215-911
215-911
    WAGO(万可电子)
215-911 数据手册
Electrical Contractor Products Offering Better Alternatives Contents 1 Push-Wire Connectors for Junction Boxes, 1 2 Compact Connectors, 2 3 Lighting, “Service”, and MICRO Connectors, 3 4 Terminal Blocks for Chassis Mounting, 4 5 High Current Terminal Blocks, 5 6 DIN Rail Mount Outlet Boxes, 6 7 Pluggable Relay Modules, Surge Protection Devices, 7 8 Rail, Tools, & Accessories, 8 Series 773 (Wall-nuts™) Series 222 (Lever-nuts™) Series 224 & Series 243 Series 862 Series 285 CPO Series Series 788 & WAGO PROTECT Series Miscellaneous Series  Push-Wire Connectors for Junction Boxes, (re-use solid wire), Series 773 (Wall-nuts™) Fast, Easy, Reliable Connection: Simply strip conductor to 12 mm /0.47 in. using the built-in strip-length gauge Then insert stripped conductor firmly into connector. Check for complete insertion. Push-wire connection Wire removal Solid - Pull & Twist; Remove wire Stranded - Cut Wire; Discard connector Restrip; Insert wire in new connector Testing Integrated test port allows for easy testing of connection integrity. Applications Packing unit Push-wire connectors used in a cable duct with double power outlet. Connectors may be mounted on DIN Rail by using the WAGO fixing carrier.  Push-Wire Connectors for Junction Boxes, (re-use solid wire), Series 773 (Wall-nuts™) 2 x 0.75 – 2.5 mm2 “s” 2 2 x 1 .5 – 2.5 mm “r” 400 V/ 4 kV/2* 24 A 2 x AWG 18 – 12 “sol.” 2 x AWG 16 – 12 “rig.” 600 V, 20 A 2u Max. op. temp. 105°C l 12 mm / 0.47 in * Pack.-unit pcs Push-wire connectors for junction boxes, 2-conductor connectors, color of housing transparent, color of cover yellow 773-162 100 pc/box 500 pc/bag 773-102/VE00-0500 2500 pc/bag 773-102/VE00-2500 51011251 10 pc/blister pack 8 x 0.75 – 2.5 mm2 “s” 8 x 1 .5 – 2.5 mm2 “r” 400 V/ 4 kV/2* 24 A 8 x AWG 18 – 12 “sol.” 8 x AWG 16 – 12 “rig.” 600 V, 20 A 2u Max. op. temp. 105°C l 12 mm / 0.47 in Item No. 4 x AWG 18 – 12 “sol.” 4 x AWG 16 – 12 “rig.” 600 V, 20 A 2u Max. op. temp. 105°C 6 x 0.75 – 2.5 mm2 “s” 6 x 1 .5 – 2.5 mm2 “r” 400 V/ 4 kV/ 2* 24 A l 12 mm / 0.47 in Item No. * 2 Pack.-unit pcs Push-wire connectors for junction boxes, 4-conductor connectors, color of housing transparent, color of cover orange 773-164 100 pc/box 500 pc/bag 773-104/VE00-0500 2500 pc/bag 773-104/VE00-2500 5101252 10 pc/blister pack 3 x 0.75 – 2.5 mm2 “s” 3 x 1 .5 – 2.5 mm2 “r” 1 x 0.75 “sol.+ rig.” 400 V/ 4 kV/ 2* 24 A Push-wire connectors for junction boxes, 8-conductor connectors, color of housing transparent, color of cover dark grey 773-168 50 pc/box 2500 pc/bag 773-108/VE00-2500 51013414 10 pc/blister pack Item No. 3 x AWG 18 – 12 “sol.” 3 x AWG 16 – 12 “rig.” 1 x AWG 18 “sol.+ rig.” 600 V, 20 A 2u Max. op. temp. 105°C Item No. Pack.-unit pcs 3 x 1 .5 – 6 mm2“s + st“ 3 x AWG 14 –10“sol.“ +“str.“ 400 V/ 4 kV/ 2* 600 V, 20 A 2u 32 A Max. op. temp. 105°C l 12 – 15 mm / 0.47 - 0.53 in Pack.-unit pcs Push-wire connectors for junction boxes, 4-conductor connectors, filled with contact paste “Alu-Plus”, color of housing transparent, color of cover light grey 773-124   100 pc/box 773-124/VE01-0000   2500 pc/bag  Push-wire connectors for junction boxes, 6-conductor connectors, color of housing transparent, color of cover black 773-166 50 pc/box 500 pc/bag 773-166/VE00-0500 2500 pc/bag 773-166/VE00-2500 10 pc/blister pack 51011253 l 12 mm / 0.47 in Pack.-unit pcs 6 x AWG 18 – 12 “sol.” 6 x AWG 16 – 12 “rig.” 600 V, 20 A 2u Max. op. temp. 105°C l 12 mm / 0.47 in * 2 2 Item No. 4 x 0.75 – 2.5 mm2 “s” 4 x 1 .5 – 2.5 mm2 “r” 400 V/ 4 kV/ 2* 24 A Item No. Pack.-unit pcs Push-wire connectors for junction boxes, 3-conductor connectors, color of housing transparent, color of cover red 773-173 100 pc/box 773-173/VE00-0500 500 pc/bag 773-173/VE00-2500 2500 pc/bag 51015201 5 pc/blister pack Push-Wire Connectors for Junction Boxes, (re-use solid wire), Series 773 (Wall-nuts™) 22 22 3‑x‑AWG‑18‑– 3‑x‑0,75‑–‑ 3‑x‑0.75‑–‑ 1 .5‑mm 1,5‑mm „e“ «r» “s”‑‑   2 x AWG 8‑x‑0.75‑–‑1,5‑mm 1 .5‑mm „e“ «r» “s”‑2   18‑12 “sol.”8‑x‑0,75‑–‑ 2 x 0.75–2.5 mm2 “s” 4 x 0.75 – 2.5 mm “s” 48‑x‑AWG‑18‑– x AWG 18 – 12 “sol.” ‑16‑“sol.” ‑16‑«s» ‑16‑„sol.“ ‑16‑«s» ‑16‑„sol.“ ‑16‑“sol.” 2 2 2 x 1 .5–2.5 mm 22“r” 2 x AWG 16‑12 “rig.” 4 x 1 .5 – 2.5 mm “r” 4 x AWG 16–12 “rig.” 5‑x‑0.75‑–‑ 5‑x‑0,75‑–‑ 5‑x‑AWG‑18‑– 1 1,5‑mm .5‑mm „e“ «r» “s” ‑ ‑     400 V/ 4 kV/2* 600 V, 20 A u 400 V/ 4 kV/ 2* 600 V, 20 A u ‑16‑“sol.” ‑16‑«s» ‑16‑„sol.“ 400 V/ 4 kV/2** 600 V, 10 A u 24 A 24 A 600 V, 20 A 2 400 V/ 4 kV/2** kV/2** 600 V, 10 600 A uV, 10 A u 18 A 600 V, 10 A 2 18l A 600 V, 10 A 2 12 mm / 0.47 in l 12 mm / 0.47 in u NDCCA10 Fa CB mm :; RMR * u * 2QOKfNSDFAJ9q:;[ l – 13 / 0.45 in Item No. l 10 – 13 mm / 0.45 in * u2QOsKfNSDFaAJ9q:;[ * u2NSDCCA FaCB :;RMR Pack.-unit pcs Push-wire connectors for junction boxes, 2-conductor connectors, color of housing transparent, color of cover green 773-112 100 pc/box 8 x 0.75 – 2.5 mm2 “s” 8 x 1 .5 – 2.5 mm2 “r” 400 V/ 4 kV/2* 24 A 8 x AWG 18 – 12 “sol.” 8 x AWG 16 – 12 “rig.” 600 V, 20 A u 600 V, 20 A 2 l 12 mm / 0.47 in l 12 mm / 0.47 in * u2QOsKfNSDFaAJ9q:;[ * u2NSDCCA FaCB :;RMR Pack.-unit pcs Push-wire connectors for junction boxes, 4-conductor connectors, color of housing transparent, color of cover green 773-114 100 pc/box Item No. l 12 mm / 0.47 in Pack.-unit pcs Push-wire connectors for junction boxes, 6-conductor connectors, color of housing transparent, color of cover green 773-116   50 pc/box 4 x 0.75 – 2.5 mm2 “s” 4 x AWG 18 – 12 “sol.” 4 x 1 .5 – 2.5 mm2 “r” 4 x AWG 16 – 12 “rig.” 400 V/ 4 kV/ 2* 600 V, 20 A u 24 A 600 V, 20 A 2 :;[ * u2 * u2fNSDFaCB 6 x AWG 18 – 12 “sol.” 6 x AWG 16 – 12 “rig.” 600 V, 20 A u 600 V, 20 A 2 Carrier for Push-Wire Connectors Carrier width 18 mm / 0.7 in * u2QOsKfNSDFbAJ:;[ < 25.5‑mm/ > 1 in CCA Fa CB :; RMR 2QOsKfNSDFAJ9:;[ * u2NSD Item No. 6 x 0.75 – 2.5 mm2 “s” 6 x 1 .5 – 2.5 mm2 “r” 400 V/ 4 kV/ 2* 24 A Item No. Pack.-unit pcs Push-wire connectors for junction boxes, 8-conductor connectors, color of housing transparent, color of cover green 773-118   50 pc/box Item No. Pack.-unit pcs Push-wire connectors for high temperature applications, 4-conductor connectors, color of housing black, color of cover black 773-514 50 pc/box ** in grounded (earthed) supply system  Item No. Pack.-unit pcs Fixing carrier for 4 push-wire connectors 773-332    50 pc/box orange light grey 773-331    50 pc/box Marker strip, plain 243-110     1 ea 3 or 5 Conductor Compact Connectors, Series 222 (Lever-Nuts™) 28 – 12 AWG (stranded and solid) 600 V maximum u 20 A maximum 28 – 12 AWG (stranded and solid) 600 V maximum u 20 A maximum Strip length: l 9 - 10 mm / 0.37 in Maximum operating temperature: 105° C Strip length: l 9 - 10 mm / 0.37 in Maximum operating temperature: 105° C For all connections requiring... • Stranded / solid wires • Wide range of wire sizes • Combination of different wire sizes and types • Small space consumption • Built-in test point • Protection against electrical shock, touch safe • Low installed cost and safe operation • Maintenance-free connection Item No. Pack.-unit pcs Push-wire connectors for junction boxes, 3-conductor connectors with CAGE CLAMP® spring pressure connection technology, grey (w/orange levers) 222-413   500 pc/bag 222-413/VE00-0050   50 pc/box 51015200 5 pc/blister pack Technical Information Number of connection points per connector: Potentials per connector: Height: Width: Depth: Approvals: 3 1 14.5 mm / 0.571 in 17 mm / 0.669 in 20.5 mm / 0.807 in r Item No. Pack.-unit pcs Push-wire connectors for junction boxes, 3-conductor connectors, color of housing transparent, color of cover red 773-173 100 pc/box 773-173/VE00-0500 500 pc/bag 773-173/VE00-2500 2500 pc/bag 51017356 5 pc/blister pack 5 1 14.5 mm / 0.571 in 26.6 mm / 1.047 in 20.5 mm / 0.807 in r Easy as 1, 2, 3... 1) Strip wire 2) Push up lever  3) Insert conductor and push down lever Lighting & “Service“ Connectors, Series 224 Installation side 1 .0 – 2.5 mm2‑“s“ AWG 14 – 12 Lighting side 0.5 – 2.5 mm2‑“s +f-st“ AWG 20 – 16 400 V/4 kV/2**; 24 A 300 V, 20 A‑u2 l 9 – 11 mm / 0.39 in * u2QOKCCA NSDFaAJ:; Colour Item No. Pack.-unit pcs Lighting connectors, standard version, continuous service temperature 105°C, 224-101 1000 (10 x 100) grey version for increased continuous service temperature 120°C, 224-104   100 black “Service“ connector 224-201 grey Installation side 2‑x‑1 .0 – 2.5 mm2‑“s“ AWG 16 – 14 Lighting side 0.5 – 2.5 mm2‑“s + f-st“ AWG 20 – 16 400 V/4 kV/ 2**; 24 A 300 V, 4 A‑u‑2 l 9 – 11 mm / 0.39 in * u2QOKCCA NSDFaAJ:; Colour Item No. Pack.-unit pcs Stripped length 2-conductor lighting connectors, standard version, continuous service temperature 105°C, 224-112 1000 (10 x 100) white version for increased continuous service temperature 120°C, 224-114   100 black 50 Strip conductor to 9 – 11 mm / 0.39 in Dimensions (in mm) Testing Testing through separate test slot Testing Connection of conductors (lighting side): Press button fully and insert stripped conductor into square entry and release. Connection of conductors (installation side): Introduce stripped solid conductor into circular entry and push to stop.  Testing through separate test slot MICRO Push-Wire Connectors for Junction Boxes, Series 243 1 Stripped length Connector blocks Strip solid wire to 5 – 6 mm /0.22 in Assembly of modular connectors to connector strips Testing Commoning Packing units Test using integrated test ports Commoned connector blocks Push-wire connection Connection: Insert stripped conductor FULLY. Push-wire connection Removal: Hold wire to be removed and twist alternately left and right while pulling the connector  1 For distribution connectors for e (Euro Installation Bus) see Full Line Catalog W4, volume 2, page 2.4  Box for use on site (example) Contents series 243:   50 pcs 8-conductor or 100 pcs 4-conductor MICRO Push-Wire Connectors for Junction Boxes, Fixing Carrier Series 243 4x0.6– 0.8 Ø mm “ s“ ** 4 x AWG 22 – 20 “ sol.“ ** 100 V/ 1 .5 kV/ 2 125 V, 7 A U 6 A 150 V, 7 A 2 * U2QKCCA SDaq Pack.-unit pcs MICRO push-wire connectors for junction boxes, 4-conductor connectors dark grey red light grey yellow 243-204 243-804 243-304 243-504 4x 0.4 – 0.5 Ø mm “ s“ 100 V/ 1 .5 kV/ 2 6A Fixing carrier for MICRO push-wire connectors l 5 – 6 mm / 0.22 in l 5 – 6 mm / 0.22 in * U2QKCCA NSDaq Color Item No. 8x0.6– 0.8 Ø mm “ s“ ** 8 x AWG 22 – 20 “ sol.“ ** 100 V/ 1 .5 kV/ 2 125 V, 7 A U 6 A 150 V, 7 A 2 1000 (10 x 100) 1000 (10 x 100) 1000 (10 x 100) 1000 (10 x 100) Color Item No. Pack.-unit pcs MICRO push-wire connectors for junction boxes, 8-conductor connectors dark grey red light grey yellow 243-208 243-808 243-308 243-508   500 (10 x 50)   500 (10 x 50) 500 (10 x 50) 500 (10 x 50) Description Item No. Pack.-unit pcs Fixing carrier for 4 push-wire connectors 243-112    50 (5 x 10) for 6 push-wire connectors 243-113    50 (5 x 10) Marker strip, 243-110     1 plain 4 x AWG 26 – 24 “ sol.“ l 5 – 6 mm / 0.22 in * U2CCA aq Inserting a MICRO push-wire connector for junction boxes into the carrier Color Item No. Pack.-unit pcs MICRO push-wire connector for junction boxes, 4-conductor connector transparent 243-144 Example of doorbell application – mounted on DIN 35 rail 1000 (10 x 100) Dimensions (in mm) * You can find approvals on the Internet at www.wago.us **When using wires of the seme diameter only, 0.5 Ø mm/AWG 24 or 1.0 Ø mm /AWG 18 are also possible 10 Typical application in a terminal box for burglar alarm – screw fixing Terminal Blocks for Chassis Mounting, Series 862 4 x 0.5 – 4 mm2 500 V/6 kV/2 32 A l Available in black and white without ground/ earth contact with ground/ earth contact 4 x AWG 20 –12 300 V, 20 A 600 V, 5 A 2U 10 – 11 mm / 0.41 in 4 x 0.5 – 4 mm2 500 V/6 kV/2 32 A l 2 poles /8 connection points Item No. black for fastening screw 3 mm /0.118 in Ø or for self tapping screw 2.9 mm / 0.114 in Ø from top 862-0552 without marking L1-N (pre-marked) 862-1552 N-L1 (pre-marked) 862-2552 for self tapping screw 2.9 mm / 0.114 mm Ø from below without marking 862-0562 L1-N (pre-marked) 862-1562 N-L1 (pre-marked) 862-2562 1 snap-in foot per pole without marking 862-0532 L1-N (pre-marked) 862-1532 N-L1 (pre-marked) 862-2532 for fastening screw 3 mm / 0.008 in Ø or for self tapping screw 2.9 mm / 0.114 in Ø from top without marking PE-N-L1 (pre-marked) N-PE-L1 (pre-marked) (pre-marked) N-PE-L1 (pre-marked) PE-N-L1 1 snap-in foot per pole without marking PE-N-L1 (pre-marked) N-PE-L1 (pre-marked) (pre-marked) N-PE-L1 (pre-marked) PE-N-L1 snap-in feet at pos. 1+3 without marking PE-N-L1 (pre-marked) N-PE-L1 (pre-marked) (pre-marked) N-PE-L1 (pre-marked) PE-N-L1 4 x AWG 20 –12 300 V, 20 A 600 V, 5 A 2U 10 – 11 mm / 0.41 in 3 poles /12 connection points Item No. white Pack.-unit pcs 862-0652 862-1652 862-2652 500 500 500 862-0662 862-1662 862-2662 500 500 500 862-0632 862-1632 862-2632 500 500 500 Accessories Item No. black Item No. white Pack.-unit pcs 862-0503 862-1503 862-2503 862-8503 862-9503 862-0603 862-1603 862-2603 862-8603 862-9603 250 250 250 250 250 862-0533 862-1533 862-2533 862-8533 862-9533 862-0633 862-1633 862-2633 862-8633 862-9633 250 250 250 250 250 862-0593 862-1593 862-2593 862-8593 862-9593 862-0693 862-1693 862-2693 862-8693 862-9693 250 250 250 250 250 Comb-type jumper bar, can easily be inserted into the wire entry, 32 A 862-482 5 Test plug, with cable 500 mm / 1'7.7" 2 mm /0.079 in Ø, red 210-136 1 Test plug, with cable 500 mm / 1'7.7" 2.3 mm /0.091 in Ø, yellow 210-137 50 (5 x 10) Screwdriver, with partially inslated shaft (3.5 x 0.5) mm (.14 x .0025) in 210-620 1 Marker strip, white, plain for central marking; 7.5 mm wide, on roll, 50 m long 709-178 1 Marker strip, white, plain for central marking; 7.5 mm wide, on roll, 300 m long 709-188 1 Cost-effective features: The new 862 Series chassis mount terminal block was developed specifically to minimize wiring costs, while accommodating requirements for easy mounting, multiple connection points, marking, and handling. • The new 862 Series allows the connection of up to four conductors from wire size 20 to 12 AWG. Due to the multiple connection points per pole, different wire sizes can be used within the same terminal block position. • The CAGE CLAMP®S termination technology allows solid conductors, stranded conductors with ferrules, or ultrasonically bonded conductors to be easily connected by simply pushing the conductor into the contact. • An integrated push button, with molded-in slots, accommodates fast and easy wiring of all conductor types - either by hand, or with a slotted tip/ phillips screwdriver. • Convenient automatic grounding contact available as an option (see page 3 for illustration). • Snap-in mounting feet for fast assembly (see back page for illustration). • Flexible marking options with standard marking (pre-marked), marker strip, or custom marked per your specifications with large quantity orders. • Built-in test points simplify testing with 2 mm / 0.079 in diameter test plug. 11 Terminal Blocks for Chassis Mounting, Series 862 4 x 0.5 – 4 mm2 4 x AWG 20 –12 500 V/6 kV/2 300 V, 20 A 32 A 600 V, 5 A 2U l 10 – 11 mm / 0.41 in Available in black and white without ground/ earth contact with ground/ earth contact for fastening screw 3 mm Ø or for self tapping screw 2.9 mm Ø from top without marking PE-N-L1-L2 (pre-marked) N-PE-L1-L2 (pre-marked) (pre-marked) N-PE-L1-L2 (pre-marked) PE-N-L1-L2 1 snap-in foot per pole without marking PE-N-L1-L2 (pre-marked) N-PE-L1-L2 (pre-marked) (pre-marked) N-PE-L1-L2 (pre-marked) PE-N-L1-L2 snap-in feet at pos. 1+4 without marking PE-N-L1-L2 (pre-marked) N-PE-L1-L2 (pre-marked) (pre-marked) N-PE-L1-L2 (pre-marked) PE-N-L1-L2 for fastening screw 3 mm Ø or for self tapping screw 2.9 mm Ø from top without marking PE-N-L1-L2-L3 (pre-marked) L3-N-PE-L1-L2 (pre-marked) (pre-marked) L3-N-PE-L1-L2 (pre-marked) PE-N-L1-L2-L3 1 snap-in feet at pos. 2+4 without marking PE-N-L1-L2-L3 (pre-marked) L3-N-PE-L1-L2 (pre-marked) (pre-marked) L3-N-PE-L1-L2 (pre-marked) PE-N-L1-L2-L3 snap-in feet at pos. 1+3+5 without marking PE-N-L1-L2-L3 (pre-marked) L3-N-PE-L1-L2 (pre-marked) (pre-marked) L3-N-PE-L1-L2 (pre-marked) PE-N-L1-L2-L3 4 x 0.5 – 4 mm2 4 x AWG 20 –12 500 V/6 kV/2 300 V, 20 A 32 A 600 V, 5 A 2U l 10 – 11 mm / 0.41 in 4 poles /16 connection points 5 poles /20 connection points Item No. black Item No. white Pack.-unit pcs 862-0504 862-1504 862-2504 862-8504 862-9504 862-0604 862-1604 862-2604 862-8604 862-9604 200 200 200 200 200 862-0534 862-1534 862-2534 862-8534 862-9534 862-0634 862-1634 862-2634 862-8634 862-9634 200 200 200 200 200 862-0594 862-1594 862-2594 862-8594 862-9594 862-0694 862-1694 862-2694 862-8694 862-9694 200 200 200 200 200 Item No. black Item No. white Pack.-unit pcs 862-0505 862-1505 862-2505 862-8505 862-9505 862-0605 862-1605 862-2605 862-8605 862-9605 200 200 200 200 200 862-0525 862-1525 862-2525 862-8525 862-9525 862-0625 862-1625 862-2625 862-8625 862-9625 200 200 200 200 200 862-0515 862-1515 862-2515 862-8515 862-9515 862-0615 862-1615 862-2615 862-8615 862-9615 200 200 200 200 200 Ground (earth) contact Conductor connection Marking and testing • Makes an automatic contact to the mounting plate • Varnish coating is penetrated automatically • Four conductors per pole • For solid and flexible conductors • Mixed wiring with solid and flexible conductors of different cross sections • Marking by direct printing and/or marker strips • Testing with test plug 2 mm Ø 12 Terminal Blocks for Chassis Mounting, Series 862 Fastening Options is nto chass Fasten o w re sc m o g fr in Fasten lf tapp se y w b re to lf se om p ia sc Fasten v mm Ø) fr below via w .9 ) (2 Ø m m (3 scre and nut tapping ) into Ø m from top m (2.9 using o h terminal 12 0.47” (3mmØ) ia screw ssis Fasten v ad in cha into thre and nut ia screw Fasten v (3 mm Ø) from top 24 0.94” 36 1 .42” 24 0.94” 48 1 .89” ting feet -in moun ia snap stening v Fa Mounting foot, Item No. Pack.-unit pcs Mounting foot for DIN Rail mounting, Dimensions (mm) 209-120 Dimensions (in mm) 13 25 95 mm2/AWG 000 Rail-Mounted High Current Terminal Blocks Series 285 Wire connection 25 – 95 mm2 1000 V/8 kV/3- 232 A Commoning AWG 4 – 000 600 V, 200 A U 600 V, 2 10 A 2 Terminal block width 25 mm / 0.98 in * U2 CCA :4 Commoning with adjacent jumper. Insertion of jumper above the conductor entry hole, without tools. Rated cross section is still 95 mm2/AWG 000. Testing/Protective warning marker Colour Item No. ➌ Pack.-unit pcs 2-conductor through terminal blocks grey 285-195      5 blue 285-194      5 light grey      5 285-995 4 Counter-clockwise rotation using a hex wrench. Latch holds clamp in open position. 2-conductor ground (earth) terminal blocks green-yellow      5 285-197 green-yellow 285-197/999-950    5 • Testing with test plug 4 mm/0.157 in diameter. • Protective warning marker may indicate: 4 Accessories Appropriate marking system Attention! Voltage may be present despite main being switched off! circuit Voltage tap WMB Adjacent jumper, insulated, I N 232 A for 1 jumper I N 192 A for 2 to 4 jumper 285-495 25 grey Voltage tap, I N 57 A, 0.2 - 10/16 mm2 Module width 20 mm / 0.787 in grey 285-407    5 Hex wrench with partially insulated shaft 8 mm/0.32 in 285-172   1 Introduce stripped wire (stripped length 35 mm!) into the clamping unit up to the stop and hold it in position . . . Touch protection cover, for unused clamping units and jumper slots yellow 285-169 25 Reliable and simple tap directly onto the power supply. Insert the unwired tap before opening the pressure spring. Touch protection Protective warning marker, with high voltage symbol, for 5 terminal blocks 285-170 50 (2‑x‑25) yellow 4Suitable for Ex e II applications 25 – 95 mm2 AWG 4 – 000 750 V~, 195 A AWG 2 – 00 20 – 70 mm2 for ground (earth) conductor terminal blocks . . . A small counter-clockwise rotation releases the latch. Once the operating tool has been removed the conductor is safely clamped. * You can find approvals on the Internet at www.wago.us 14 Jumper contact slots can also be sealed individually. DIN Rail Mount Outlet Boxes, CPO Series Dimensions: Width: 60.2 mm / 2.37 in Height: 61 .1 mm / 2.41 in Length with connector: 108.7 mm / 4.28 in The WAGO CPO Series of DIN rail mount Convenient Power Outlets provides a convenient power source in the control cabinet, for laptops, solder irons, electrical screwdrivers, test equipment, lighting, etc. The CPO Series significantly reduces time, cost and frustration compared to the manual assembly of outlet boxes. • Ground pin located on top to prevent loose metal objects from inadvertently shorting the hot and neutral pins. • Power input terminal blocks with CAGE CLAMP® connection technology for fast, easy and maintenance-free wiring. • Power input terminal block is pre-marked for safe wiring. • Compact design takes up less space. • Complete family of solutions to choose from. • Built-in test point for easy troubleshooting. Item Number Pack.-unit pcs 51015045 1 51012222 1 51018358 1 51012216 1 Ground Fault Circuit Interrupt Outlet with load terminals to protect equipment downstream Surge-Protected Outlet Switched Box European "Schuko" Outlet 120 V 15 A 28 - 12 35 mm DIN rail UL Pending 120 V 15 A 28 - 12 35 mm DIN rail UL Pending 120 V 15 A 28 - 12 35 mm DIN rail 250 V 15 A 28 - 12 35 mm DIN rail Description Technical Data Rated Voltage Rated Current Rated AWG Mounting Approvals Item Number Pack.-unit pcs 51017543 1 51012218 1 Duplex Outlet 20 Amp Duplex Outlet 120 V 15 A 28 - 12 35 mm DIN rail 120 V 20 A 28 - 12 35 mm DIN rail Description 51018302 1 r 51012356 1 Isolated Ground Isolated Ground Outlet Outlet single connection double connection per pole per pole 51018351 1 51012352 1 51018377 1 51012312 1 Ground Fault Circuit Interrupt Outlet Ground Fault Circuit Interrupt Outlet; right angle connector to reduce wiring space Switched Controlled Outlet Outlet with separate switch 120 V 15 A 28 - 12 35 mm DIN rail 120 V 15 A 28 - 12 35 mm DIN rail UL Pending 120 V 15 A 28 - 12 35 mm DIN rail 120 V 20 A 28 - 12 35 mm DIN rail UL Pending Technical Data Rated Voltage Rated Current Rated AWG Mounting Approvals r r 125 V 15 A 28 - 12 35 mm DIN rail r 125 V 15 A 28 - 12 35 mm DIN rail UL Pending 15 r r Relay Socket with Small Switching Relay, Pluggable, Series 788 Relay socket with DC relay and status indication; 1 or 2 changeover contacts Relay socket with DC relay and status indication; 1 or 2 changeover contacts 0.34 – 2.5 mm2 AWG 22 – 14 Dimensions (W x H x L) 15 x 53 x 86 mm Relay height 15 mm File E 175199 L 9 – 10 mm / 0.37 in 0.34 – 2.5 mm2 AWG 22 – 14 Dimensions (W x H x L) 15 x 63 x 86 mm Relay height 25 mm L 9 – 10 mm / 0.37 in File E 175199 Item No. Pack.-unit pcs Item No. Pack.-unit pcs Single Pole/Double Throw Single Pole Double Throw 788-303 DC   12 V 788-304 DC   24 V 788-305 DC   48 V 788-306 DC   60 V 788-307 DC 110 V 788-323 DC 12 V 788-324 DC 24 V 788-528 AC 230 V 1 1 1 1 1 1 1 1 Single Pole Double Throw Double Pole Double Throw 788-506 AC 24 V 788-507 AC 115 V 788-508 AC 230 V 788-333 DC 12 V 788-334 DC 24 V 788-337 DC 110 V 788-538 AC 230 V 1 1 1 Double Pole Double Throw 788-311 DC   12 V 788-312 DC   24 V 788-313 DC   48 V 788-314 DC   60 V 788-315 DC 110 V 1 1 1 1 1 Double Pole Double Throw Accessories, Series 788 1 1 1 1 Comb type jumper bar, 2-way 788-113 859-402 Socket without relay for switching relay (15 mm high) 788-100 1 RT 15, SPDT 788-102 RT 15, DPDT 788-103 RT 25, DPDT 1 1 1 1 Switch status indication appropriate marking system WMB/WSB Status indication, with free-wheeling diode 788-120 DC   24‑V 788-121 DC   48‑V 788-122 DC 110‑V 788-123 AC   24‑V 788-124 AC 115‑V 788-125 AC 230‑V Socket without relay for switching relay (25 mm high) 788-101 1 RT 25, SPDT 788-512 DC 24 V 788-515 DC 115 V 788-516 DC 230 V Jumpering made easy Pluggable relays 1 CAGE CLAMP®S 16 Non-degrading Silicon Surge Suppression Devices, WAGO PROTECT Series Silicon Surge Suppression Devices WAGO PROTECT - 120 Vac, 240 Vac, 24 Vdc AWG 28 – 12 L 8 – 9 mm Non-Degrading Silicon Surge Suppression The WAGO-PROTECT series DIN rail mount surge suppressors are high speed, high current, solid state devices designed to protect sensitive electronic equipment (PLCs, PCs, etc.) from transient over voltages present on AC/DC power lines. Powered by patented Silicon Avalanche Suppressor Diode technology from Transtector, these suppressors provide the utmost in protection without degradation - unlike MOV based technology. Features: • Pluggable surge function module for easy maintenance and replacement • Fast, vibration-proof, and maintenance-free wiring with CAGE CLAMP® • LED fail mode indication as well as relay alarm output connection • Built-in test points for easy troubleshooting and maintenance Item No. Pack.-unit pcs WAGO Protect 120, Non-degrading silicon surge suppression devices, 120 Vac pluggable module, with receptacle base 51018058 1 ea Nominal Voltage Max. Continuous Voltage Max. Nominal Current Leakage Current Voltage Protection Level (min./max. V Peak) Power Dissipation (based on IEEE ANSI c62.41-1991) at 20/80µs (transient waveform lightning induced) at 10/100µs (transient waveform other source induced) Response Time (nano seconds) Temperature Range Ingress Protection Level (IEC) Insulating Housing Wire Ternmination Type Wire Strip Length Wire Range Wiring Configurations Dimensions (mm) Approvals Item No. Pack.-unit pcs WAGO Protect 240, Non-degrading silicon surge suppression devices, 240 Vac pluggable module, with receptacle base 51018059 1 ea Item No. Pack.-unit pcs WAGO Protect 24, Non-degrading silicon surge suppression devices, 24 Vdc pluggable module, with receptacle base 51017375 1 ea 120 Vac 140 V RMS 20 A None 220/330 Vp 240 Vac 280 V RMS 20 A None 440/660 Vp 24 Vdc 36 V RMS 20 A None 60 Vp 1.3kA 1.3kA 2kA 400 A 400 A 600 A
215-911 价格&库存
很抱歉,暂时无法提供与“215-911”相匹配的价格&库存,您可以联系我们找货
