VH CONNECTOR
High box type
3.96mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
• Current rating: 7 A AC, DC (AWG #18)
10 A AC, DC (AWG #16)/1 circuit only
• Voltage rating: 250 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #22 to #16
• Applicable PC board thickness: 1.6 mm
Note:
Do not branch in parallel current which exceeds the rated current. If branched in
parallel, current imbalance or other problems may develop. If it is absolutely
necessary to branch such a large current in parallel, be sure to use contacts
made of phosphor bronze. Design the circuits without causing imbalance and
provide an extra margin for each circuit.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
This is VH connector high box type, with
21.3 mm mounting height (single circuit:
18.6 mm) and with 9.2 mm thickness (single
circuit: 8 mm). This connector exhibits the
stable electric connection to the condition
such as the vibration, the prying, the microcurrent and micro-voltage circuit.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2 R75122
• Header for use specifically with resin coated
("potted") PC board
• Interchangeability
PC board layout and Assembly layout
10.6
10.5
±0.1
8
+0.1
1.3 0
+0.1
1.3
±0.05
+0.1
(21.3)
±0.05
(18.6)
+0.1
φ1.65 0
3.4
+0.1
φ1.65
φ1.4 0
3.96
±0.1
3.6
±0.1
3.6
0.8
±0.1
±0.05
Note: 1. The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guide line. Contact JST for details.
1
VH CONNECTOR High box type
Contact
Applicable wire
Model No.
SVH-21T-P1.1
*SVH-41T-P1.1
10.6
3
4.2
4
mm2
AWG#
Insulation O.D.
(mm)
Q't y/
reel
0.33∼0.83
22∼18
1.7∼3.0
4,500
0.5 ∼1.25
20∼16
1.7∼3.0
3,500
Material and Finish
3.8
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note: 1. *The current rating when combining with single circuit is 10 A AC, DC
(AWG #16.)
2. When using retainer mountable type housing, applicable wire's
insulation O. D. shall be 1.7 to 2.2 mm.
Crimping
machine Crimp applicator
Contact
SVH-21T-P1.1
AP-K2N
Applicator
Dies
MKS-L
MK/SVH-21-11
APLMK SVH21-11
*MKS-SC
SC/SVH-21-11
APLSC SVH21-11
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SVH-41-11
APLMK SVH41-11
Crimping
Contact
SVH-41T-P1.1
AP-K2N
Note: *Strip-crimp applicator
Housing
N Type
Circuits
6.2
1
B
2
A
3
4
5.7
10.5
5
6
7
H JST
8
N type
VHR-1N
VHR-2N
VHR-3N
VHR-4N
VHR-5N
VHR-6N
VHR-7N
VHR-8N
Model No.
Retainer mountable type
VHRR-3N
VHRR-5N
VHRR-7N
VHRR-8N
Dimensions (mm)
A
B
Q'ty/
bag
1,000
3.96
7.86
7.92
11.82
1,000
11.88
15.78
15.84
19.74
19.80
23.70
500
23.76
27.66
500
27.72
31.62
500
1,000
Material
13.3
14.6
PA 6, UL94V-0, natural (white)
RoHS compliance
* N type ; 1,000 Retainer mountable type ; 500
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex. VHR-2N-oo(blank)…natural (white)
BK…black R…red BL…blue M…green D…orange
Y…yellow PK…pink H…gray
B
15
5.7
10.5
A
2
Retainer
Model No.
VHS-3V
VHS-5V
VHS-7V
VHS-8V
Circuits
3
5
7
Q’ty/bag
1,000
15.44
1,000
23.36
1,000
27.32
1,000
Material
A
4.2
8
A
7.52
Glass-filled PA 66, UL94V-0, natural (ivory)
RoHS compliance
7.1
Shrouded header
Model No.
With a boss
BH1P-VH-1
Circuits
With a boss
1
Q'ty/box
500
Material and Finish
9.1
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL-94V-0, natural (white)
3
4
13.4
RoHS compliance This product displays (LF)(SN) on a label.
ex. BH1P-VH-1-oo(blank)…natural (white) BK…black R…red BL…blue
M…green O…orange Y…yellow PK…pink
8
□1.14
Circuits
2
3
4
B
5
9.2
6
7
15.8
8
3.5
φ1.2
3.96
A
1.5
Dimensions (mm)
A
B
Q'ty/
box
3.96
9.80
250
7.92
13.76
200
11.88
17.72
150
15.84
21.68
100
19.80
25.64
100
23.76
29.60
100
27.72
33.56
100
Material and Finish
Wafer: Glass-filled PA 66, UL-94V-0, natural (ivory)
1.5
□1.14
Model No.
With a boss
BH2P-VH-1
BH3P-VH-1
BH4P-VH-1
BH5P-VH-1
BH6P-VH-1
BH7P-VH-1
BH8P-VH-1
3.4
ex. BH2P-VH-1-oo(blank)…natural (ivory) BK…black R…red BL…blue
M…green Y…yellow
3
3
BH2P-VH-1-R(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BH2P-VH-1-R(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.648841+0.34239
- 10+2.3516110+0.30397
- 50+1.8096050+0.23391
- 100+1.44244100+0.18645
- 500+1.37250500+0.17741
- 1000+1.320051000+0.17063
- 2000+1.293822000+0.16724
