F-213
QTH–090–01–C–D–A
(0,50 mm) .0197"
QTH–030–01–L–D–A
QTH–060–07–F–D–A
QTH SERIES
HIGH SPEED GROUND PLANE HEADER
SPECIFICATIONS
Integral metal plane for
power or ground
Board Mates:
QSH
Standard Stack Heights
from 5 mm to 25 mm
For complete specifications and
recommended PCB layouts see
www.samtec.com?QTH
Insulator Material:
Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Current Rating:
Contact:
1.0A per contact @ 30°C
Temperature Rise
Ground Plane:
7.8A per ground plane @ 30°C
Temperature Rise
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
125 VAC (5 mm Stack Height)
Max Cycles:
100
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (030-060)
(0,15 mm) .006" max (090)
Board Stacking:
For applications requiring
more than two connectors per
board contact ipg@samtec.com
Cable Mates:
HQCD, HQDP
(See Application Specific note)
fina
TM
s
ocol
Prot orted
Supp
EXTENDED LIFE PRODUCT
10 year Mixed Flowing Gas with 50µ" Gold
Call Samtec for maximum cycles mated with QSH
Type
LEAD
STYLE
PINS PER ROW
NO. OF PAIRS
QTH
Specify
LEAD
STYLE
from
chart
–030, –060, –090
(60 total pins per bank = –D)
–020, –040, –060
APPLICATION
SPECIFIC OPTION
• 14 mm, 15 mm, 22 mm
and 30 mm stack height
(Caution: Some automatic
placement/inspection
machines may have
component height
restrictions. Please consult
machinery specifications.)
• 30µ" (0,76 µm) Gold
(Specify -H plating
for Data Rate cable mating
applications.)
• Edge Mount & Guide Posts
• 80 (-DP), 120, 150
positions per row
• Retention Option
Call Samtec.
*Note: –C Plating passes
10 year MFG testing
Note: Some lengths, styles
and options are non-standard,
non-returnable.
100 GbE ™
sport
Hyper tran
XAUI ®
s
PCI Expres
SATA ™
InfiniBand
Rated @ 3dB Insertion Loss
with PCB effects* w/o PCB effects**
Single-Ended Signaling
–D
9 GHz / 18 Gbps
9.5 GHz / 19 Gbps
Differential Pair Signaling
–D
8 GHz / 16 Gbps 10.5 GHz / 21 Gbps
–DP 9.5 GHz / 19 Gbps 16.5 GHz / 33 Gbps
*Performance data includes effects of a non-optimized PCB.
**Test board losses de-embedded from performance data.
Performance data for other stack heights and complete test data
available at www.samtec.com?QTH or contact sig@samtec.com
QTH/QSH
5 mm Stack Height
(20 pairs per bank = –D–DP)
notes at
Download app ppnote
/a
om
c.c
www.samte
@ samtec.com
G
SI
t
ac
nt
Co
on protocols
for questions
PLATING
OPTION
01
= Gold Flash on
Signal Pins and
Ground Plane,
Matte Tin on tails
= Single-Ended
–C*
(7,11)
.280
(0,50)
.0197
(0,20)
.008
A
A
–01 & –02
–03 thru –07
(0,76)
.030
(0,89)
.035
DIA
(0,64)
.025
–L
WWW.SAMTEC.COM
OTHER
OPTION
–K
–D
= 10µ" (0,25 µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–DP = (No. of Pairs per Row/20) x (20,00) .7875
(20,00) .7875
A
TYPE
–F
–L
–D = (No. of Pins per Row/30) x (20,00) .7875
02
l i nch.com
= Electro-Polished
Selective
50µ" (1,27 µm) min Au
over 150µ" (3,81 µm)
Ni on Signal Pins in
contact area,
10µ" (0,25 µm) min Au
over 50µ" (1,27 µm)
Ni on Ground Plane
in contact area,
Matte Tin over 50µ"
(1,27 µm) min Ni
on all solder tails
–D–DP
= Differential Pair
(–01 only)
= (7,00 mm)
.275" DIA
Polyimide
film Pick &
Place Pad
(N/A with -05 &
-07 lead style)
–TR
QTH
LEAD
STYLE
–01
–02
–03
–04
–05
–07
= Tape & Reel
HEIGHT (–090 positions
maximum)
WITH
QSH*
A
(4,27)
.168
(7,26)
.286
(10,27)
.404
(15,25)
.600
(18,26)
.718
(24,24)
.954
(5,00)
.197
(8,00)
.315
(11,00)
.433
(16,00)
.630
(19,00)
.748
(25,00)
.984
–L
= Latching
Option
(–01 lead
style only)
(N/A on
–060 (–D–DP),
–080, –090
& –120)
*Processing conditions
will affect mated height.
ALSO AVAILABLE
Board Spacing Standoffs.
See SO Series.
