2091-1406
2091-1406
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 间距:3.50mm 1x6P 直插
2091-1406 数据手册
Printview: Male header with straight solder pins; 6-pole; pin spacing 3.5 mm / 0.138 in - Item No.: 20911406 . Male header with straight solder pins; 6-pole; pin spacing 3.5 mm / 0.138 in Item No.: 2091-1406 . Male header with straight solder pins; 6-pole; pin spacing 3.5 mm / 0.138 in . Marking . Business data Supplier WAGO Item no. 2091-1406 GTIN / EAN 4050821161035 Content 1 Order amount 100 Customer item number . Notes Assembly of female connectors without loss of poles, allowing different functions to be divided within one male headerCoding pins inserted into the header interface prevent mismating, allowing subsequent coding in panel feedthrough applicationsThe female connector is fully shrouded by the male header's housing, providing vibration resistance up to 20 g Technical data Miscellaneous No. of poles 6 Pin Spacing 3.5 mm (0.0 in %) Color light gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Male header with straight solder pins; 6-pole; pin spacing 3.5 mm / 0.138 in - Item No.: 20911406 Technical data Rated voltage EN (1) [V] 160 [V] Rated surge voltage (1) [kV] 2.5 [kV] Nominal current [A] 10 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 320 [V] Rated surge voltage (2) [kV] 2.5 [kV] Nominal current (2) [A] 10 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 160 [V] Rated surge voltage (3) [kV] 2.5 [kV] Nominal current (3) [A] 10 [A] Solder pin length [mm] 3.6 [mm] Solder pin diameter [mm] 1 [mm] Tolerance of drilled hole [mm] 1.2(+ 0.1) [mm] Material group I Insulating material Polyphtalamid (PPA GF) Flammability rating per UL 94 V0 Limit temperature range -60 C … 100 C Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.044 [MJ] Weight [g] 2.1 [g] Width 23 mm / 0.906 in Height 21.1 mm / 0.831 in Height from the surface 17.5 mm / 0.689 in Length 12.4 mm / 0.488 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Male header with straight solder pins; 6-pole; pin spacing 3.5 mm / 0.138 in - Item No.: 20911406 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Male header with straight solder pins; 6-pole; pin spacing 3.5 mm / 0.138 in - Item No.: 20911406 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2091-1406 价格&库存
很抱歉,暂时无法提供与“2091-1406”相匹配的价格&库存,您可以联系我们找货
  • 1+19.691731+2.55945
  • 10+16.7592410+2.17830
  • 100+14.24174100+1.85108
  • 500+12.71227500+1.65229
  • 1000+12.105671000+1.57344
  • 5000+10.807075000+1.40466
库存:604
2091-1406
  • 1+14.95800
  • 10+12.47400
  • 30+10.90800
库存:27
