DF51K-22SCF(800)
DF51K-22SCF(800)
    HRS(广濑)
    DF51K-22SCF(800)
DF51K-22SCF(800) 数据手册
DESCRIPTION OF REVISIONS COUNT BY CHKD DATE △ △ APPLICABLE STANDARD May.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. DESCRIPTION OF REVISIONS COUNT BY CHKD DATE △ △ Operating Temperature Range Operating Humidity Range Storage Temperature Range Storage Humidity Range -55℃ to +105℃ (Note1) 20% to 80% (Note2) RATING Applicable Connector DF51K-*(D)S-2C (###) Applicable Cable -10℃ to +60℃ (Note3) 40% to 70% (Note3) Voltage 250V AC/DC Current AWG 22 : 2A AWG#22 Insulation Diameter φ1.2 ∼ φ1.45 mm SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT CONSTRUCTION General Examination Visually and by measuring instrument. Marking Confirmed visually. According to drawing. O O O O O - O - O - O - O - O - O - ELECTRICAL CHARACTERISTICS Contact Resistance 20mV MAX, 1mA (DC or 1000Hz). 30 mΩ MAX. Millivolt Level Method MECHANICAL CHARACTERISTICS Mechanical Operation 30 times insertion and extraction. ①Contact resistance: 30mΩ MAX ②No damage, crack or looseness of parts. (Sn Plating) Mechanical Operation 50 times insertion and extraction. ①Contact resistance: 30mΩ MAX ②No damage, crack or looseness of parts. (Au Plating) Vibration Frequency 10 to 55 Hz, single amplitude 0.75 mm, ①No electrical discontinuity of 1μs. at 10 cycles for 3 direction. ②No damage, crack or looseness of parts. Acceleration 490 m/s2 duration of pulse 11 ms at 3 Shock times for 3 directions. ENVIRONMENTAL CHARACTERISTICS Damp Heat Exposed at 40 ± 2 ℃ , humidity 90 to 95 %, 96 h. ①Contact resistance: 30 mΩ MAX. (Steady State) (After leaving the room temperature for 1 to 2h.) Rapid Change of Temperature -55 ℃→ +105 ℃ Temperature Time 30min→ 30min ②No damage, crack or looseness of parts. ①Contact resistance: 30 mΩ MAX. Under 5 Cycles. ②No damage, crack or looseness of parts. (The transferring time of the tank is 2 to 3 MIN) (After leaving the room temperature for 1 to 2h.) Remarks Note 1: Include the temperature rising by current. Note 2: No condensing Note 3: Apply to the condition of long term storage for unused products before pcb on board, after pcb board , operating temperature and   humidity range is applied for interim storage during transportation. DRAWN DESIGNED CHECKED APPROVED J.S CHOI J.S CHOI S.M.LIM T.S KANG 17.12.22 17.12.22 17.12.22 17.12.22 RELEASED Unless otherwise specified, refer to IEC 60512. NOTE QT: QUALIFICATION TEST AT: ASSURANCE TEST O: APPLICABLE TEST HIROSE KOREA CO.,LTD. CODE NO.(OLD) CL SPECIFICATION SHEET DRAWING NO. ELC4-611493 CODE NO. PART NO. DF51K-22SCF (800) CL 6652-0039-4-800 F-1-021(Rev.0) 1 1
DF51K-22SCF(800) 价格&库存
很抱歉,暂时无法提供与“DF51K-22SCF(800)”相匹配的价格&库存,您可以联系我们找货
DF51K-22SCF(800)
    • 1+0.34760
    • 2000+0.26070
    • 50000+0.17380
    库存:7332
    DF51K-22SCF(800)
      DF51K-22SCF(800)
        库存:28185
