MMS-102-02-L-DV-A
MMS-102-02-L-DV-A
    SAMTEC(申泰)
    2MM SOCKET STRIPS
MMS-102-02-L-DV-A 数据手册
TIGER CLAW™ SOCKET STRIP 8 G b p s (2.00 mm) .0787" PITCH • MMS SERIES MMS Board Mates: TMMH, TMM,MTMM, MMT, TW, LTMM, ZLTMM, TSH Cable Mates: TCMD SPECIFICATIONS Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (MMS/TMM): 3.9 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: DH = (2.13 mm) .084" to (2.79 mm) .110" SH = (2.13 mm) .084" minimum or pass-through Top Entry DV/SV = (2.13 mm) .084" to (4.32 mm) .170" Bottom Entry DV/SV = (4.27 mm) .168" minimum (Plus board) MMS - NO. PINS PER ROW 01 - 02 thru 40 (2.00) .0787 - PLATING OPTION –F –L = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail —SV –SH = Single Horizontal –DV —DH No. of positions x (2.00) .0787 + (0.56) .022 (4.45) .175 —DH —SH —DV —SV MMS -1 NO. PINS PER ROW - - 02 thru 40 —DV —SH —SV 02 (2.00) .0787 - PLATING OPTION –F —SV - ROW OPTION = Polarized Position –K –SH = (5.50 mm) .217" DIA Polyimide Film Pick & Place Pad (3 positions min.) (–SV & –DV only) = Single Horizontal –DV = Double Vertical —SH –M = Metal Pick & Place Pad (4 positions min.) (–DV only) –DH = Double Horizontal –P = Plastic Pick & Place Pad (4 positions min.) (–SV & –DV only) (4.17) .164 (4.00) .157 —DH —P (1.22) .048 —M (1.22) .048 (1.39) .055 (1.39) .055 (4.50) .177 —SV OTHER OPTION –“XX” = Single Vertical = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail (3.05) .120 —DH –SV = Gold flash on contact, Matte Tin on tail (2.16) .085 (2.92) .115 (3.05) .120 (2.92) .115 No. of positions x (2.00) .0787 + (0.56) .022 F-224 (Rev 10NOV23) –“XX” = Polarized Position = Double Horizontal —DV —DV Note: Some lengths, styles and options are non-standard, non-returnable. OPTION –DH (4.00) .157 MOQ Required Alignment Pin (–DV only) Locking clips and Through-hole pass-through options Other platings –SV = Single Vertical - = Double Vertical –L ALSO AVAILABLE ROW OPTION = Gold flash on contact, Matte Tin on tail —SH PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) -1 —SH —DV –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) —DH samtec.com?MMS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MMS-102-02-L-DV-A 价格&库存
很抱歉,暂时无法提供与“MMS-102-02-L-DV-A”相匹配的价格&库存,您可以联系我们找货
MMS-102-02-L-DV-A
  • 132+13.81126132+1.78649
