ESQ-123-14-L-S
ESQ-123-14-L-S
    SAMTEC(申泰)
    ELEVATED SOCKET STRIPS
ESQ-123-14-L-S 数据手册
ELEVATED SOCKETS (2.54 mm) .100" PITCH • ESW/ESQ SERIES ESW/ESQ Mates: TSW, MTSW, EW, MTLW, TSS, ZSS, TSM, DW, ZW, HW, TSSH, HTSS SPECIFICATIONS Insulator Material: Black Glass Filled Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (ESW/TSW): 5.2 A per pin (2 pins powered) Current Rating (ESQ/TSW): 5.7 A per pin (2 pins powered) Voltage Rating: 515 VAC mated with TSW or ESQ Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Max Cycles: 100 with 10 µ" (0.25 µm) Au SERIES ESW = Solder Tail - NO. PINS PER ROW LEAD STYLE 01 thru 36 Specify LEAD STYLE from chart ESQ = Square Tail - - PLATING OPTION ROW OPTION –L –S = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail = Single Row –D = Double Row –G –T = 20 µ" (0.51 µm) Gold contact, Gold Flash on Balance STANDARD LOW INSERTION INSERTION FORCE FORCE = Triple Row (ESQ only) - OTHER OPTION –LL = Locking Lead (Two leads per strip crimped. Not available with single row 1 or 2 positions) “XXX” = Polarized –T LEAD STYLE PROCESSING Lead-Free Solderable: No, Lead Wave only -1 A B – 12 – 37 (2.29) .090 – 13 – 38 (7.36) .290 = Matte Tin (Not available with LIF contact) (11.05) .435 – 23 – 48 (4.83) .190 (13.59) .535 – 33 – 58 (2.29) .090 (16.13) .635 (12.19) .480 (11.05) .435 – 14 – 39 – 24 – 49 (9.65) .380 (13.59) .535 – 34 – 59 (7.11) .280 (16.13) .635 – 44 – 69 (4.57) .180 (18.67) .735 (2.54) .100 X No. of Positions + (0.51) .020 —S (2.41) .095 —D (4.95) .195 —T (ESQ only) (7.49) .295 APPLICATIONS (ESQ SERIES) PC/104 J1/P1 “Stackthrough” Connectors Standard Insertion Force ESQ-132-14-G-D Low Insertion Force ESQ-132-39-G-D PC/104™ J1 “Non-Stackthrough” Connectors Standard Insertion Force ESQ-132-12-G-D Low Insertion Force ESQ-132-37-G-D PC/104™ J2/P2 “Stackthrough” Connectors Standard Insertion Force ESQ-120-14-G-D Low Insertion Force ESQ-120-39-G-D ™ B ALSO AVAILABLE MOQ Required PC/104 is a trademark of the PC/104 Consortium. Other Platings A Note: Some lengths, styles and options are non-standard, non-returnable. (2.54) .100 TYP ESW (0.41) x (0.79) .016 .031 ESQ (0.64) .025 SQ samtec.com?ESW or samtec.com?ESQ Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
ESQ-123-14-L-S 价格&库存
很抱歉,暂时无法提供与“ESQ-123-14-L-S”相匹配的价格&库存,您可以联系我们找货
ESQ-123-14-L-S
  • 9+48.374459+6.27655
