Data sheet | Item number: 2065-101/998-403
SMD PCB terminal block; 0.75 mm²; Pin spacing 6 mm; 1-pole; PUSH WIRE®;
in tape-and-reel packaging; Without housing; 0,75 mm2; silver-colored
www.wago.com/2065-101/998-403
Color:
R = Feed direction
Item description
SMD PCB terminal block with PUSH WIRE® connection technology
Push-in termination of solid conductors
Just 2.7 mm tall
05.09.2019 Page 1/4
Just 2.7 mm tall
Available in tape-and-reel packaging for automated assembly
Note:
Die Bemessungsdaten basieren auf dem exemplarischen Rastermaß von 6 mm.
Das Layout ist gemäß den Anforderungen der Isolationskoordination EN/IEC 60664-1 bzw. der Endgerätenormen auszulegen.
Safety information 1:
NOTE: Terminal block without insulation housing! Protection against accidental contact must be provided at voltages higher than low voltages(e.
g., SELV/PELV) for the relevant application.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
250 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
9 A
Approvals per UL 1977
Rated voltage per UL 1977 (factory wiring only)
600 V
Rated current per UL 1977 (factory wiring only)
9 A
Connection data
Connection technology
PUSH WIRE®
Actuation type
Push-in
Solid conductor
0.2 … 0.75 mm² / 24 … 18 AWG
Strip length
7.5 … 9.5 mm / 0.3 … 0.37 inch
Conductor entry angle to the PCB
0 °
Total number of connection points
1
Total number of potentials
1
Number of connection types
1
Number of levels
1
No. of poles
1
Geometrical Data
Pin spacing
6 mm / 0.236 inch
Width
2.3 mm / 0.091 inch
Height
2.7 mm / 0.106 inch
05.09.2019 Page 2/4
Height
2.7 mm / 0.106 inch
Depth
8 mm / 0.315 inch
Reel diameter of tape-and-reel packaging
330 mm
Tape width
16 mm
PCB contact
PCB contact
SMD
Material Data
Color
silver-colored
Insulating material
Polyamide 66 (PA 66)
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Weight
0.14 g
Environmental Requirements
Limit temperature range
-60 … +120 °C
Commercial data
Country of origin
CH
GTIN
4055143665438
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CB
DEKRA Certification B.V.
EN 60947-7-4
NL-49896
(IEC
60947-74:2013)
KEMA/KEUR
EN 60947-7-4
71102154
KEMA/KEUR
EN 60998
71102159
UL-Approvals
Logo
Certificate
05.09.2019 Page 3/4
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1977
E45171
sec. 25
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
3D Download 2065-101/998-403
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
05.09.2019 Page 4/4
很抱歉,暂时无法提供与“2065-101/998-403”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2650+2.413132650+0.28860
- 5300+2.366725300+0.28305
