Data sheet | Item number: 2042-3809
Relay module; 230 VAC/VDC; Relay with 1 changeover contact (1u)
www.wago.com/2042-3809
Similiar to picture
12.04.2019 Page 1/7
DC load limit curve
Data
Technical Data
Control circuit
Nominal input voltage UN
AC/DC 24 … 230 V
Input voltage range
±10 %
Nominal input current at UN
1.7 mA (230 V); 26.3 mA (24 V)
Load circuit:
Number of make contacts/switch on contacts
1
Contact material (relay)
AgSnO2
Limiting continuous current
3 A
Max. switching voltage
AC 250 V
Max. switching power (resistive)
AC 750 VA; DC see load limit curve
Recommended minimum load
10 V / 10 mA; 24 V / 1 mA
Min. switching current
0 µA
Pull-in time (typ.)
8 ms
Drop-out time (typ.)
4 ms
Drop-out time
≤ 0 µs
Electrical life (N.O.; resistive load; 23 °C)
50 x 103 switching operations
Mechanical life (N.O.; resistive load; 23 °C)
5 x 106 switching operations
Signaling
Status indication
LED green
12.04.2019 Page 2/7
Safety and protection:
Rated voltage
250 V
Rated impulse voltage
4 kV
Pollution degree
2
Dielectric strength, control/load circuit (AC, 1 min)
3 kVrms
Dielectric strength open contact (AC, 1 min)
1 kVrms
Dielectric strength, channel/channel (AC, 1 min)
2.5 kVrms
Protection class
IP20
Geometrical Data
Width
10.3 mm / 0.406 inch
Height
77.7 mm / 3.059 inch
Height from the surface
59.3 mm / 2.335 inch
Depth
52 mm / 2.047 inch
Mechanical data
Type of mounting
Pluggable module for TOPJOB® S carrier terminal block
Material Data
Flammability class per UL94
V0
Fire load
0.204 MJ
Weight
31.55
Environmental Requirements
Pollution degree
2
Surrounding air (operating) temperature at UN
-40 … 70 °C
Surrounding air (storage) temperature
-40 … 85 °C
Max. operating altitude
2000 m
Standards and specifications
Standards/specifications
EN 61010-2-201; EN 61373; EN 50121-3-2
Commercial data
Country of origin
DE
GTIN
4055143709538
12.04.2019 Page 3/7
Compatible products
End plate
Item no.: 2002-1691
End and intermediate plate; 1 mm thick
www.wago.com/2002-1691
Item no.: 2002-1692
www.wago.com/2002-1692
Item no.: 2002-1791
www.wago.com/2002-1791
Item no.: 2002-1792
www.wago.com/2002-1792
Item no.: 2002-1891
www.wago.com/2002-1891
Item no.: 2002-1892
www.wago.com/2002-1892
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
www.wago.com/2009-115
Item no.: 2009-115/000-002
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
/000-006
Item no.: 2009-115/000-007
/000-007
Item no.: 2009-115/000-012
/000-012
Item no.: 2009-115/000-017
/000-017
Item no.: 2009-115/000-023
/000-023
Item no.: 2009-115/000-024
12.04.2019 Page 4/7
/000-024
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type
www.wago.com/793-501
Item no.: 793-501/000-002
/000-002
Item no.: 793-501/000-005
/000-005
Item no.: 793-501/000-006
/000-006
Item no.: 793-501/000-007
/000-007
Item no.: 793-501/000-012
/000-012
Item no.: 793-501/000-017
/000-017
Item no.: 793-501/000-023
/000-023
Item no.: 793-501/000-024
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type
Item no.: 793-5501/000-002
/000-002
type
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type
/000-005
Item no.: 793-5501/000-006
/000-006
Item no.: 793-5501/000-007
/000-007
Item no.: 793-5501/000-012
12.04.2019 Page 5/7
/000-012
Item no.: 793-5501/000-014
/000-014
Item no.: 793-5501/000-017
/000-017
Item no.: 793-5501/000-023
/000-023
Item no.: 793-5501/000-024
/000-024
Item no.: 2002-1661
2-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®
www.wago.com/2002-1661
Item no.: 2002-1761
3-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®
www.wago.com/2002-1761
Item no.: 2002-1861
4-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®
www.wago.com/2002-1861
clamps
Item no.: 2002-1961
2-conductor carrier terminal block; with additional jumper position; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 www.wago.com/2002-1961
Downloads
Documentation
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
Oct 10, 2018
pdf
265.8 kB
Download
URL
Download
CAD/CAE - Smart Data
CAD data
3D Download 2042-3809
12.04.2019 Page 6/7
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at 01788 568 008.
12.04.2019 Page 7/7
很抱歉,暂时无法提供与“2042-3809”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+384.33669
- 8+366.04301
- 31+349.39370
- 77+334.19531
- 240+320.29065
