN
B12 DIN
B14 DIN
B16 DIN
B18 DIN
B20 DIN
5.5
8
10
12
14
16
18
3.2
3.8
4.7
5.5
6
7.3
8
8
8
10
10
10
13
15
15
13
13
13
13
13
13
15
15
Crimp die
Wire gauge 240 mm²
09 99 000 0801
Tools
99
12
C ... Crimp zone acc. to EN 46 235
2 crimps
Identification
Part number
Drawing
Dimensions in mm
100 A
09 99 000 0383
Tools
99
13
Overview Han® crimping tools
Han D®
F.O. contacts
20 10 001 ....
Han E®
Power contacts
09 33 000 ....
Han E®
F.O. contacts
20 10 001 ....
x
x
1.80
6107
6207
4.0
12
x
x
x
x
2.00
6108
6208
6.0
10
6109
6209
10.0
8
6107
6207
6127
6227
6104
6204
6124
6224
0.14 0.25
26 - 24
6107
6207
6127
6227
6104
6204
6124
6224
0.37
22
6103
6203
6123
6223
0.5
6105
6205
6125
6225
6102
6202
6122
6101
6201
6106
6206
Male contact
3211
3212 / 3213
x
x
x
x
x
x
x
x
x
x
x
99
14
Locator
Han® C
1.00
x
x
x
x
x
x
1.30
x
x
x
x
x
x
1.55
0.75
18
x
x
x
x
x
x
1.55
6222
1.0
18
x
x
x
x
x
x
1.55
6121
6221
1.5
16
x
x
x
x
x
x
1.80
6126
6226
2.5
14
x
x
x
x
1.55
Female contact
3221
3222
1 mm POF
6227
6117
6217
6121
6220
6122
6222
0.5
x
x
x
x
6114
6214
6115
6215
0.75
18
x
x
x
6105
6205
6118
6218
1.0
18
x
x
6104
6204
6116
6216
1.5
16
x
6102
6202
6123
6223
2.5
14
6106
6206
3.0
6107
6207
4.0
6119
6221
Female contact
3321
0.14 - 0.37 26 - 22
x
6127
Male contact
3311
x
x
09 99 000 0308
x
x
x
1.00
x
x
1.55
x
x
x
1.55
x
x
x
x
1.55
x
x
x
x
x
1.80
x
x
x
x
x
x
1.80
12
x
x
x
x
x
2.00
12
x
x
x
x
x
2.00
1 mm POF
x
x
x
09 99 000 0304
Locator
Han D®
09 99 000 0311
Locator
Han E®
09 99 000 0310
x
x
09 99 000 0022
09 99 000 0022
1) For using changeable units 09 99 000 6001 / 6002
2) Adjustment gauge with Ø 1.00 mm; 1.30 mm; 1.55
3) For using of tool head the basic unit CP 600 (09 99
09 99 000 0052
x
1.00
09 99 000 0012
x
x
removal tools
x
09 99 000 0381
x
09 99 000 0305
adjustment gauge
09 99 000 0379 2)
14
09 98 000 9002
2.5
09 98 000 9001
6205
09 98 000 6002 1)
6105
09 98 000 6001 1)
1.80
09 99 000 0814 3)
x
09 99 000 0813 3)
x
20 99 000 1035
x
09 99 000 0377
x
09 99 000 0303
16
09 99 000 0021
1.5
female contact
gold plated
6204
male contact
silver plated
6104
Description
Tools
Tools
09 98 000 9003
Crimping machines
09 99 000 0110
Crimping tools
09 99 000 0001
AWG
female contact
silver plated
Han D®
Signal contacts
09 15 000 ....
mm²
male contact
silver plated
Han® C
Power contacts
09 32 000 ....
Part number
x
x
x
x
x
basic unit 09 99 000 6000 is required.
mm; 1.80 mm; 2.00 mm
000 0810) is required.
09 99 000 0319
Crimp contacts
Series
Notes
Tools
99
15
Crimping machine TK
Features
❏ Basic unit in compact construction
Dimensions:
Height
Width
Depth
400 mm
555 mm
440 mm
❏ Simple handling due to ergonomic design
Total weight:
Approx. 60 kg
Local noise level:
< 70 dB (A)
❏ Fast stripping and crimping in one operation
❏ For individual, turned male and female contacts
(for the HARTING series Han D ®, Han E ®)
❏ Selective processing of male and female
contacts
(Wire gauge from 0.34 mm² to 4.0 mm²,
AWG 22 to AWG 12)
❏ Contact magazine with filling control
❏ Reproducible, top quality gas-tight crimp
connections
❏ Infinitely variable adjustment parameters
– Stripping depth
– Stripping length
– Crimping depth
– Crimp contact feed rate
❏ Magazine empties automatically
❏ Low noise level
❏ For oil-free compressed air
Tools
❏ Air servicing unit with water separator and
pressure reducer
❏ Very low setup effort
99
16
Technical characteristics
❏ Low maintenance costs
Drive: Electro-pneumatic
Electrical connection:
230 V, 50 Hz
Power rating:
0.75 kW
Pneumatic pressure:
6 bar
Compressed air
connection:
3 dm³ / work cycle
Control system:
PLC
Work cycle trigger:
Sensor
Machine work cycle: 2 seconds (stripping and
crimping)
Crimp type:
Four-notch crimping
Contact feed:
Vibratory bowl feed
Stroke counters: Resettable daily counter
and permanent counter
Crimping machine TK
Identification
Part No.
Crimping machine TK
(Basic machine
without interchangeable unit)
09 98 000 6000
interchangeable units for Han D ®
Han E ®
09 98 000 6001
09 98 000 6002
Pack contents
❏ Crimping machine TK
– with one mounted interchangeable unit
– with 2.0 m connection cable and grounding
plug
– with 2.0 m pneumatic hose with plug-in
nipple N9
Options
Interchangeable unit
with plug gauges
❏ Plug gauge for setting the crimping depth
❏ Centering bushing for positioning the plug
gauges
Forming blades
with feeding funnel
❏ Drawer for insulation pieces
❏ Drawer for holding contacts when the
magazine is emptied
❏ Tool set for adjustments
Tools
❏ 1 set of stripping blades
❏ Operating instructions
❏ Declaration of conformity
99
17
Features
❏ Basic unit in compact construction for
pre-stripped wire
HARTING contacts (wire gauge from
0.14 mm² to 10.0 mm², AWG 26 to AWG 8)
❏ Automatic contact feed
connections
❏ Non-slip, anti-vibration adjustable feet for
setting the height
❏ Low noise level
❏ Can be transported with carrying handle
❏ Removable electric and pneumatic supply
connections
❏ Maintenance interval counter
❏ Minimal setup effort
Tools
❏ Crimping depth can be set without tools
❏ Low follow-up costs for maintenance and
repair
99
18
❏ Easy replacement of wearing components
Dimensions:
Height
Width
Depth
345 mm
230 mm
400 mm
Total weight:
app. 24 kg
Local noise level:
62 dB (A)
230 V, 50 Hz
Power rating:
0.20 kW
Compressed air
connection:
6 bar
Control system:
PLC
Work cycle trigger:
Footswitch
Machine work cycle:
1 second
Crimp type:
Four-point crimping
Contact feed:
Vibratory bowl feed
Identification
for Han D ® contacts
Han E ® contacts
Han ® C contacts
Other
Part No.
09 98 000 9001
09 98 000 9002
09 98 000 9003
On request
Included in the delivery
❏ Crimping machine TC-C01
– with 2.5 m connection cable and grounding
plug
– with 2.5 m pneumatic hose, quick-release
coupling and N6 plug-in nipple
Options
Pneumatic maintenance unit
❏ Footswitch
❏ Carrying handle
Wire guide
Working light
Tools
99
19
Notes
Tools
99
很抱歉,暂时无法提供与“09990000368”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+277.406301+34.78729
- 5+257.118775+32.24319
- 10+248.8508010+31.20637
- 25+238.3237925+29.88626
- 国内价格 香港价格
- 1+197.300811+24.74190
- 4+194.645354+24.40890
- 15+192.1669215+24.09810
- 30+190.8391930+23.93160
- 75+187.9181875+23.56530
- 国内价格 香港价格
- 1+222.662461+27.92230
- 3+201.486553+25.26680
- 国内价格
- 1+184.56444
- 25+180.68008
- 50+175.20240
- 100+170.92231
- 500+167.21499
