Product data sheet
15 82 836 2601 000
har-flex hy st F 9.05 8+36 SMT PL1 280pc
Part number
15 82 836 2601 000
Specification
280pc
HARTING eCatalogue
https://b2b.harting.com/15828362601000
Image is for illustration purposes only. Please refer to product description.
Identification
Category
Connectors
Series
har-flex®
Identification
Hybrid
Element
Female connector
Description of the contact
Straight
Version
Termination method
Reflow soldering termination (SMT)
Connection type
Motherboard to daughtercard
Mezzanine
Number of contacts
44
Number of signal contacts
36
Number of power contacts
8
Performance level
1
Pack contents
280 pieces on reel
Technical characteristics
Contact spacing (mating side)
1.27 mm
2.54 mm
Stacking height
9.05 mm
Rated voltage
acc. to IEC 60664-1
Rated voltage
50 V AC
120 V DC
Rated impulse voltage
1.5 kV
Page 1 / 3 | Creation date 2020-10-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality,
conformity with applicable laws and directives, as well as for the electrical safety in the particular application.
HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany
Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
Product data sheet
15 82 836 2601 000
Pollution degree
2
Clearance distance
≥0.4 mm Signal contacts
≥1.74 mm Power contacts
≥1.11 mm Signal to power contacts
Connector: Power contacts
Creepage distance
≥0.4 mm PCB: Signal contacts
≥1.74 mm PCB: Power contacts
≥1.11 mm PCB: Signal to power contacts
≥0.4 mm Connector: Signal contacts
≥1.89 mm Connector: Power contacts
≥2.09 mm Connector: Signal to power contacts
Insulation resistance
>1010 Ω
Contact resistance
≤25 mΩ
Limiting temperature
-55 ... +125 °C
Mating cycles
≥500
Test voltage Ur.m.s.
0.5 kV Signal
1.39 kV Signal / Power
1.39 kV Power / Power
Isolation group
IIIa (175 ≤ CTI < 400)
Moisture Sensitivity Level (MSL)
1 acc. to ECA/IPC/JEDEC J-STD-020D
Process Sensitivity Level (PSL)
R0 acc. to ECA/IPC/JEDEC J-STD-020D
Coplanarity of contacts
0.12 mm
Material properties
Material (insert)
Liquid crystal polymer (LCP)
Colour (insert)
Black
Material (contacts)
Copper alloy
Surface (contacts)
Au over Pd/Ni Mating side
Tin plated Termination side
Material flammability class acc. to UL 94
V-0
Commercial data
Packaging size
1
Country of origin
China
European customs tariff number
85366990
eCl@ss
27460201 PCB connector (board connector)
Page 2 / 3 | Creation date 2020-10-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
15 82 836 2601 000
Current carrying capacity
Operating current (A)
The current carrying capacity of the connectors is
limited by the thermal load capability of the contact
element material including the connections and the
insulating parts. The derating curve is therefore
valid for currents which flow constantly (nonintermittent) through each contact element of the
connector evenly, without exceeding the allowed
maximum temperature.
Measuring and testing techniques acc. to IEC
60512-5-2
Ambient temperature (°C)
Derating curve 80%
Page 3 / 3 | Creation date 2020-10-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the
很抱歉,暂时无法提供与“15828362601000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+20950.14486
- 3+18485.49169
- 国内价格 香港价格
- 280+74.97272280+9.65906
- 560+71.39778560+9.19848
- 840+69.38702840+8.93943
- 国内价格 香港价格
- 1+111.593261+14.37704
- 10+94.8424910+12.21896
- 100+80.61842100+10.38642
