EV2-30P-1PC
EV2-30P-1PC
    HRS(广濑)
    CONN CIRC PLUG SHIELDED CRIMP
EV2-30P-1PC 数据手册
Water-proof shielded 220A connector EV2 Series ■Features 1.The connection is made using a multipurpose crimp contact. The EV2 connector replaces conventional screw terminated connections creating a stable electrical connection. 2.Rated current of 220A using 40mm² cables. (Ambient Temperature 25˚C) 3.Resistant to random vibration (ISO 16750-3, JASO D 014-3) Product is designed for use in moving objects. 4. Water-proof design, meets IP68 / IPX9K Oil-resistant through use of specialized rubber. 5. Shield design for noise reduction Designed to connect the braided shield of the cable with the connector body. 6. TÜV and UL pending 7. RoHS supported. ■Connector connection is possible. Using a multi-purpose crimp contact, mating operation and bolt fastening completes the connection. Inverter housing EV2 connector Front panel fastener Mating [Reference] Derating curve EV2 Connector [Derating Curve] Basic Curve Derating Curve Current [A] Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. This product is mainly used for power supply. Ambient Temperature [ç] Note 1 : The derating curve is derived from the basic curve multiplied by the derating factor of 0.8. Note 2 : The value of rated current varies with the ambient temperature. It is recommended to use the product within the derating curve zone. When using a UL or TÜV approved product, please use the product within the specified range as well as the derating curve aera. Note 3 : The measurement method of the derating curve is shown below. Test specimen : This product, unused prior to testing. 2 Test cable conductor cross sectional area : Receptacle side (38mm )  2 Plug side (40mm ) Test condition : Power supplied while the specimen is in a stationary state and then measured. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.7② 1 EV2 Series●Water-proof shielded 220A connector ■Applications Hybrid construction equipment , power conditioners, machine tools, small generators, and other inverter sections. ■Product Specifications Ratings UL, TÜV Pending Rated voltage AC 800V, DC 800V Operating temperature range -40℃ to +105℃ (Note 1) Rated current (Note 3) 220A (Ambient Temperature 25℃) Storage temperature range Rated voltage AC 1000V, DC 1000V Rated current (Note 3) 200A -10℃ to +60℃ Operating temperature range -40℃ to +105℃ (Note 1) Storage temperature range -10℃ to +60℃ Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 1 : Including temperature rise due to current carrying. Note 2 : The value of rated current varies with the ambient temperature. It is recommended to use the product within the derating curve zone. When using a UL or TÜV approved product, please use the product within the specified range as well as the derating curve aera. Item 1. Contact resistance 2. Insulation resistance Specifications Conditions Contact part : 0.5mΩ or less Between the exterior and the cable shield Measured at DC 1A 100mΩ or less 1000MΩ or more Measured at DC 500V 3. Withstanding voltage No flashover or breakdown Apply AC 4260V for 1 minute. 4. Repeated operation ①Contact resistance : Maximum of 1mΩ 30 times of repeated operation ②Insertion and removal force : Maximum of 150N 5. Vibration resistance ①No electrical discontinuity of 10μs or more average acceleration 57.9m/s² in 3 directions for 8 ②No damage, crack or loosened parts. Testing conditions : frequency range : 10 to 2000Hz, 6. Shock resistance 7. Temperature cycles 8. Brine spraying hours each (ISO 16750-3, JASO D 014-3) Testing conditions: acceleration : 490m/s², ①No electrical discontinuity of 10μs or more duration : 11ms, and half-sine wave in 3 directions, ②No damage, crack or loosened parts. 3 cycles for each -40℃ : 30 minutes → Room temperature : 2 to 3 Insulation resistance : Minimum of 100MΩ minutes → 125℃ : 30 minutes → Room temperature : 2 to 3 minutes, 5 cycles No considerable corrosion impairing Left in the brine of 5% concentration for 48 hours. electric/mechanical functions. Insulation resistance : Minimum of 100MΩ (When dried) While the connector is mated with the applicable 10. Pressure-resistance panel, apply an air pressure of 17.6kPa in the internals of the connector for 30 seconds. 9. Moisture resistance (Steady state) Left at a temperature of 40° C and in humidity of 90 to 95% for 96 hours. No air bubbles generated from the internals of the connector. ■Materials / Finish Item Materials Finish Remarks Resin parts Contact spring Conductor section Nut O-ring Gasket PPS resin (Black) Stainless steel Copper alloy Iron Nitrile hydride rubber Fluororubber ---------------------- UL94V-0 ---------------------------------------------------------------------------------------------------------- ---------------------- Tin plated Nickel plated ------------------------------------------- ※Use commercially available M6 bolts, crimp contacts, and electric wires.  Recommended crimping contact : R38-8 manufactured by JST ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. EV2 − 30 R * − 1 S * (**) ❹ ❺ ❻ ❼ ❽ ❶ Series name : EV2 ❷ Connector size : Indicates the outer diameter of the mated plug section. ❸ Connector type : R=Receptacle P=Plug ❹ Serial symbols : Modification types are indicated by A, B, C,・ ・ ・. 2 ❺ Number of contacts : 1 ❻ Connector structure : S=With a contact spring P=Without contact spring ❼ Contact connection method : B=Screw-fastened connection C=Crimp connection ❽ When different types of specifications are provided, ・ ・for identification. attach (01), (02),・ EV2 Series●Water-proof shielded 220A connector ■Receptacle 32.8 Part No. HRS No. Remarks EV2-30R-1SB 139-0200-7 00 ̶̶̶ ■Plug 34 49 53.8 16 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 53.9 79.2 Part No. HRS No. Remarks EV2-30P-1PC 139-0201-0 ̶̶̶ 3 EV2 Series●Water-proof shielded 220A connector BApplicable Tools Tool / Jig HRS No. Part No. Crimp tools for round-form contacts HT112/REC-150F 902-1516-5 00 Cable crimp tools EV2-30P-1PC/CKED Cable crimp tools : Crimpers only EV2-30P-1PC/CKED(61) Cable crimp tools : Anvil only EV2-30P-1PC/CKED(62) Spring ring pressor jigs EV2-30P-1PC/PRMD Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HT112/REC-150F EV2-30P-1PC/CKED ̶̶̶ ̶̶̶ ̶̶̶ EV2-30P-1PC/PRMD Note : Please perform maintenance of crimping tools according to the instructions of the tool manufacturer. Diagram of the panel mounting slot dimension ※Please refer to the specification for details. 36.5±0.1 11.5±0.1 43.4±0.1 M4×0.7, blind hole is required B B 25±0.05 16±0.05 Minimum pitch 45±0.1 B-B 20±0.1 13mm minimum, blind bag hole is required Reference mating surface 1.5±0.1 C M6×1 Reference mating surface Ø31±0.05 C (1:1) 0 ° -15 45° Powered by TCPDF (www.tcpdf.org) 902-1521-0 00 902-1521-0 61 902-1521-0 62 902-1522-0 10 Remarks Equivalent product : REC-150F made by IZUMI Product Company ̶̶̶ Please ensure surface is free from burr. Water-proof Rz3.2 surface ※Features without dimensions are for reference only. BSafety Precautions Warning ●Do not touch the exposed conductor while it is energized, failing to follow this warning may cause an electric shock and injury. ●The power should be in the OFF position when inserting or extracting this connector. Caution ●Use dedicated tools with applicable cables. Use of non-applicable items, could lead to an accident due to the insufficient performance. ●Please only use Hirose approved contacts, using unapproved contacts can result in a lowering of the product’s performance and cause a serious accident. Please contact your local Hirose representative for additional information. ® 4 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2017. Contents are subject to change without notice for the purpose of improvements.
EV2-30P-1PC 价格&库存
很抱歉,暂时无法提供与“EV2-30P-1PC”相匹配的价格&库存,您可以联系我们找货
EV2-30P-1PC
    • 1+285.81120
    • 200+114.04800
    • 500+110.23560
    • 1000+108.34560
