9320006207
9320006207
    HARTING(浩亭)
    Contact SKT Crimp ST Cable Mount ; Region : ACNA
9320006207 数据手册
Han® Q 2/0 Crimp HV Size 3 A 830  V 40  A Number of contacts 2+ Part number Identification Male insert (M) Female insert (F) Drawing Dimensions in mm Crimp terminal with heat shrink tube order crimp contacts separately 09 12 002 3052 09 12 002 3152 Contact arrangement view from termination side Coding element 09 12 000 9922 Identification Wire gauge (mm²) 09 12 000 9922 Part number Male contact Female contact Drawing Dimensions in mm Crimp contacts Power contacts silver plated 1.5 2.5 4 6 10 09 32 000 6104 09 32 000 6105 09 32 000 6107 09 32 000 6108 09 32 000 6109 09 32 000 6204 09 32 000 6205 09 32 000 6207 09 32 000 6208 09 32 000 6209 Wire gauge 1.5 2.5 4 6 10 mm² mm² mm² mm² mm² AWG 16 AWG 14 AWG 12 AWG 10 AWG 8 ∅ Stripping length 1.75 2.25 2.85 3.5 4.3 9 mm 9 mm 9.6 mm 9.6 mm 12 mm Han® Data Sheet 0604 Han® Q 2/0 Crimp High Voltage Features Technical characteristics Inserts • High current rated compact designed connector for hoods/housings size Han® 3 A • Mating compatible to the axial screw version with 16 coding options • Using of standard Han C crimp contacts and crimp tools wich allows a cost optimised production of high quantities • For high voltages, please use heat shrink tube • Finger protected male and female contacts Remark • By using in Han 3 A HPR hoods/housings the sealing on the insert has to be removed. ® Number of contacts Electrical data acc. to EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - mating cycles Contacts Tools Current Carrying Capacity Operating current (A) The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly, without exceeding the allowed maximum temperature. Measuring and testing techniques according to DIN EN 60 512-5 40 A 830 V 6 kV 3 40 A 830 V 6 kV 3 ≥ 1010 Ω polycarbonate -40 °C ... 125 °C V0 ≥ 500   Material Surface - hard-silver plated Contact resistance Crimp termination - mm² - AWG   2 + PE copper alloy 3 µm Ag ≤ 1 mΩ 1.5 ... 10 mm² 16 ... 8 see chapter 99 in the main catalogue „Industrial Connectors Han®“   Hoods/Housings Selection of hoods/housings Plastic hoods/housings Material Flammability acc. to UL 94 Degree of protection acc. to DIN EN 60 529 for coupled connector Metal hoods/housings Material Degree of protection acc. to DIN EN 60 529 for coupled connector see Han® main catalogue chapter 30 / chapter 31 polycarbonate V0 IP 67 zinc die-cast IP 44 IP 67 is achieved with seal screw 09 20 000 9918 Ambient temperature (°C) ① wire gauge: 2.5 mm² ② wire gauge: 4 mm² ③ wire gauge: 6 mm² ④ wire gauge: 10 mm² HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Fon: +49 57 72 47-97100 | Fax: +49 57 72 47-124 Internet: www.HARTING.com | E-Mail: HARTING.Electric@HARTING.com 2011-03-15
9320006207 价格&库存
很抱歉,暂时无法提供与“9320006207”相匹配的价格&库存,您可以联系我们找货
