PCIE-LP-01-01-S-DV-A-WT-TR
    SAMTEC(申泰)
    1.00 MM PCI EXPRESS EDGE CARD C
PCIE-LP-01-01-S-DV-A-WT-TR 数据手册
PCIE–098–02–F–D–EMS2 F-218 (Rev 16NOV17) PCIE–064–02–F–D–RA (1.00 mm) .0394" PCIE SERIES PCIE–036–02–F–D–TH PCI EXPRESS CARD SOCKETS ® Polarized Card Mates: (1.60 mm) .062" card SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?PCIE Insulator Material: –TH=Black Nylon –EMS2 & –RA=LCP Contact: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.2 A per pin (2 adjacent pins powered) Operating Temp: -55 °C to +125 °C Card Insertion Depth: (7.65 mm) .301" nominal RoHS Compliant: Yes Lead–Free Solderable: –RA & –EMS2=Yes –TH=Wave only Cable Mates: PCIEC Supports one, four, eight and sixteen PCI Express® links Note: While optimized for 50 W applications, this connector with alternative signal/ground patterns may also perform well in certain 75 W applications. Contact Samtec for further information. Choice of card–edge mount or PCB mount Accepts 1.60 mm (.062") card Alignment pins HIGH-SPEED CHANNEL PERFORMANCE 14 PCIE Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality (MOQ Required) Four rows on 2 mm pitch G b p s NO. OF POSITIONS PCIE ALSO AVAILABLE • Other platings Contact Samtec. PLATING OPTION 02 TAIL OPTION D FILE NO. E111594 OTHER SOLUTIONS –036, –064, –098, –164 PCI Express® Jumpers & Extenders call for PCIEC Series –EMS2 –F = Edge Mount = Gold flash on contact, Tin on tail –TH = Through-hole A B2 –RA B1 = Right-angle (1.00) .03937 B (1.78) .070 • Loop back Extender (From one PCIe® slot to another PCIe® slot) • Ser-Des Physical Extender (From one PCIe® slot to another PCIe® Ser-Des) • Physical Extender for easy troubleshooting of PCIe® card debug and analysis (PCIe® slot to Emulator or Analyzer) Contact Samtec. PCI-SIG®, PCI Express® and the PCIe® design marks are registered trademarks and/or service marks of PCI-SIG. Note: Some lengths, styles and options are non-standard, non-returnable. A2 (8.61) .339 (7.50) .295 A1 (11.65) .459 (11.00) .433 (15.40) .606 (7.30) .287 (1.35) .053 C D (2.05) .081 DIA A B (1.80) .071 (2.00) .079 (2.50) .098 (10.00) .394 –TH B1 (9.45) .372 (10.00) .394 (4.50) .177 (4.50) .177 –RA (6.50) .256 (2.50) .098 POSITIONS A B C D –036 (X1) (25.00) .984 (39.00) 1.535 (56.00) 2.205 (89.00) 3.504 (7.65) .301 (21.65) .852 (38.65) 1.522 (71.65) 2.821 (6.00) .236 (20.00) .787 (37.00) 1.457 (70.00) 2.756 (9.15) .360 (23.15) .911 (40.15) 1.581 (73.15) 2.880 –098 (X8) –164 (X16) Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM (1.50) .059 –EMS2 –064 (X4) A1 (1.00) .03937 C D (7.65) .301 (11.05) .435 (2.31) .091 All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
PCIE-LP-01-01-S-DV-A-WT-TR 价格&库存
很抱歉,暂时无法提供与“PCIE-LP-01-01-S-DV-A-WT-TR”相匹配的价格&库存,您可以联系我们找货
    • 275+37.37329
    • 550+24.52056
    • 1100+20.39752
    • 2200+19.03124
    • 5225+16.20195
    • 7975+13.54193
    库存:125
