MPSC-02-24-02-7.70-03-L-V 数据手册
HIGH POWER SYSTEMS
20-60 A
p er bla de
FEATURES & BENEFITS
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assemblies with 10-16 AWG wire
(see pages 246-248)
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
CREEPAGE & CLEARANCE
Hermaphroditic options
samtec.com?MPPT and
samtec.com?UPPT
Hinging options available
samtec.com?FMPT and
samtec.com?FMPS
PITCH
CREEPAGE
CLEARANCE
UPT/UPS/UPPT
5.50 mm
1.51 mm
MPT/MPS/MPTC/MPSC
2.95 mm
2.71 mm
PET/PES/PETC/PESC
3.66 mm
3.31 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
SERIES
INSULATOR CONTACT
MATERIAL MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
UPT/UPS
(3.81 mm)
.150"
Black LCP
BeCu
Sn or Au over
-55 ºC to +105 ºC (Sn)
50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au)
23 A
(1 pin powered)
438 VAC
Yes
UPPT
(3.81 mm)
.150"
Black LCP
Copper Alloy
Sn or Au over
21.4 A
(1 pin powered)
425 VAC
Yes
MPT/MPS
(5.00 mm)
.1969"
Black LCP
Copper Alloy
Sn or Au over
28.8 A
(1 pin powered)
575 VAC
Yes
(5.00 mm)
.197" (pwr)
MPTC/MPSC (2.00 mm)
.079" (sig)
Black LCP
Signal:
Phosphor
Sn or Au over
Bronze
Terminal:
Copper Alloy
28.8 A
(pwr - 1 pin powered)
5A
(sig - 4 pins powered)
250 VAC
Yes
PET/PES
(6.35 mm)
.250"
Black LCP
Copper Alloy
Sn or Au over
58.7 A
(1 pin powered)
450 VAC
Yes
PETC/PESC
(6.35 mm)
.250" (pwr)
(2.54 mm)
.100" (sig)
Black LCP
Copper Alloy
Sn or Au over
31.4 A
5.7 A
650 VAC (pwr)
450 VAC (sig)
Yes
F-224
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(5.00 mm) .197"(PWR) / (2.00 mm) .079"(SIG) • 30 A SIGNAL/POWER COMBO SYSTEMS
SERIES
POWER
PINS
MPTC
Per end
MPSC
–02
Terminal
–01
Socket
SIGNAL
PINS
POWER
PINS
–16
Per end
–40
–02
–01
–24
–80
MPTC
LEAD STYLE
–6.30
= (6.30 mm) 0.248"
(MPTC only)
–7.70
= (7.70 mm) 0.303"
(MPSC only)
TAIL LENGTH
–01
–L
= Use with (1.60 mm)
.062" Thick PCB
–03
= Use with (2.36 mm)
.093" Thick PCB
= Locking Clip
(Manual placement
required)
–T
= Matte tin on
contact and tail
(power),
Gold on contact,
Matte tin on tail
(Signal)
TAIL
LENGTH
B
–01
(2.72) .107
–03
(3.51) .138
MPSC
Board Mates:
MPTC
OTHER
OPTION
–LC
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(Power & Signal)
Board Mates:
MPSC
Cable Mates:
MPCC
-V-
PLATING
OPTION
POWER
PINS/ENDS
A
16
24
40
80
SIGNAL SIGNAL SIGNAL SIGNAL
PINS
PINS
PINS
PINS
–01
(27.44)
1.081
(31.45)
1.238
(39.44)
1.553
(59.44)
2.340
–02
(37.44)
1.474
(41.45)
1.632
(49.44)
1.946
(69.44)
2.734
TAIL
LENGTH
View complete specifications at: samtec.com?MPTC & samtec.com?MPSC
SERIES
POWER
PINS
MPTC
Per end
MPSC
–02
Terminal
Socket
–01
SIGNAL
PINS
–24
–80
POWER
PINS
TAIL LENGTH
–01
Per end
.062" Thick PCB
–01
–02
–03
.093" Thick PCB
MPTC-RA
Board Mates:
MPSC
Cable Mates:
MPCC
- 01 -
PLATING OPTION
- RA -
–L
–01
(2.72) .107
–03
(3.51) .138
MPSC-RA
Board Mates:
MPTC
TAIL
LENGTH
B
–01
(2.20) .087
–03
(3.00) .118
OTHER OPTION
–SD
–LC
–T
(2.72) .107
(3.52) .139
= Screw Down
= Locking Clip
(Manual placement
required)
= Matte Tin on contact
and tail (power),
Gold on contact,
Matte tin on tail
(Signal)
B
–01
–03
–SD or –LC is a
required callout
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(Power & Signal)
TAIL
LENGTH
B
POWER
PINS/ENDS
A
24
SIGNAL
PINS
80
SIGNAL
PINS
–01
(35.25) 1.388 (63.25) 2.490
–02
(45.25) 1.781
POWER
PINS/
ENDS
(73.25) 2.884
A
24
SIGNAL
PINS
80
SIGNAL
PINS
–01
(36.52) 1.438
(64.52) 2.540
–02
(46.52) 1.831
(74.52) 2.934
Note: Some lengths, styles
and options are non-standard,
non-returnable
F-224
MPSC-02-24-02-7.70-03-L-V 价格&库存
很抱歉,暂时无法提供与“MPSC-02-24-02-7.70-03-L-V”相匹配的价格&库存,您可以联系我们找货
