Ha-VIS eCon 2000 Full Gigabit Ethernet Basic
5 to 7 Ethernet ports RJ45 and FOC
English
Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0 °C ... +55 °C / Industrial
temp.: -40 °C ... +70 °C
Energy
Efficient
Ethernet
■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE
802.3
■ Support of jumbo frames (10 kB)
■ Variants with industrial temperature range of -40 °C ... +70 °C
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General Description
The Ha-VIS eCon 2000 Full Gigabit family of unmanaged Ethernet switches is
equipped with up to 7 gigabit Ethernet ports and allow for cost-efficient and
quick expansion and/or reconstruction of network infrastructures with high
bandwidth requirements. In this, all switches support extra-long Ethernet
frames (jumbo frames). Due to the extremely flat design, these switches
can be accommodated in installations where space is restricted towards the
cable connection at the front. The selection includes various combinations
of variants with RJ45 and fibre optic ports. Automatic detection of the
transmission rate (auto-negotiation) and of the wiring of the twisted pair
data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play.
All variants are available with the temperature ranges "Industrial" and
"Commercial".
Technical characteristics
Switch features
Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE
Enclosure width
60 mm
120 mm
Number of ports
5
7
Type of connection
RJ45
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Frame size
Auto-MDI(X)
10 kBytes
MAC table size
Transfer conditions
8k entries
Transfer speed
10 / 100 / 1000 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Paket buffer size
1 Mbit
Non-blocking
Yes
Quality of service
Yes
Energy-efficient Ethernet
Yes
PROFINET-compatible
Yes
EthernetIP-compatible
Yes
Yes
Twisted pair
Ethernet ports 1000BASE-SX / 1000BASE-LX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
Wavelength
Power supply
FOC
850 nm
Transfer speed
Nominal voltage
24 VDC
Permissible voltage range
48 VDC
9 VDC ... 60 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Starting current
1.60 A
Overcurrent protection at input
Input sensitivity
3.20 A
Yes (2/4 A)
Max. power consumption
@ 24 VDC
3.22 W ... 4.78 W
Conductor cross-section
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
Type of connection
Pinout
3-pole, pluggable screw type terminal block
Supply circuit (according to 60950)
Transfer length
Output power
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
Single-mode (SM)
SC Duplex
1310 nm
1000 Mbit/s
0.55 km
10 km
-9.5 dBm ... -4 dBm
-9.5 dBm ... -3 dBm
≤ -17 dBm
≤ -21 dBm
Environmental conditions
Commercial temperature range
Industrial temperature range
Storage temperature range
0 °C ... +55 °C
-40 °C ... +70 °C
-40 °C ... +85 °C
Relative humidity (operation)
0% ... 95 % (not-condensing)
Relative humidity (storage and
transport)
Air pressure (operation)
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
Enclosures
Enclosure width
Dimensions H x W x D (without
block and holding bracket)
60 mm
120 mm
113.5 mm x
60 mm x
27.3 mm
113.5 mm x
120 mm x
27.3 mm
205 g
378 g ... 393 g
Weight
Type of installation
35 mm DIN rail acc. to EN 60 715
Enclosures material
Anodised aluminium
Protection class (with plugged
screwed contact)
IP30
Protection class
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
10 Mbit/s
Link speed ("Spd") illuminated yellow
100 Mbit/s
Link speed ("Spd") illuminated green
1000 Mbit/s
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
III
Status and diagnostic displays
Power ("Pwr")
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Vibrationresonance search
IEC 60068-2-27 Shock test
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
Drawings
Technical characteristics / order information
Ports / order information
Commercial Temp.: 0 °C ... +55 °C
RJ45
SFP
SC
Enclosure
width
Power consumption @ 24 VDC
MTBF
in million h
Switch
4
3x MM (0.55 km)
120 mm
185 mA
1.69
4
3x SM (10 km)
120 mm
199 mA
1.69
5
60 mm
134 mA
5
2x MM (0.55 km)
120 mm
5
2x SM (10 km)
6
6
7
Industrial Temp.: -40 °C ... +70 °C
Part no.
Switch
Part no.
Ha-VIS eCon 2043GB-AD
24 02 404 3110
Ha-VIS eCon 2043GBT-AD
24 02 404 3100
Ha-VIS eCon 2043GB-AF
24 02 404 3210
Ha-VIS eCon 2043GBT-AF
24 02 404 3200
3.06
Ha-VIS eCon 2050GB-A
24 02 405 0010
Ha-VIS eCon 2050GBT-A
24 02 405 0000
184 mA
1.69
Ha-VIS eCon 2052GB-AD
24 02 405 2110
Ha-VIS eCon 2052GBT-AD
24 02 405 2100
120 mm
194 mA
1.69
Ha-VIS eCon 2052GB-AF
24 02 405 2210
Ha-VIS eCon 2052GBT-AF
24 02 405 2200
1x MM (0.55 km)
120 mm
183 mA
1.69
Ha-VIS eCon 2061GB-AD
24 02 406 1110
Ha-VIS eCon 2061GBT-AD
24 02 406 1100
1x SM (10 km)
120 mm
190 mA
1.69
Ha-VIS eCon 2061GB-AF
24 02 406 1210
Ha-VIS eCon 2161GBT-AF
24 02 406 1200
120 mm
182 mA
1.70
Ha-VIS eCon 2070GB-A
24 02 407 0010
Ha-VIS eCon 2070GBT-A
24 02 407 0000
Copyright© 2014
All rights reserved
Date of issue 05.2015
ICPN Datasheet 0838/02
很抱歉,暂时无法提供与“24024050000”相匹配的价格&库存,您可以联系我们找货
