QSH-060-01-F-D-DP-A-TR 数据手册
F-214
QSH–060–01–L–D–DP–A
QSH–060–01–L–D–A–K
QSH–030–01–F–D–A
(0,50 mm) .0197"
QSH SERIES
HIGH SPEED GROUND PLANE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QSH
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating: Au or Sn over
50µ" (1,27 µm) Ni
Current Rating:
Contact:
2 A per pin
(1 pin powered per row)
Ground Plane:
25 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
125 VAC (5 mm Stack Height)
Max Cycles: 100
RoHS Compliant: Yes
Processing:
Lead-Free Solderable: Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (030-060)
(0,15 mm) .006" max (090)
Board Stacking:
For applications requiring
more than two connectors per
board contact ipg@samtec.com
Blade &
Beam
Design
Board Mates:
QTH
Integral metal plane
for power or ground
Cable Mates:
HQCD, HQDP
(See Also Available note)
100 GbE ™
transport
er
yp
H
XAUI ®
s
PCI Expres
SATA ™
InfiniBand
notes at
Download app ppnote
/a
om
c.c
te
www.sam
@ samtec.com
Contact SIG
on protocols
for questions
Rated @ 3dB Insertion Loss
with PCB effects* w/o PCB effects**
Single-Ended Signaling
–D
9 GHz / 18 Gbps
9.5 GHz / 19 Gbps
Differential Pair Signaling
–D
8 GHz / 16 Gbps 10.5 GHz / 21 Gbps
–DP 9.5 GHz / 19 Gbps 16.5 GHz / 33 Gbps
*Performance data includes effects of a non-optimized PCB.
**Test board losses de-embedded from performance data.
Performance data for other stack heights and complete test data
available at www.samtec.com?QSH or contact sig@samtec.com
QTH/QSH
5 mm Stack Height
Type
PINS PER ROW
NO. OF PAIRS
QSH
01
RECOGNITIONS
PLATING
OPTION
A
TYPE
OTHER
OPTION
–F
For complete scope
of recognitions see
www.samtec.com/quality
= Gold Flash
on Signal Pins
and Ground Plane,
Matte Tin on tails
–030, –060, –090
(60 total pins per bank = –D)
–020, –040, –060
ALSO AVAILABLE
–DP = (No. of Pairs per Row/20) x
(20,00) .7875 + (1,27) .050
(20,00) .7875
–C*
02
(7,49)
.295
01
(0,50)
.0197
(0,15)
.006
(3,25)
.128
(3,05)
.120
(7,24)
.285 (0,76)
.030
(0,89)
.035
DIA
= Electro-Polished
Selective
50µ" (1,27 µm) min Au
over 150µ" (3,81 µm)
Ni on Signal Pins
in contact area,
10µ" (0,25 µm) min Au
over 50µ" (1,27 µm)
Ni on Ground Plane
in contact area,
Matte Tin over 50µ"
(1,27 µm) min Ni
on all solder tails
QTH
MATED
LEAD
HEIGHT
STYLE WITH QSH*
–01
–02
–03
–04
–05
–07
–L
WWW.SAMTEC.COM
(5,00) .197
(8,00) .315
–TR
= Tape & Reel
(–090 positions
maximum)
–L
= Latching
Option
(N/A on
–060 (–D–DP)
& –09 positions)
(11,00) .433
(16,00) .630
(19,00) .748
(25,00) .984
*Processing
conditions will
affect mated height.
*Note: –C Plating passes
10 year MFG testing
(0,64)
.025
–K
= (8,25 mm)
.325" DIA
Polyimide Film
Pick & Place Pad
= Differential
Pair
(–01 only)
= 10µ" (0,25 µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–D = (No. of Pins per Row/30) x
(MOQ Required)
–D
= SingleEnded
–D–DP
–L
(20 pairs per bank = –D–DP)
FILE NO: 090871_0_000
• 14 mm, 15 mm, 22 mm
and 30 mm stack height
(Caution: Some automatic
placement/inspection
machines may have
component height
restrictions. Please
consult machinery
specifications.)
• 30µ" (0,76 µm) Gold
(Specify -H plating for
Data Rate cable mating
applications.)
• Edge Mount & Guide Posts
• 80 (-DP), 120, 150
positions per row
• Retention Option
Contact Samtec.
s
ocol
t
o
r
d
P
orte
p
p
u
S
Note: Some lengths, styles
and options are non-standard,
non-returnable.
OTHER
SOLUTIONS
• Board Spacing Standoffs.
See SO Series
QSH-060-01-F-D-DP-A-TR 价格&库存
很抱歉,暂时无法提供与“QSH-060-01-F-D-DP-A-TR”相匹配的价格&库存,您可以联系我们找货
