JM-2BL-63
JM-2BL-63
    JST
    插件
    JM-2BL-63
JM-2BL-63 数据手册
JM CONNECTOR 2.54mm Jumper connectors pitch Standard type Features –––––––––––––––––––––––– • Stackable This connector is stackable in both directions. • Low profile This connector measures 8.5mm high after mounting. The receptacle is 6.0mm high. Grooved type • High reliability Each contact makes an electrical connection with its mating header post at two points. This redundancy ensures continuity even under adverse environmental conditions. • Through style The receptacle allows the mating post to pass completely through and measures 6.0mm in height. It is suited for various headers having posts measuring 6.0mm or more in height. • Provides convenient test points This is a two-circuit jumper connector suited for changing or switching circuits on printed circuit boards without using DIP switches. It is compact and light, thus can be mounted on printed circuit boards without interfering with the placement of other components. The connector is easy to use, low in cost, and has a wide range of applications in industrial and consumer products. Standard type Grooved type Provides extra test points where circuits can be checked without the disassembly of components. Specifications ––––––––––––––––––– • Current rating: 3 A AC, DC • Voltage rating: 250 V AC, DC • Temperature range: -55˚C to +125˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 30 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable PC board thickness: 1.2 to 1.6 mm • Number of circuits: RE header 2 to 30 RF header 2 to 60 (even numbers only) * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 1 JM CONNECTOR Receptacle ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Type 5.08 4.18 6 6 2.54 2.5 Model No. Finish Color Q'ty / box Nickel-undercoated, JM-2BK-61 Mating part; gold-plated 0.1micron min. Nickel-undercoated, JM-2BL-63 Mating part; gold-plated 0.4micron min. Standard Nickel-undercoated, JM-2R-64 Mating part; gold-plated 0.76micron min. Copper-undercoated, JM-2W-96 tin-plated (reflow treatment) Grooved *JM-T2W-61B Nickel-undercoated, Mating part; gold-plated 0.1micron min. Black Blue Red 5,000 Natural White Material Contact: Phosphor bronze Housing: PBT, UL94V-0 2.54 2.1 2.54 RoHS compliance Note: 1. *Marked product is not UL/CSA approved. 2. Contact JST for special products. 5.08 Header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– RE header RF header (2.66) 6.2 0.64 2.54 1.27 2.54 (1.83) 3 3.4 2.54 2.54 6 1.27 6 2.54 0.64 Gold-plated product Tin-plated product Material Model No. RE-H( )2TD-1130 RF-H( )2TD-1130 RoHS compliance Wafer Post PBT, UL94V-0, black Brass Finish Nickel-undercoated, gold-plated Material Model No. Wafer RE-H( )2TD-1190 PBT, UL94V-0, Finish Post Copper-undercoated, Brass black tin-plated (reflow treatment) RF-H( )2TD-1190 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. A two-digit number (RE header: 02 to 30 or RF header: 02 to 60 even numbers only) representing the number of cicuits should be inserted in (*). 2. Special headers and side-entry type RE and RF headers are also available. For details, refer to pages RE series and RF series. PC board layout (viewed from soldering side) and Assembly layout ––––––––––––––––––– φ1 +0.1 0 1.27min. 2.54±0.05 (2.66) 2.54 3.4 8.54 3 3 (2.66) 8.54 8.54 1.27min. 8.54 2.54 ±0.05 6.2 3.4 +0.1 0 1.46 min. φ1 With RF header 1.83min. With RE header 6.2 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. Note: 2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 2
JM-2BL-63 价格&库存
很抱歉,暂时无法提供与“JM-2BL-63”相匹配的价格&库存,您可以联系我们找货
JM-2BL-63
    • 1+1.42884
    • 200+0.55296
    • 500+0.53352
    • 1000+0.52391
