HSEC8-140-01-L-PV-2-1 数据手册
HIGH-SPEED
EDGE CARD SYSTEMS
0.60 mm, 0.80 mm and 1.00 mm PITCH
FEATURES & BENEFITS
• Maximum Design Flexibility
• Up to 64 Gbps PAM4 performance
• PCI Express® 3.0, 4.0, 5.0 and 6.0
• Edge Rate® contacts optimized for signal
integrity performance and high-cycle life
• Up to 200 positions available
• Vertical, right-angle, edge mount,
pass-through orientations
• Power/signal combo, press-fit tails,
rugged weld tabs, locks and latches
• Mating cable assemblies available
Rugged tucked
beam technology
(HTEC8)
KEY SPECIFICATIONS
Differential pair for
increased speed
(HSEC8-DP)
Custom designs allow
for misalignment in
the X-Y axes (HSEC1)
SERIES
PITCH
TOTAL
POSITIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
HSEC6
0.60 mm
56-168
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
1.9 A (2 pins)
240 VAC
Yes
HTEC8
0.80 mm
20-200
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
3.0 A (2 pins)
215 VAC
Yes
HSEC8
0.80 mm
18-200
Black LCP
BeCu
-55 ℃ to +125 ℃
2.8 A (2 pins)
240 VAC
Yes
HSEC1
1.00 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.2 A (2 pins)
215 VAC
Yes
F-224 (Rev 04APR24)
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • PASS-THROUGH & POWER COMBO
HSEC8
POSITIONS
PER ROW
1
10, 13, 20
CARD
THICKNESS
–01
= (1.60 mm)
.062"
thick card
HSEC8-PE
- DV -
PLATING
OPTION
A
PE
–L
OTHER
OPTIONS
“X”R
–K
= 10 µ"
(0.25 µm)
Gold on
contact area,
Matte Tin
on tail
Leave blank for
Tray Packaging
= (5.50 mm)
.217" DIA
Polyimide
Film Pick &
Place Pad
–TR
=Tape & Reel
Packaging
–FR
–S
Card Mates:
(1.60 mm) .062"
thick card,
HSC8
= 30 µ"
(0.76 µm)
Gold on
contact area,
Matte Tin
on tail
= Full Reel
Tape & Reel
Packaging
(Must order max.
quantities per reel.
Contact Samtec for
parts per reel)
1RRI3RVLWLRQV[
ALSO AVAILABLE
1.00 mm High-Speed
Micro Plane Socket.
View complete specifications
at samtec.com?SAL1
HSEC8
SIGNAL
POSITIONS
1
20, 30, 40
(Signal positions
per row)
1RRI3RVLWLRQV[
View complete specifications at: samtec.com?HSEC8-DV
CARD
THICKNESS
–01
= (1.60 mm) .062"
thick card
- PV -
PLATING
OPTION
–L
POWER
POSITIONS
–2, –4
= 10 µ" (0.25 µm)
Gold on contact area,
Matte Tin on tail
= Weld Tab
–2
= Use with
(2.36 mm)
.093"
Thick PCB
A
(8.00)
.315
B
(8.00)
.315
(15.03)
.592
(15.21)
.599
D
C
SIGNAL
POSITIONS
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
OTHER
OPTION
–WT
= Use with
(1.60 mm)
.062"
Thick PCB
–S
Card Mates:
(1.60 mm) .062"
thick card
–1
(Total, 2 per
power bank)
= 30 µ" (0.76 µm)
Matte Tin on tail
HSEC8-PV
POWER
TAIL
A
(–2)
B
(–2)
POWER POSITIONS
C
(–2)
A
(–4)
B
(–4)
C
(–4)
(32.10) 1.264 (15.20) .598 (18.20) .717 (44.10) 1.736 (15.20) .598 (18.20) .717
30
(40.10) 1.579 (23.20) .913 (26.20) 1.031 (52.10) 2.051 (23.20) .913 (26.20) 1.031
40
(48.10) 1.894 (31.20) 1.228 (34.20) 1.346 (60.10) 2.366 (31.20) 1.228 (34.20) 1.346
POWER
TAIL
D
–1
(2.35) .093
–2
(3.13) .123
View complete specifications at: samtec.com?HSEC8-PV
samtec.com/EdgeCard
F-224 (Rev 04APR24)
HSEC8-140-01-L-PV-2-1 价格&库存
很抱歉,暂时无法提供与“HSEC8-140-01-L-PV-2-1”相匹配的价格&库存,您可以联系我们找货
