DF51K-12DS-2C(800)
DF51K-12DS-2C(800)
    HRS(广濑)
    P=2mm
    2X6P 2MM
DF51K-12DS-2C(800) 数据手册
COUNT DESCRIPTION OF REVISIONS BY CHKD DATE Jun.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. △ △ APPLICABLE STANDARD Applicable Contact BY CHKD DATE △ △ Operating Temperature Range Operating Humidity Range RATING Applicable Connector DESCRIPTION OF REVISIONS COUNT Storage Temperature Range Storage Humidity Range -55℃ to +105℃ (Note1) 20% to 80% (Note2) DF51K#-12DP-2DSA/DS (###) Voltage DF51K-22SC(A)/SCF(A) (###) DF51K-2428SC(A)/SCF(A) (###) DF51K-30SC(A)/SCF(A) (###) Current -10℃ to +60℃ (Note3) 40% to 70% (Note3) 250V AC/DC AWG 30: 0.5A AWG 28: 1A AWG 26: 1.5A AWG 22-24: 2A SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT CONSTRUCTION General Examination Marking Visually and by measuring instrument. Confirmed visually. O O O O O - O - O - O - O - O - O - O - O - O - O - O - Dry Heat O Cold O Remarks Note 1: Include the temperature rising by current. Note 2: No condensing Note 3: Apply to the condition of long term storage for unused products before pcb on board, after pcb board , operating temperature and   humidity range is applied for interim storage during transportation. - According to drawing. ELECTRICAL CHARACTERISTICS Contact Resistance Millivolt Level Method Insulation Resistance 20mV MAX, 1mA (DC or 1000Hz). 30 mΩ MAX. 500 V DC. 1,000 MΩ MIN. Voltage Proof 650 V AC for 1 min. No flashover or breakdown. MECHANICAL CHARACTERISTICS Mechanical Operation (Sn Plating) Mechanical Operation (Au Plating) Mating and unmating Force (Sn Plating) Mating and unmating Force (Au Plating) Vibration 30 times insertion and extraction. Shock Acceleration 490 m/s2 duration of pulse 11 ms at 3 times for 3 directions. Pull out the cable after housing fixation. 11.8N MIN Contact extraction force ①Contact resistance: 30mΩ MAX ②No damage, crack or looseness of parts. 50 times insertion and extraction. ①Contact resistance: 30mΩ MAX ②No damage, crack or looseness of parts. It takes out and inserts with a conformity connector. ①Insertion Force: 56.2N MAX ②Extraction Force: 3.2N MIN It takes out and inserts with a conformity connector. ①Insertion Force: 36.2N MAX ②Extraction Force: 3.0N MIN Frequency 10 to 55 Hz, single amplitude 0.75 mm, ①No electrical discontinuity of 1μs. at 10 cycles for 3 direction. ②No damage, crack or looseness of parts. ENVIRONMENTAL CHARACTERISTICS Damp Heat Rapid Change of Temperature Exposed at 40 ± 2 ℃ , humidity 90 to 95 %, 96 h. (Steady State) (After leaving the room temperature for 1 to 2h.) ①Contact resistance: 30 mΩ MAX. ②Insulation resistance: 500MΩ MIN. ③No damage, crack or looseness of parts. Temperature -55 ℃ → +105 ℃ ①Contact resistance: 30 mΩ MAX. Time 30min → 30min Under 5 Cycles. ②Insulation resistance: 1,000MΩ MIN. (The transferring time of the tank is 2 to 3 MIN) ③No damage, crack or looseness of parts. (After leaving the room temperature for 1 to 2h.) Exposed at 105±2 ℃, 96h Exposed at -55±3 ℃, 96h DRAWN DESIGNED CHECKED APPROVED J.S CHOI J.S CHOI S.M.LIM T.S KANG 17.12.22 17.12.22 17.12.22 17.12.22 RELEASED Unless otherwise specified, refer to IEC 60512. NOTE QT: QUALIFICATION TEST AT: ASSURANCE TEST O: APPLICABLE TEST HIROSE KOREA CO.,LTD. CODE NO.(OLD) CL SPECIFICATION SHEET DRAWING NO. ELC4-632499 CODE NO. PART NO. DF51K-12DS-2C (800) CL 6652-0029-0-800 F-1-021(Rev.0) 1 1
DF51K-12DS-2C(800) 价格&库存
很抱歉,暂时无法提供与“DF51K-12DS-2C(800)”相匹配的价格&库存,您可以联系我们找货
DF51K-12DS-2C(800)
    库存:2590
