Data sheet | Item number: 788-304
Relay module; Nominal input voltage: 24 VDC; 1 changeover contact;
Limiting continuous current: 16 A; Red status indicator; Module width: 15
mm; 2,50 mm2; gray
www.wago.com/788-304
Similiar to
Color:
Current-carrying capacity curve
06.10.2019 Page 1/11
DC load limit curve
Item description
Note:
Reinforced insulation between coil and contacts
A separator plate (e.g., 209-191) must be used for voltages greater than 250 V between adjacent relay modules and for compliance with the
reinforced insulation requirements.
To protect the relay coils and contacts, inductive loads must be dampened with an effective protection circuit.
Data
Technical Data
Control circuit
Nominal input voltage UN
DC 24 V
Input voltage range
±10 %
Nominal input current at UN
19 mA
Load circuit:
Number of changeover/switchover contacts
1
Contact material (relay)
AgNi 90/10
16 A
Max. make current (resistive)
(AC) 30 A / 4 s
Max. switching voltage
AC 250 V
Max. switching power (resistive)
AC 4000 VA; DC see load limit curve
Switching capacity
AC-15: 6 A / AC 250 V; DC-13: 2 A / DC 24 V
Recommended minimum load
12 V / 10 mA
06.10.2019 Page 2/11
12 V / 10 mA
Pull-in time (typ.)
8 ms
Drop-out time (typ.)
6 ms
Bounce time (typ)
6 ms
Electrical life (N.O.; resistive load; 23 °C)
30 x 103 switching operations
Mechanical life
30 x 106 switching operations
Max. switching load with load/without load
6 min-1 / 1200 min-1
Signaling
Status indication
LED red
Safety and protection:
Rated voltage
250 V
Rated impulse voltage
4 kV
Pollution degree
3
Dielectric strength, control/load circuit (AC, 1 min)
5 kVrms
Dielectric strength open contact (AC, 1 min)
1 kVrms
Protection class
IP20
Connection data
Connection technology
Push-in CAGE CLAMP®
Solid conductor
0.34 … 2.5 mm² / 22 … 14 AWG
Fine-stranded conductor
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Geometrical Data
Width
15 mm / 0.591 inch
Height from upper-edge of DIN-35 rail
54 mm / 2.126 inch
Depth
86 mm / 3.386 inch
Mechanical data
Type of mounting
DIN-35 rail
Material Data
Color
gray
Fire load
0.915 MJ
Weight
45.918 g
Environmental Requirements
06.10.2019 Page 3/11
Pollution degree
3
Surrounding air (operating) temperature at UN
-40 … 70 °C
Surrounding air (storage) temperature
-40 … 70 °C
Processing temperature
-25 … +50 °C
Standards and specifications
Standards/specifications
EN 61010-2-201; EN 61810-1; EN 61373; UL 508 (max. 10 A)
Elementary relay
WAGO elementary relay
788-154
Commercial data
Product Group
6 (Interface Electronics)
Country of origin
CN
GTIN
4055143184113
Customs Tariff No.
85364900990
Approvals / Certificates
UL-Approvals
Logo
Approval
Additional Approval Text
UL
UL International Netherlands B.V. (ORDINARY
LOCATIONS)
UL 508
Certificate
name
E175199
Sec.6
Compatible products
ferrule
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped;
www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
06.10.2019 Page 4/11
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-542
Twin ferrule; Sleeve for 2 x 1 mm² / AWG 2 x 18; red, insulated; 12 mm long; red
www.wago.com/216-542
Item no.: 788-113
Comb-style jumper bar; 2-way; insulated
www.wago.com/788-113
Item no.: 788-114
Comb-style jumper bar; 3-way; insulated
www.wago.com/788-114
Item no.: 788-115
Comb-style jumper bar; 4-way; insulated
www.wago.com/788-115
Item no.: 788-116
Comb-style jumper bar; 6-way; insulated
www.wago.com/788-116
Item no.: 788-117
Comb-style jumper bar; 8-way; insulated
www.wago.com/788-117
Item no.: 788-118
Comb-style jumper bar; 2-way (1-3); insulated
www.wago.com/788-118
Item no.: 859-402
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-402
Item no.: 859-402/000-005
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-402/000-006
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-402/000-029
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; yellow
/000-029
Jumper
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
06.10.2019 Page 5/11
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 209-128
Adaptor
www.wago.com/209-128
Item no.: 209-183
Marker card; white
www.wago.com/209-183
Item no.: 210-110
Fiber-tip pen
www.wago.com/210-110
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-502
06.10.2019 Page 6/11
Item no.: 793-502
WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type;
white
www.wago.com/793-502
Item no.: 793-502/000-002
yellow
/000-002
Item no.: 793-502/000-005
red
/000-005
Item no.: 793-502/000-006
blue
/000-006
Item no.: 793-502/000-007
gray
/000-007
Item no.: 793-502/000-012
orange
/000-012
Item no.: 793-502/000-017
light green
/000-017
Item no.: 793-502/000-023
green
/000-023
Item no.: 793-502/000-024
violet
/000-024
Item no.: 793-503
WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-503
white
Item no.: 793-503/000-002
/000-002
white
Item no.: 793-503/000-005
/000-005
white
Item no.: 793-503/000-006
/000-006
white
Item no.: 793-503/000-007
/000-007
white
Item no.: 793-503/000-012
/000-012
white
Item no.: 793-503/000-017
06.10.2019 Page 7/11
/000-017
white
Item no.: 793-503/000-023
/000-023
white
Item no.: 793-503/000-024
/000-024
white
Item no.: 793-504
WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-504
white
Item no.: 793-504/000-002
/000-002
white
Item no.: 793-504/000-005
/000-005
white
Item no.: 793-504/000-006
/000-006
white
Item no.: 793-504/000-012
/000-012
white
Item no.: 793-504/000-017
/000-017
white
Item no.: 793-504/000-023
/000-023
white
Item no.: 793-505
WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-505
white
Item no.: 793-505/000-005
/000-005
white
Item no.: 793-505/000-006
/000-006
white
Item no.: 793-505/000-007
/000-007
white
Item no.: 793-505/000-012
/000-012
white
Item no.: 793-506
06.10.2019 Page 8/11
Item no.: 793-506
WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-506
white
Item no.: 793-506/000-005
/000-005
white
Item no.: 793-506/000-006
/000-006
white
Item no.: 793-506/000-012
/000-012
white
Item no.: 793-506/000-017
/000-017
white
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-5501/000-006
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-5501/000-012
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-5501/000-014
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown
/000-014
Item no.: 793-5501/000-017
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-5501/000-023
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 793-566
06.10.2019 Page 9/11
Item no.: 793-566
WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type;
white
www.wago.com/793-566
Item no.: 793-566/000-002
white
/000-002
Item no.: 793-566/000-005
red
/000-005
Item no.: 793-566/000-006
white
/000-006
Item no.: 793-566/000-007
white
/000-007
Item no.: 793-566/000-012
white
/000-012
Item no.: 793-566/000-017
white
/000-017
Item no.: 793-566/000-023
white
/000-023
Item no.: 793-566/000-024
white
/000-024
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
tools
General accessories
Item no.: 209-145
Group marker carrier
www.wago.com/209-145
Item no.: 209-184
Protection cover; transparent
www.wago.com/209-184
Item no.: 249-105
www.wago.com/249-105
Item no.: 788-120
Accessories for relay modules; Operation status indicator: red
www.wago.com/788-120
Item no.: 788-154
Basic relay; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 16 A;
Module width: 13 mm; Module height: 15 mm
www.wago.com/788-154
Downloads
06.10.2019 Page 10/11
Downloads
Documentation
Bid Text
788-304
Apr 4, 2012
docx
16.7 kB
Download
V 1.0.0
pdf
2.4 MB
Download
V 1.0.0
pdf
265.8 kB
Download
URL
Download
Relaisbaustein
Instruction Leaflet
Sockets with Elementary Relay/ SSR
Additional Information
Disposal; Electrical and electronic equipment, Packaging
CAD/CAE-Data
CAD data
3D Download 788-304
EPLAN
EPLAN Data Portal 788-304
Download
WSCAD
WSCAD Universe 788-304
Download
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
06.10.2019 Page 11/11
很抱歉,暂时无法提供与“788-113”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.097501+2.21264
- 10+14.5627210+1.88461
- 25+13.6456025+1.76592
- 50+12.9932550+1.68150
- 100+12.37181100+1.60108
- 250+11.59663250+1.50076
- 500+11.04286500+1.42909
- 1000+10.515811000+1.36088
- 2500+9.857732500+1.27572
