FJH-10-D-04.70-4
FJH-10-D-04.70-4
    SAMTEC(申泰)
    .5MM FLEX CABLE JUMPER
FJH-10-D-04.70-4 数据手册
FLAT FLEXIBLE CABLE (FFC) JUMPER & SOCKET (0.50 mm) .0197" PITCH • FJH/ZF5S SERIES FJH FJH Mates: ZF5S NO. OF POSITIONS - –10, –15, –20, –25, –30, –40, –43, –50 SPECIFICATIONS Conductor: Tin Plated Copper Conductor Resistance: 1000 Ω/km max Current Rating: 1.8 A per pin (1 pin powered) Operating Temp Range: -55 °C to +80 °C Voltage Rating: 195 VAC - –D Length in inches –R = (76.2 mm) 3.00" –06.00 –12.00 = (304.8 mm) 12.00" LENGTH ± (3.18) .125 –24.00 = (609.6 mm) 24.00" A ± (1.52) 0.06 (Standard Lengths) (4.00) .157 —D STYLE OTHER SOLUTIONS For 1.00 mm pitch flat flexible cable series, visit: www.samtec.com?FJ www.samtec.com?ZF1 www.samtec.com?FC1 —R STYLE ZF5S - SPECIFICATIONS NO. OF POSITIONS - –10, –15, –20, –25, –30, –40, –43, –50 Insulator Material: Natural LCP Contact Material: Phosphor Bronze Plating: Sn over 50 µ" (1.27 µm) Ni Weld Tab: Phosphor Bronze Operating Temp Range: -55 °C to +105 °C Current Rating: 1.8 A per pin (1 pin powered) (Standard sizes) - LEAD STYLE –01 = Contact Bottom NO. OF POSTIONS A –10 (5.50) .217 –15 (8.00) .315 –20 (10.50) .413 –25 (13.00) .512 –30 (15.50) .610 –40 (20.50) .807 –43 (22.00) .866 –50 (25.50) 1.00 PLATING OPTION –T = Matte Tin - Notes: Stiffener color will be blue or black at Samtec’s discretion. Some sizes, styles and options are non-standard, non-returnable. - WT –WT = Weld Tab OPTION –K = (3.00 mm) .118" DIA Polyimide Film Pick & Place Pad –TR = Tape & Reel (No. of positions -1) x (0.50) .0197 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (4.82) .190 PROCESSING No. of positions x (0.50) .0197 + (5.65) .222 (2.00) .079 (2.10) .083 Note: Some sizes, styles and options are non-standard, non-returnable. F-224 (Rev 20OCT23) –4 = (4.00 mm) .157" –03.00 = Reversed End Other Platings Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (10-30) (0.15 mm) .006" max (40-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) STRIP LENGTH = (152.4 mm) 6.00" MOQ Required Mates: FJH - LENGTH = Double End (Standard sizes) ALSO AVAILABLE ZF5S - STYLE ALSO AVAILABLE MOQ Required Vertical Contact top Other positions samtec.com?FJH or samtec.com?ZF5S Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FJH-10-D-04.70-4 价格&库存
很抱歉,暂时无法提供与“FJH-10-D-04.70-4”相匹配的价格&库存,您可以联系我们找货
