24034060020
24034060020
    HARTING(浩亭)
24034060020 数据手册
Ha-VIS eCon 3000 Full Gigabit Ethernet Basic PoE / PoE+ 5 to 7 Ethernet ports RJ45, FOC, and PoE / PoE+ English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial ­­ temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in accordance with IEEE 802.3at ■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3 ■ Support of jumbo frames (10 kB) ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet ■ Optimised DIN rail bracket Target markets Machinery & Robotics Wind Energy, Solar Energy Industrial network infrastructures Automation Transportation Shipbuilding General description The Ha-VIS eCon 3000 Full Gigabit family of unmanaged Ethernet switches is equipped with up to 7 gigabit Ethernet ports and allows for cost-efficient and quick expansion and/or reconstruction of network infrastructures with high bandwidth requirements. In this, all variants support extra-long Ethernet frames (jumbo frames). The switches work as power sourcing equipment (PSE) and are capable of simultaneously providing the full PoE output of 34.2 watts on up to four ports. The slender design of the switches enables an extremely high packing density on the DIN rail. The selection includes various combinations of variants with RJ45 and fibre optic cables. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch Features Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE Enclosure width 25 mm Type of connection RJ45 Number of ports 5, 6, 7 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame size Auto-MDI(X) 10 kBytes MAC table size Transfer conditions 8k entries Transfer speed 10 / 100 / 1000 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Packet buffer size 1 Mbit Non-blocking Yes Quality of Service Yes Energy-efficient Ethernet Yes PROFINET-compatible Yes EthernetIP-compatible Yes Ethernet ports 100BASE-SX / 100BASE-FX Type of fibre 24 VDC 48 VDC Surge protection Yes Reverse polarity proof Yes Starting current 3.20 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout 54 VDC 9 VDC ... 60 VDC 6.40 A Output power Input sensitivity 7.20 A Yes (12 A) 3.84 W ... 4.56 W 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches FOC 850 nm Transfer speed Transfer length Single-mode (SM) SC Duplex Transfer conditions Wavelength Permissible voltage range Multi-mode (MM) Type of connection Power supply Nominal voltage Yes Twisted pair 1310 nm 1000 Mbit/s 0.55 km 10 km -9,5 dBm ... -3 dBm -9,5 dBm ... -4 dBm ≤ -17 dBm ≤ -21 dBm SFP ports Transfer standard Depending on used SFP Type of connection Depending on used SFP, RJ45 or LC Transfer conditions Depending on used SFP, TP or FOC Transfer speed Transfer length Depending on used SFP, 100 or 1000 Mbit/s Depending on used SFP Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. PoE Enclosures Number of PoE ports 4 Standard IEEE 802.3af / IEEE 802.3at PoE type PSE Supported mode Alternative A Power supply PSE 48 VDC 54 VDC Maximum power consumption PSE 1380 mA 2380 mA Maximum current (PoE / PoE+) 375 mA 638 mA 15.4 W per port 61.6 W total 34.2 W per port 136.8 W total Maximum output power PSE Supported cabling See 802.3at, section 33.1.4 PoE pinout Alternative A, MDI-X (1/2 = V-, 3/6 = V+) Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green Link is active Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s Link speed ("Spd") illuminated green 1000 Mbit/s PoE status off PoE status illuminated green Voltage in PoE range PoE status illuminated blue Voltage in PoE+ range PoE status illuminated red Fault PoE is inactive / low voltage Ambient conditions Commercial temperature range -40 °C ... +70 °C Storage temperature range -40 °C ... +85 °C Relative humidity (operation) 0 % ... 95 % (non-condensing) Relative humidity (storage and transport) 0 % ... 95 % (non-condensing) Air pressure 25 mm 142 mm x 25 mm x 107.5 mm Weight 498 g ... 513 g Type of installation 35 mm DIN rail acc. to EN 60 715 Material enclosures Anodised aluminium / powder-coated steel sheet Protection class (with pluggable screw type terminal block) IP30 Protection class III Approvals CE FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions 0° C ... +55 °C Industrial temperature range Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) 2000 m (795 hPa) Drawings Technical characteristics / order information Ports / order information RJ45 SFP SC Enclosure width Power consumption @ 24 VDC without PoE 4 - 1x MM (0.55 km) 25 mm 4 - 1x SM (10 km) 25 mm 4 - 2x MM (0.55 km) 4 - 4 Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C MTBF in million h Switch Part no. Switch Part no. 0.17 A 1.13 Ha-VIS eCon 3041GB-AD-P 24 03 404 1130 Ha-VIS eCon 3041GBT-AD-P 24 03 404 1120 0.17 A 1.13 Ha-VIS eCon 3041GB-AF-P 24 03 404 1230 Ha-VIS eCon 3041GBT-AF-P 24 03 404 1220 25 mm 0.19 A 1.11 Ha-VIS eCon 3042GB-AD-P 24 03 404 2130 Ha-VIS eCon 3042GBT-AD-P 24 03 404 2120 2x SM (10 km) 25 mm 0.19 A 1.11 Ha-VIS eCon 3042GB-AF-P 24 03 404 2230 Ha-VIS eCon 3042GBT-AF-P 24 03 404 2220 3 - 25 mm 0.18 A 0.70 Ha-VIS eCon 3043GB-AC-P 24 03 404 3330 Ha-VIS eCon 3043GBT-AC-P 24 03 404 3320 5 - - 25 mm 0.16 A 1.08 Ha-VIS eCon 3050GB-A-P 24 03 405 0030 Ha-VIS eCon 3050GBT-A-P 24 03 405 0020 5 - 1x MM (0.55 km) 25 mm 0.19 A 1.06 Ha-VIS eCon 3051GB-AD-P 24 03 405 1130 Ha-VIS eCon 3051GBT-AD-P 24 03 405 1120 5 - 1x SM (10 km) 25 mm 0.19 A 1.06 Ha-VIS eCon 3051GB-AF-P 24 03 405 1230 Ha-VIS eCon 3051GBT-AF-P 24 03 405 1220 5 2 - 25 mm 0.19 A 0.68 Ha-VIS eCon 3052GB-AC-P 24 03 405 2330 Ha-VIS eCon 3052GBT-AC-P 24 03 405 2320 6 - - 25 mm 0.18 A 1.01 Ha-VIS eCon 3060GB-A-P 24 03 406 0030 Ha-VIS eCon 3060GBT-A-P 24 03 406 0020 6 1 - 25 mm 0.19 A 0.66 Ha-VIS eCon 3061GB-AC-P 24 03 406 1330 Ha-VIS eCon 3061GBT-AC-P 24 03 406 1320 7 - - 25 mm 0.19 A 0.63 Ha-VIS eCon 3070GB-A-P 24 03 407 0030 Ha-VIS eCon 3070GBT-A-P 24 03 407 0020 Copyright© 2014 HARTING Technology Group All rights reserved Date of issue 02.2015 ICPN Datasheet 0850/01
24034060020 价格&库存
很抱歉,暂时无法提供与“24034060020”相匹配的价格&库存,您可以联系我们找货
  • 1+7444.473541+933.91110
  • 5+6996.798085+877.75010
