MPT-04-6.30-03-L-V-LC
    SAMTEC(申泰)
    Wire to Board, Header, Connector Assembly
MPT-04-6.30-03-L-V-LC 数据手册
HIGH POWER SYSTEMS 20-60 A p er bla de FEATURES & BENEFITS • Current Rating: 23 A - 58.7 A per power blade • 3.81 mm, 5.00 mm and 6.35 mm pitch • Dual blade contact system • Power only or power/signal combinations available • Right-angle and vertical orientations • Rugged screw down and locking clip options • Discrete wire cable assemblies with 10-16 AWG wire (see pages 246-248) • “Hinged” for unique mating in any orientation from 0° to 90° and space confined applications CREEPAGE & CLEARANCE Hermaphroditic options samtec.com?MPPT and samtec.com?UPPT Hinging options available samtec.com?FMPT and samtec.com?FMPS PITCH CREEPAGE CLEARANCE UPT/UPS/UPPT 5.50 mm 1.51 mm MPT/MPS/MPTC/MPSC 2.95 mm 2.71 mm PET/PES/PETC/PESC 3.66 mm 3.31 mm Selectively loading contacts achieves customer specific creepage and clearance requirements. KEY SPECIFICATIONS SERIES SERIES INSULATOR CONTACT MATERIAL MATERIAL PLATING OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE UPT/UPS (3.81 mm) .150" Black LCP BeCu Sn or Au over -55 ºC to +105 ºC (Sn) 50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au) 23 A (1 pin powered) 438 VAC Yes UPPT (3.81 mm) .150" Black LCP Copper Alloy Sn or Au over -55 ºC to +105 ºC (Sn) 50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au) 21.4 A (1 pin powered) 425 VAC Yes MPT/MPS (5.00 mm) .1969" Black LCP Copper Alloy Sn or Au over -55 ºC to +105 ºC (Sn) 50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au) 28.8 A (1 pin powered) 575 VAC Yes (5.00 mm) .197" (pwr) MPTC/MPSC (2.00 mm) .079" (sig) Black LCP Signal: Phosphor Sn or Au over -55 ºC to +105 ºC (Sn) Bronze 50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au) Terminal: Copper Alloy 28.8 A (pwr - 1 pin powered) 5A (sig - 4 pins powered) 250 VAC Yes PET/PES (6.35 mm) .250" Black LCP Copper Alloy Sn or Au over -55 ºC to +105 ºC (Sn) 50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au) 58.7 A (1 pin powered) 450 VAC Yes PETC/PESC (6.35 mm) .250" (pwr) (2.54 mm) .100" (sig) Black LCP Copper Alloy Sn or Au over -55 ºC to +105 ºC (Sn) 50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au) 31.4 A (pwr - 1 pin powered) 5.7 A (sig - 4 pins powered) 650 VAC (pwr) 450 VAC (sig) Yes F-224 samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (5.00 mm) .1969" PITCH • 30 A DUAL BLADE/LEAF SYSTEMS SERIES - MPT POWER PINS - –02, –03, –04, –06, –08 Terminal MPS - LEAD STYLE –6.30 Socket - TAIL LENGTH –01 = (6.30 mm) 0.248" (MPT only) = Use with (1.60 mm) .062" Thick PCB –7.70 = Use with (2.36 mm) .093" Thick PCB –03 = (7.70 mm) 0.303" (MPS only) –L TAIL (Required Callout) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –V = Vertical –T = Matte Tin 1RRISRVLWLRQV[     MPT - PLATING OPTION Board Mates: MPS Cable Mates: MPSS     A –01 (2.72) .107 –03 (3.51) .138 MATED HEIGHT $ 1RRISRVLWLRQV[     MPS TAIL LENGTH MPS 13.81 mm MPT Board Mates: MPT   TAIL LENGTH   $ View complete specifications at: samtec.com?MPT & samtec.com?MPS SERIES - MPT Terminal MPS Socket POWER PINS –02, –04, –06, –08 - 01 - TAIL LENGTH - –01 = Use with (1.60 mm) .062" Thick PCB –03 –01 (2.72) .107 –03 (3.52) .139 RA - SD –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –T = Use with (2.36 mm) .093" Thick PCB = Matte Tin MPT-RA Board Mates: MPS Cable Mates: MPSS - PLATING OPTION A   1RRISRVLWLRQV[     TAIL LENGTH A –01 (2.72) .107 –03 (3.51) .138 TAIL LENGTH A $   MPS-RA 1RRISRVLWLRQV[     Board Mates: MPT   –01 (2.72) .107 –03 (3.52) .139   $ View complete specifications at: samtec.com?MPT & samtec.com?MPS Note: Some lengths, styles and options are non-standard, non-returnable samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
MPT-04-6.30-03-L-V-LC 价格&库存
很抱歉,暂时无法提供与“MPT-04-6.30-03-L-V-LC”相匹配的价格&库存,您可以联系我们找货
