LBT CONNECTOR A Type
Emboss
Emboss Tape
Tape
Disconnectable Crimp style connectors
Specifications
• Current rating: Power supply circuit; 7.0 A AC/DC (AWG #20)
Signal circuit; 0.5 A AC/DC (AWG #28)
• Voltage rating: 50 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Power supply circuit
Initial value/ 15 mΩ max.
After environmental tests/ 30 mΩ max.
Signal circuit
Initial value/ 20 mΩ max.
After environmental tests/ 40 mΩ max.
• Insulation resistance: 100 MΩ min.
• Withstanding voltage: 500 VAC/minute
• Applicable wire: Power supply circuit
Conductor size/ AWG #24 to #20
Insulation O.D./ 1.11 to 1.44 mm
Signal circuit
Conductor size/ AWG #28
Insulation O.D./ 0.6 to 0.8 mm
* In using the products,refer to "Handling Precaution for Terminal
and Connector" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
This connector is for connecting the lithium
polymer battery or for connecting DC-IN, and
has the sequence structure for connection to
the power supply circuit in preference to
connection to the signal circuit by dividing the
signal circuit and power supply circuit clearly.
Moreover, this is the low profile connector
(space saving) for applying the high current by
adopting the heat radiation structure.
● Connector for power supply (7.0 A)
● Low profile (Space saving)
● Hybrid model of Signal circuit
+ Power supply circuit
● Heat radiation structure
● Sequence structure
● High-strength
● Check of incomplete mating
Standards
Recognized E60389
PC board layout and Assembly layout
A±0.05
B ±0.05
1.25 ±0.05
1
4.8 ±0.05
+0.1
2.75 ±0.05
2.9 ±0.05
2.5 ±0.05
0.5
1.2
+0.1
±0.05
R0.25
+0.1
3
0.6 ±0.05
Circuit No.1
1.55 ±0.05
1±0.05
2.05 ±0.05
C±0.05
1.5
1.5±0.05
5.65 ±0.05
±0.05
Header outline
Note: 1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details.
1
Contact
Power supply
1.7
5.9
Power supply
2.6
0.6
Applicable wire
mm2
AWG #
Insulation
O.D. (mm)
0.22~0.5
24~20
1.11~1.44
7,000
0.08
28
0.6~0.8
23,000
Model No.
1.2
SLBTAD-01T-M0.5
SSH-003T-P0.2-H
Signal
1.45
2.9
Q'ty/
reel
Material and Finish
Power supply: Copper alloy, tin-plated (reflow treatment)
Signal: Phosphor bronze, tin-plated (reflow treatment)
RoHS2 compliance
Contact
Signal
SLBTAD-01T-M0.5
3.9
1.6
2
0.8
0.8
AP-K2N
アプリケータ
Dies
Crimp applicator with dies
MKS-L
MK/SLBTAD-01-05
APLMK SLBTAD01-05
MKS-L-10-3
MK/SSH/L-003-02
APLMK SSH/L003-02
Note: Contact JST for fully automatic crimping applicator.
1.35
0.5
SSH-003T-P0.2-H
Crimping
machine Crimp applicator
0.45
Housing
No. of circuits
Power
supply
D
B
1
Model No.
Signal
LBTAR-03V-2K-K(HF)
LBTAR-05V-2K-K(HF)
LBTAR-07V-2K-K(HF)
LBTAR-09V-2K-K(HF)
1
C
3
2
3
5
7
Dimensions (mm)
C
B
D
Q’ty/
bag
3.45
9.1
3,000
5.45
2.0
11.1
3,000
7.45
4.0
13.1
2,000
9.45
6.0
15.1
2,000
7.45
Material and Finish
PBT, UL94V-0
RoHS2 compliance
Circuit No.1 mark
Header
No. of circuits
D
6.55
0.25
Power
supply
1
2
3
5
7
3
K-A
JST
Signal
Model No.
SM03B-LBTAKS-TD-N2T-K(HF)
SM05B-LBTAKS-TD-N2T-K(HF)
SM07B-LBTAKS-TD-N2T-K(HF)
SM09B-LBTAKS-TD-N2T-K(HF)
Dimensions (mm)
A
B
8.2 3.45
C
D
Q'ty/
reel
9.1 1,500
10.2
5.45
2.0
11.1 1,500
12.2
7.45
4.0
13.1 1,500
14.2
9.45
6.0
15.1 1,500
0.8
Material and Finish
1
0.8
C
B
A
Power supply contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Signal contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Housing: Heat resisting resin, UL94V-0
Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
RoHS2 compliance
Note: The products listed above are supplied on embossed-tape.
2
Model number allocation
Contact for power supply circuit
Contact for signal circuit
S LBTA D - 01 T - M 0.5
S SH - 003 T - P 0.2 - H
Form: S... Strip form
Form: S...Strip form
Series name
Series name
Product shape: D...Contact for power supply circuit
Applicable wire: AWG #28
Applicable wire: AWG #24 to #20
Surface finish: T...Tin-plated (reflow treatment)
Material: P...Phosphor bronze
Material: Copper alloy
Terminal size
Terminal size
Type: For single socket
Housing
LBTA R - 09 V - 2 K - K (HF)
Series name
Part name: Receptacle
No. of circuits
(Power supply circuit + Signal circuit): 3, 5, 7, 9
Flammability: V...UL94V-0
No. of circuits (Power supply circuit): 2
Color indication: K...Black
Product type: K...High-strength product
Indication of halogen-free: (HF)...Halogen-free
Header
SM 09 B - LBTA K S - T D - N 2 T - K - TB (HF)
Assembly style: SM...SMT Side entry type
No. of circuits (Power supply circuit + Signal circuit): 3, 5, 7, 9
Part name: Header
Series name
Indication of clinch: S...No clinch
Surface finish (Signal circuit): T...Copper-underplated Tin-plated (reflow treatment)
Solder tab specification: D...DIP type
Sequence (Between power supply circuits): N...None
Surface finish (Power supply circuit): T...Copper-underplated Tin-plated (reflow treatment)
Packaging style: TB...Embossed-taping
Indication of halogen-free: (HF)... Halogen-free
3
很抱歉,暂时无法提供与“LBTAR-07V-2K-K(HF)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.029122000+0.26302
- 国内价格 香港价格
- 1+2.554341+0.33109
- 10+2.3015210+0.29832
- 50+1.7610150+0.22826
- 100+1.39486100+0.18080
- 500+1.32512500+0.17176
- 1000+1.272811000+0.16498
- 2000+1.246662000+0.16159
- 国内价格
- 10+2.80800
- 100+2.59200
- 500+2.48400
- 1000+2.41920
- 2000+2.37600
